[GeoNode-users] Help with geonodeAuthProvider configuration
Ivo Santos
ivojfs at gmail.com
Thu Jan 21 05:12:34 PST 2016
It's not working on development mode.
Sorry the (probably) dumb question, but how can I use mod_wsgi to run
GeonNode?
Maybe this info could help. The error that appears on apache when the user
is logged on geonode and tries to see a layer is:
mod_wsgi (pid=7536): Exception occurred processing WSGI script
'/var/www/geonode/wsgi/geonode.wsgi'.
And I realized that:
if the user is logged he can't see the layers (Example:
http://atlas.example.com/layers/geonode%3Acom26_wgs84 ) .
if the user tries to create a new map (
http://atlas.example.com/layers/maps/new) the layers appear as available
and could be shown on the map.
But if the user tries to save the map with the layers on screen, it gives a
500 error.
Thank you in advance.
Best regards,
Ivo
2016-01-21 13:01 GMT+00:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> One more thing, if you are running GeoNode in development mode (paver
> start_django) it may not work when running the embedded geoserver.
> If is not yet like this, try using mod_wsgi to run GeoNode
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Thu, Jan 21, 2016 at 1:30 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>> Alessio,
>> Thank you for your reply. I think that I did understand what you were
>> saying... After some improvements, geonode and geoserver are still unable
>> to communicate when a user is logged on geonode (this time, independently
>> of being logged on geoserver).
>> On local_settings.py:
>> # OGC (WMS/WFS/WCS) Server Settings
>> OGC_SERVER = {
>> 'default' : {
>> 'BACKEND' : 'geonode.geoserver',
>> 'LOCATION' : 'http://atlas.example.com:8080/geoserver/',
>> 'PUBLIC_LOCATION' : GEOSERVER_URL,
>> 'USER' : 'admin',
>> 'PASSWORD' : '*********************'
>> ALLOWED_HOSTS=['atlas.example.com']
>> On geonodeAuthProvider/config.xml:
>> <baseUrl>http://atlas.example.com/</baseUrl>
>> Does anyone have a clue of what is the problem? It seems the same problem
>> Ariel had in November:
>> https://lists.osgeo.org/pipermail/geonode-users/2015-November/001150.html
>> Best regards,
>> Ivo
>> 2016-01-20 15:19 GMT+00:00 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it>:
>>> The GeoNode/GeoServer security, right now, in order to work correctly
>>> needs both GeoNode and GeoServer exposed under the same domain (and the
>>> same port).
>>> Therefore if you expose GeoNode as http://mysite/ you must also expose
>>> GeoServer as http://mysite/geoserver
>>> The GeoNode authentication provider can be configured with
>>> http://localhost, I guess, but you must be sure that GeoServer is also
>>> exposed as http://localhost/geoserver.
>>> The rationale is that the GeoNodeSecurityClient looks for the
>>> AuthPrincipal from the cookies.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Wed, Jan 20, 2016 at 3:58 PM, Ivo Santos <ivojfs at gmail.com> wrote:
>>>> Hi everyone,
>>>> After several limiting issues concerning the configuration of apache
>>>> that I have to thank you especially to Simone for all the help and
>>>> guidance, I am now with a problem with the connection between geonode and
>>>> geoserver:
>>>> If user as log in on geoserver but not on geonode, he can view the
>>>> layers.
>>>> If user is not loged on geoserver, he can not view the layers and the
>>>> error is:
>>>> 2016-01-20 14:39:59,947 WARN [geonode.security] - Error connecting to
>>>> the GeoNode server for authentication purposes
>>>> org.springframework.security.authentication.AuthenticationServiceException:
>>>> Communication with GeoNode failed (UsernamePasswordAuthenticationToken)
>>>> If user is logged on both geonode and geoserver it gives a internal
>>>> error (500).
>>>> Following this thread
>>>> <https://groups.google.com/forum/m/#!topic/geonode-users/84HvjbarPE8>I
>>>> tried to apply this doc
>>>> <https://github.com/GeoNode/geonode/commit/cc732e0a73c6d04d8f57fdf376dfb9a9848abd86>to
>>>> my installation but it didn't worked.
>>>> Does it have to remain like "http://localhost/" on both files or
>>>> should I substitute by "http://atlas.example.com" on both? If you need
>>>> more info please let me know.
>>>> Thank you for all the help and patience for this newcomer,
>>>> regards,
>>>> Ivo
>>>> Ivo Santos
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Ivo Santos
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160121/72f24568/attachment-0001.html>
More information about the geonode-users
