[GeoNode-users] Geoserver can't see changes
Rosario Peña roelpeag at gmail.com
Thu Jan 28 10:42:25 PST 2016
This is the log that was generate in the moment of delete a layer, but that
layer yet is in geoserver.
2016-01-28 12:00 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Sorry but 10 MB is too heavy for me and my connection is not very strong
> where I am now. Try to catch only the relevant part. PS please keep posting
> to the list.
> 2016-01-28 16:23 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>> I saw the log but isn't very clear for me. Anyway , I attached the log.
>> 2016-01-28 9:19 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> If you delete in geonode, which has been uploaded via geonode, then it
>>> should be removed from geoserver as well. I case check the geoserver logs
>>> when this error occurs.
>>> 2016-01-28 15:07 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>>> Great, it's work :D
>>>> Another error is that Geoserver not take the changes made in the
>>>> Geonode. Any idea why???
>>>> 2016-01-28 8:36 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> Ok that is an issue of the old releases, but is not the issue we are
>>>>> looking for.
>>>>> You can solve this with:
>>>>> $ sudo chown -R www-data /var/www/geonode/
>>>>> 2016-01-28 14:31 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>>>>> I mean editing metada of layers WMS. I started Django in debug mode
>>>>>> and verbose logging in Geoserver and I get a error: "Permission denied save
>>>>>> thumbnail"
>>>>>> 2016-01-28 8:05 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>>> I see,
>>>>>>> we released the stable version last November, which is available on
>>>>>>> ppa:geonode/stable.
>>>>>>> Anyway, in order to understand your issue we need more information,
>>>>>>> what do you mean by editing wms cascade?
>>>>>>> Also in geoserver you can find the log page, it would be good if you
>>>>>>> could check for errors there.
>>>>>>> 2016-01-28 13:59 GMT+01:00 Rosario Peña <roelpeag at gmail.com>:
>>>>>>>> Hi
>>>>>>>> Geonode I not installed, but with these steps was installed:
>>>>>>>> *Install from PPA in Ubuntu 14.04*
>>>>>>>> $ sudo add-apt-repository ppa:geonode/testing
>>>>>>>> $ sudo apt-get update
>>>>>>>> $ sudo apt-get install geonode
>>>>>>>> Set the IP address and create a superuser
>>>>>>>> $ sudo geonode-updateip 127.0.0.1
>>>>>>>> $ geonode createsuperuser
>>>>>>>> 2016-01-28 4:01 GMT-05:00 Simone Dalmasso <
>>>>>>>>> Hi. How did you install geonode? Take look at the geoserver and
>>>>>>>>> Apache logs they will give you more info.
>>>>>>>>> Il mercoledì 27 gennaio 2016, Rosario Peña <roelpeag at gmail.com>
>>>>>>>>> ha scritto:
>>>>>>>>>> The geoserver can't see the changes did in the geonode, if I
>>>>>>>>>> delete a layer, this layer remains in the geoserver and I can't  edit the
>>>>>>>>>> layers WMS cascade because I get a Internal Server Error.
>>>>>>>>> Simone
>>>>>>>> Ing. Rosario Peña
>>>>>>> Simone
>>>>>> Ing. Rosario Peña
>>>>> Simone
>>>> Ing. Rosario Peña
>>> Simone
>> Ing. Rosario Peña
> Simone
Ing. Rosario Peña
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160128/a5ea30cd/attachment-0001.html>
10:13:04,497 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:13:04,498 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:13:04,500 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:13:04,500 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:13:04,501 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:13:07,746 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run...
2016-01-28 10:13:17,746 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run...
2016-01-28 10:13:27,746 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run...
2016-01-28 10:13:37,746 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run...
2016-01-28 10:13:47,746 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run...
2016-01-28 10:13:55,892 DEBUG [geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at fd02eb3e] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl at f7fe962a]]
2016-01-28 10:13:57,746 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run...
