[GeoNode-users] Geoserver can't see changes
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jan 28 05:36:43 PST 2016
Ok that is an issue of the old releases, but is not the issue we are
looking for.
You can solve this with:
$ sudo chown -R www-data /var/www/geonode/
2016-01-28 14:31 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
> I mean editing metada of layers WMS. I started Django in debug mode and
> verbose logging in Geoserver and I get a error: "Permission denied save
> thumbnail"
> 2016-01-28 8:05 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> I see,
>> we released the stable version last November, which is available on
>> ppa:geonode/stable.
>> Anyway, in order to understand your issue we need more information, what
>> do you mean by editing wms cascade?
>> Also in geoserver you can find the log page, it would be good if you
>> could check for errors there.
>> 2016-01-28 13:59 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>> Hi
>>> Geonode I not installed, but with these steps was installed:
>>> *Install from PPA in Ubuntu 14.04*
>>> $ sudo add-apt-repository ppa:geonode/testing
>>> $ sudo apt-get update
>>> $ sudo apt-get install geonode
>>> Set the IP address and create a superuser
>>> $ sudo geonode-updateip 127.0.0.1
>>> $ geonode createsuperuser
>>> 2016-01-28 4:01 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Hi. How did you install geonode? Take look at the geoserver and Apache
>>>> logs they will give you more info.
>>>> Il mercoledì 27 gennaio 2016, Rosario Peña <roelpeag at gmail.com> ha
>>>> scritto:
>>>>> The geoserver can't see the changes did in the geonode, if I delete a
>>>>> layer, this layer remains in the geoserver and I can't  edit the layers WMS
>>>>> cascade because I get a Internal Server Error.
>>>> Simone
>>> Ing. Rosario Peña
>> Simone
> Ing. Rosario Peña
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160128/86588e43/attachment.html>
More information about the geonode-users mailing list