2016-01-28 10:14:06,154 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:06,155 DEBUG [org.geoserver] - Thread 655 locking in mode WRITE
2016-01-28 10:14:06,155 DEBUG [org.geoserver] - Thread 655 got the lock in mode WRITE
2016-01-28 10:14:06,158 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,159 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,160 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,160 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,162 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,162 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,192 DEBUG [org.geoserver] - Thread 655 releasing the lock in mode WRITE
2016-01-28 10:14:06,193 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:06,199 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,288 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:06,288 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,289 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,290 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:06,290 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,291 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:06,291 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,291 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:06,292 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:06,291 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:06,292 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,292 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,293 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,293 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:06,294 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,294 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,295 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:06,295 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,296 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,300 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:06,301 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,301 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:06,301 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,302 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:06,302 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:06,303 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:06,303 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,303 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:06,303 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,304 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,304 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,304 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:06,305 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:06,305 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,305 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,305 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,306 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,307 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:06,308 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,308 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,326 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:06,326 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:06,326 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:06,327 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:06,327 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:06,327 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,327 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:06,327 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,327 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,328 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,328 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,328 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:06,329 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,329 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,330 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:06,330 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,331 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,334 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:06,335 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:06,335 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:06,335 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,336 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:06,336 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,336 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,336 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:06,337 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:06,337 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:06,337 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,337 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:06,337 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,337 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,338 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,338 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,338 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,339 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,341 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:06,341 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,342 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,343 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:06,343 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,344 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,345 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:06,346 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,346 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:06,346 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,347 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,347 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:06,347 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,348 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:06,348 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,348 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:06,349 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:06,349 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,349 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,350 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,351 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:06,352 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:06,352 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,353 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,353 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:06,353 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:06,354 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,354 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,354 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,355 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:06,356 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:06,356 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,357 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,357 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:06,357 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:06,358 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,358 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,358 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,359 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:06,360 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,360 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:06,432 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:06,433 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,433 DEBUG [org.geoserver] - Thread 32 locking in mode READ
2016-01-28 10:14:06,433 DEBUG [org.geoserver] - Thread 32 got the lock in mode READ
2016-01-28 10:14:06,434 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:06,435 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:06,435 DEBUG [org.geoserver] - Thread 32 releasing the lock in mode READ
2016-01-28 10:14:06,435 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,169 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:07,169 DEBUG [org.geoserver] - Thread 32 locking in mode WRITE
2016-01-28 10:14:07,169 DEBUG [org.geoserver] - Thread 32 got the lock in mode WRITE
2016-01-28 10:14:07,172 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,173 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,174 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,175 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,176 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,177 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,206 DEBUG [org.geoserver] - Thread 32 releasing the lock in mode WRITE
2016-01-28 10:14:07,206 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:07,211 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,300 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:07,300 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:07,300 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:07,301 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:07,301 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,301 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:07,302 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:07,302 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:07,302 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:07,302 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,302 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,303 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,302 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,302 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,303 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,304 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,303 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,310 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:07,310 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:07,311 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:07,311 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:07,311 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:07,311 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:07,312 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:07,312 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,312 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,312 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:07,312 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,313 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,313 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:07,312 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:07,313 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:07,313 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,314 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,314 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,312 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:07,314 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:07,315 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:07,313 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:07,315 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:07,315 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,315 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,316 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,318 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:07,318 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,318 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:07,319 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:07,319 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,319 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,321 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:07,322 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,322 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:07,322 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:07,322 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,323 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:07,323 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,323 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,323 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,322 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,384 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:07,384 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,384 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:07,384 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:07,385 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,384 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,385 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:07,385 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,384 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:07,386 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,386 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,386 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,385 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,386 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,387 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,387 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,387 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:07,387 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,386 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:07,388 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:07,388 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,388 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,389 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,430 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:07,430 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:07,430 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:07,431 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:07,431 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:07,431 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:07,431 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,431 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,431 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:07,431 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,431 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,432 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,432 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:07,432 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:07,433 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,433 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,432 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:07,434 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:07,434 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,435 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,435 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,438 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:07,439 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:07,439 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,439 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:07,439 DEBUG [org.geoserver] - Thread 255 locking in mode WRITE
2016-01-28 10:14:07,439 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:07,439 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,440 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,439 DEBUG [org.geoserver] - Thread 255 got the lock in mode WRITE
2016-01-28 10:14:07,440 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:07,440 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,440 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,441 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:07,441 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,441 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:07,441 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,442 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,442 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,444 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,444 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,445 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:07,445 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,445 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,446 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,446 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:07,447 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:07,447 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:07,447 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,447 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,448 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,448 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,449 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,449 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:07,449 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,450 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,450 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,451 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,480 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode WRITE
2016-01-28 10:14:07,480 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:07,486 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,571 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:07,571 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:07,572 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:07,572 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,573 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,573 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:07,573 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,573 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:07,574 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,574 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,574 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:07,574 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,573 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:07,574 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:07,575 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:07,575 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,575 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,576 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,576 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,606 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:07,607 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:07,607 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,607 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,608 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:07,609 DEBUG [org.geoserver] - Thread 42 locking in mode WRITE
2016-01-28 10:14:07,609 DEBUG [org.geoserver] - Thread 42 got the lock in mode WRITE
2016-01-28 10:14:07,611 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,612 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,612 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:07,613 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:07,613 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,613 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,613 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,614 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,615 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,616 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,619 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:07,620 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,620 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,626 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:07,626 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,627 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,633 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:07,633 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,634 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,644 DEBUG [org.geoserver] - Thread 42 releasing the lock in mode WRITE
2016-01-28 10:14:07,645 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:07,650 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,693 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:07,693 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,694 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,700 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:07,700 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,701 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,705 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:07,706 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:07,706 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,706 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,710 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:07,711 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:07,711 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:07,711 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,712 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:07,712 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:07,712 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:07,712 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:07,713 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:07,712 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,713 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,713 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:07,713 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,713 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,713 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,713 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,714 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,714 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,719 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:07,720 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,720 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:07,720 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,720 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,721 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,722 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:07,722 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,722 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,722 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,723 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:07,722 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:07,721 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,723 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:07,723 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,723 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,724 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,724 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,724 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,724 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,724 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,725 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,725 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:07,726 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:07,726 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,726 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,731 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:07,731 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,732 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,746 DEBUG [diskquota.CacheCleanerTask] - DiskQuota disabled, ignoring run...
2016-01-28 10:14:07,756 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:07,756 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:07,757 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:07,757 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,757 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,758 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,761 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:07,761 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:07,762 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:07,762 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,762 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:07,763 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,763 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,763 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:07,764 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:07,763 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:07,764 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:07,764 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,764 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,764 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,765 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,819 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:07,819 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:07,819 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:07,820 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,820 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,820 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:07,821 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:07,821 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:07,820 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,821 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:07,821 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,821 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,822 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:07,822 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,822 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,823 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:07,823 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,823 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,823 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,824 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,828 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:07,828 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:07,829 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,829 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,829 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,830 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,830 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:07,830 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:07,831 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:07,831 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,831 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:07,831 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:07,831 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,832 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:07,832 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,832 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,833 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,833 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,834 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,835 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:07,835 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:07,836 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:07,836 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,836 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,836 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,837 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,838 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:07,838 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,839 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,839 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:07,839 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,840 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,840 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,840 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,840 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:07,840 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,841 DEBUG [org.geoserver] - Thread 649 locking in mode READ
2016-01-28 10:14:07,841 DEBUG [org.geoserver] - Thread 649 got the lock in mode READ
2016-01-28 10:14:07,841 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,841 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,841 DEBUG [org.geoserver] - Thread 657 locking in mode READ
2016-01-28 10:14:07,841 DEBUG [org.geoserver] - Thread 657 got the lock in mode READ
2016-01-28 10:14:07,842 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,842 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:07,842 DEBUG [org.geoserver] - Thread 649 releasing the lock in mode READ
2016-01-28 10:14:07,842 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,842 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:07,843 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:07,843 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:07,843 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:07,843 DEBUG [org.geoserver] - Thread 657 releasing the lock in mode READ
2016-01-28 10:14:07,843 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,843 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,843 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,844 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,844 DEBUG [org.geoserver] - Thread 254 locking in mode READ
2016-01-28 10:14:07,844 DEBUG [org.geoserver] - Thread 254 got the lock in mode READ
2016-01-28 10:14:07,844 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:07,844 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,845 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,845 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:07,845 DEBUG [org.geoserver] - Thread 254 releasing the lock in mode READ
2016-01-28 10:14:07,845 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,846 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,846 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:07,846 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,847 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,847 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:07,848 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:07,848 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,849 DEBUG [org.geoserver] - Thread 254 locking in mode READ
2016-01-28 10:14:07,849 DEBUG [org.geoserver] - Thread 254 got the lock in mode READ
2016-01-28 10:14:07,849 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,850 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:07,851 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:07,852 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:07,852 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,852 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,852 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,853 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,853 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:07,853 DEBUG [org.geoserver] - Thread 254 releasing the lock in mode READ
2016-01-28 10:14:07,853 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:07,853 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:07,854 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:07,854 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,854 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,854 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,854 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,855 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,857 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:07,857 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,858 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,859 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:07,859 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:07,859 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,860 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,860 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,860 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:07,861 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:07,861 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,861 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,861 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,862 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,937 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:07,938 DEBUG [org.geoserver] - Thread 657 locking in mode WRITE
2016-01-28 10:14:07,938 DEBUG [org.geoserver] - Thread 657 got the lock in mode WRITE
2016-01-28 10:14:07,941 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:07,941 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,941 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,942 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,942 DEBUG [org.geoserver] - Thread 254 locking in mode READ
2016-01-28 10:14:07,943 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,943 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,944 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,945 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,980 DEBUG [org.geoserver] - Thread 657 releasing the lock in mode WRITE
2016-01-28 10:14:07,980 DEBUG [org.geoserver] - Thread 254 got the lock in mode READ
2016-01-28 10:14:07,980 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:07,981 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:07,982 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:07,982 DEBUG [org.geoserver] - Thread 254 releasing the lock in mode READ
2016-01-28 10:14:07,982 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:07,986 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,095 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:08,095 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:08,096 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:08,096 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:08,096 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,096 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:08,097 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:08,097 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:08,097 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,097 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:08,097 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,097 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,096 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,098 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,096 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,098 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:08,099 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:08,099 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,099 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,099 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,100 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,103 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:08,104 DEBUG [org.geoserver] - Thread 42 locking in mode WRITE
2016-01-28 10:14:08,104 DEBUG [org.geoserver] - Thread 42 got the lock in mode WRITE
2016-01-28 10:14:08,106 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:08,106 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,106 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,107 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,107 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,108 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,109 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,110 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,111 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,111 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:08,112 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,112 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,119 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:08,119 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,120 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,126 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:08,126 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,127 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,133 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:08,134 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,134 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,139 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:08,140 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:08,140 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,140 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,143 DEBUG [org.geoserver] - Thread 42 releasing the lock in mode WRITE
2016-01-28 10:14:08,143 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:08,147 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:08,147 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,148 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,149 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,154 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:08,154 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,155 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,161 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:08,161 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,162 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,167 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:08,168 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,168 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,174 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:08,174 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,175 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,180 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:08,181 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,181 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,186 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:08,187 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:08,187 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,187 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,193 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:08,194 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,194 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,200 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:08,201 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,201 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,207 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:08,208 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,208 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,209 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:08,210 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:08,210 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,210 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,211 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:08,211 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:08,212 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:08,212 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:08,212 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,212 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,212 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,213 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,214 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:08,214 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,215 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:08,215 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,215 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,216 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,216 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:08,217 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:08,217 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,218 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,257 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:08,258 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:08,258 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,259 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:08,259 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,259 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:08,260 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:08,260 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,260 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:08,260 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,261 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,261 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,261 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,261 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:08,261 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:08,262 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:08,262 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,262 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,262 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,321 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:08,322 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,322 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:08,322 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,323 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,323 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,323 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:08,323 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:08,324 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,324 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,324 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:08,324 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,324 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:08,325 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:08,325 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,325 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,325 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,326 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,328 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:08,329 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:08,329 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:08,329 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,329 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,329 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,330 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,330 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:08,331 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,331 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,331 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:08,332 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,332 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:08,333 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:08,333 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,333 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,333 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:08,334 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,334 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,335 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:08,335 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,336 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,337 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:08,338 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,338 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,340 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:08,340 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,340 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:08,340 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,341 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:08,341 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:08,341 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,342 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,342 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:08,342 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:08,342 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,342 DEBUG [org.geoserver] - Thread 649 locking in mode READ
2016-01-28 10:14:08,343 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:08,342 DEBUG [org.geoserver] - Thread 649 got the lock in mode READ
2016-01-28 10:14:08,343 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,343 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,344 DEBUG [org.geoserver] - Thread 658 locking in mode READ
2016-01-28 10:14:08,344 DEBUG [org.geoserver] - Thread 658 got the lock in mode READ
2016-01-28 10:14:08,344 DEBUG [org.geoserver] - Thread 255 locking in mode READ
2016-01-28 10:14:08,344 DEBUG [org.geoserver] - Thread 255 got the lock in mode READ
2016-01-28 10:14:08,344 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,344 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,343 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:08,344 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:08,345 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:08,345 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:08,345 DEBUG [org.geoserver] - Thread 649 releasing the lock in mode READ
2016-01-28 10:14:08,345 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,345 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,345 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode READ
2016-01-28 10:14:08,346 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,346 DEBUG [org.geoserver] - Thread 655 locking in mode READ
2016-01-28 10:14:08,346 DEBUG [org.geoserver] - Thread 655 got the lock in mode READ
2016-01-28 10:14:08,346 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,347 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:08,347 DEBUG [org.geoserver] - Thread 655 releasing the lock in mode READ
2016-01-28 10:14:08,347 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,347 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:08,347 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode READ
2016-01-28 10:14:08,348 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,348 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:08,348 DEBUG [org.geoserver] - Thread 255 locking in mode READ
2016-01-28 10:14:08,348 DEBUG [org.geoserver] - Thread 255 got the lock in mode READ
2016-01-28 10:14:08,349 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,349 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,349 DEBUG [org.geoserver] - Thread 657 locking in mode READ
2016-01-28 10:14:08,349 DEBUG [org.geoserver] - Thread 657 got the lock in mode READ
2016-01-28 10:14:08,349 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:08,350 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode READ
2016-01-28 10:14:08,350 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,350 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:08,350 DEBUG [org.geoserver] - Thread 657 releasing the lock in mode READ
2016-01-28 10:14:08,352 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:08,352 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:08,352 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,353 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,353 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,353 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:08,354 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,354 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,356 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:08,356 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:08,356 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:08,357 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:08,357 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,357 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,357 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,357 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,358 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,359 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:08,359 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:08,359 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,360 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,360 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,360 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:08,361 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,361 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,363 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:08,364 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:08,364 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:08,364 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,364 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,364 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,365 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,500 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:08,501 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,501 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:08,501 DEBUG [org.geoserver] - Thread 652 locking in mode READ
2016-01-28 10:14:08,501 DEBUG [org.geoserver] - Thread 652 got the lock in mode READ
2016-01-28 10:14:08,501 DEBUG [org.geoserver] - Thread 255 locking in mode WRITE
2016-01-28 10:14:08,502 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,502 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:08,503 DEBUG [org.geoserver] - Thread 652 releasing the lock in mode READ
2016-01-28 10:14:08,503 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,503 DEBUG [org.geoserver] - Thread 255 got the lock in mode WRITE
2016-01-28 10:14:08,506 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:08,506 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,506 DEBUG [org.geoserver] - Thread 42 locking in mode WRITE
2016-01-28 10:14:08,507 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,508 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,509 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,509 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,510 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,512 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:08,513 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,513 DEBUG [org.geoserver] - Thread 658 locking in mode READ
2016-01-28 10:14:08,541 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode WRITE
2016-01-28 10:14:08,541 DEBUG [org.geoserver] - Thread 42 got the lock in mode WRITE
2016-01-28 10:14:08,541 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:08,543 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,544 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,545 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,546 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,546 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,547 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,548 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,578 DEBUG [org.geoserver] - Thread 42 releasing the lock in mode WRITE
2016-01-28 10:14:08,578 DEBUG [org.geoserver] - Thread 658 got the lock in mode READ
2016-01-28 10:14:08,578 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:08,578 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,579 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:08,580 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode READ
2016-01-28 10:14:08,580 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,583 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,659 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:08,659 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:08,660 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:08,660 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:08,660 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,661 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,661 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:08,661 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:08,662 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:08,662 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,662 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:08,662 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,662 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:08,662 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,663 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,663 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,664 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,664 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,665 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:08,666 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:08,666 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,667 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,672 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:08,672 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,672 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:08,673 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:08,673 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,673 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:08,673 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,673 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,674 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,675 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:08,675 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:08,675 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:08,676 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,676 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,676 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,677 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,677 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,681 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:08,681 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,682 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:08,682 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,683 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:08,683 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:08,683 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,683 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,684 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,684 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,685 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,687 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:08,688 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,688 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:08,688 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,689 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,689 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,690 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:08,691 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:08,691 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:08,691 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,691 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,692 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,692 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:08,692 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:08,693 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,693 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,693 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,695 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:08,695 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,696 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,696 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:08,696 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,697 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,701 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:08,702 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:08,702 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,702 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,703 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:08,703 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,704 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,704 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:08,705 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,705 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,717 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:08,717 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:08,717 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,718 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:08,718 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,718 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:08,718 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,719 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,719 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,719 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:08,719 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,719 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:08,720 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:08,720 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:08,720 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,720 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,720 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,721 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,724 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:08,725 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,725 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,725 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:08,726 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:08,726 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:08,726 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,726 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:08,727 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,727 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:08,726 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:08,727 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,727 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:08,727 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:08,728 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,728 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,728 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,729 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,730 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:08,838 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:08,838 DEBUG [org.geoserver] - Thread 655 locking in mode WRITE
2016-01-28 10:14:08,838 DEBUG [org.geoserver] - Thread 655 got the lock in mode WRITE
2016-01-28 10:14:08,841 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,842 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,843 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,844 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,845 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,845 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:08,875 DEBUG [org.geoserver] - Thread 655 releasing the lock in mode WRITE
2016-01-28 10:14:08,875 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:08,881 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,009 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:09,010 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:09,010 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:09,010 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,011 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,011 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,011 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:09,012 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,012 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:09,012 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,013 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,013 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:09,014 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,014 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,014 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:09,015 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:09,015 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:09,015 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,015 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,015 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,016 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,083 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:09,083 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:09,084 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:09,084 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:09,084 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:09,084 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:09,084 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,085 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,085 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,085 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:09,085 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,085 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:09,086 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:09,086 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,085 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,086 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:09,086 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,087 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,087 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:09,087 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,090 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:09,091 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:09,091 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,092 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:09,092 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,092 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:09,093 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,093 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,093 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,093 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:09,093 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:09,094 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:09,094 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,094 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,094 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,095 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:09,096 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,096 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,099 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:09,099 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:09,099 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,100 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:09,100 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,100 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:09,100 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,101 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,101 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:09,101 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,102 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,102 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,105 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:09,105 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,105 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:09,106 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:09,106 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,106 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,108 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:09,108 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,109 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:09,109 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:09,109 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,110 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,110 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,110 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:09,110 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,111 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,111 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,111 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:09,111 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,112 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,118 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:09,119 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,119 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:09,119 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:09,119 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,119 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:09,119 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,120 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,120 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,120 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:09,121 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:09,121 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:09,121 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,122 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,122 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,123 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:09,123 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,124 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,125 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:09,126 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:09,126 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:09,126 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,126 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,126 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,126 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:09,127 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:09,127 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,127 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,127 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:09,128 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:09,128 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,162 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:09,163 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,163 DEBUG [org.geoserver] - Thread 649 locking in mode READ
2016-01-28 10:14:09,163 DEBUG [org.geoserver] - Thread 649 got the lock in mode READ
2016-01-28 10:14:09,164 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:09,165 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:09,165 DEBUG [org.geoserver] - Thread 649 releasing the lock in mode READ
2016-01-28 10:14:09,165 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,631 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:10,631 DEBUG [org.geoserver] - Thread 649 locking in mode WRITE
2016-01-28 10:14:10,632 DEBUG [org.geoserver] - Thread 649 got the lock in mode WRITE
2016-01-28 10:14:10,634 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,635 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,636 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,637 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,638 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,639 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,669 DEBUG [org.geoserver] - Thread 649 releasing the lock in mode WRITE
2016-01-28 10:14:10,669 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:10,675 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,781 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:10,782 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:10,782 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:10,782 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:10,782 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,783 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,783 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,783 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:10,784 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:10,784 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,784 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:10,784 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:10,784 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,785 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,785 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,784 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,786 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:10,786 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,787 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,792 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:10,793 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,793 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:10,793 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,793 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:10,794 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,794 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,794 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,795 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:10,795 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:10,795 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,796 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,796 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:10,796 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,796 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,797 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,814 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:10,815 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:10,815 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,816 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,816 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:10,817 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:10,817 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,817 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,818 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:10,819 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:10,819 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,819 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,820 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:10,821 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,821 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,822 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:10,822 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:10,823 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,823 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,824 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,824 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,825 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:10,826 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,826 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,827 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:10,828 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:10,828 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,829 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,829 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:10,829 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:10,830 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:10,830 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,830 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:10,831 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:10,831 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,830 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:10,830 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,831 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,832 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,832 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,832 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:10,833 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,833 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,848 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:10,848 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,849 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,849 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:10,850 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,850 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,851 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:10,852 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,852 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,853 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:10,854 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,854 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,855 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:10,856 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,856 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,857 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:10,858 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:10,858 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,859 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,859 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,861 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:10,861 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,862 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,862 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:10,862 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:10,862 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:10,863 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,863 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:10,863 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:10,863 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,863 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,863 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,864 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,866 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:10,866 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,867 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,867 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:10,867 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:10,868 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:10,868 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,868 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,868 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,913 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:10,913 DEBUG [org.geoserver] - Thread 42 locking in mode WRITE
2016-01-28 10:14:10,913 DEBUG [org.geoserver] - Thread 42 got the lock in mode WRITE
2016-01-28 10:14:10,916 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,917 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,918 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,919 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,920 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,921 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,923 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:10,924 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,924 DEBUG [org.geoserver] - Thread 659 locking in mode READ
2016-01-28 10:14:10,954 DEBUG [org.geoserver] - Thread 42 releasing the lock in mode WRITE
2016-01-28 10:14:10,954 DEBUG [org.geoserver] - Thread 659 got the lock in mode READ
2016-01-28 10:14:10,954 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:10,955 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,956 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:10,956 DEBUG [org.geoserver] - Thread 659 releasing the lock in mode READ
2016-01-28 10:14:10,956 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,966 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:10,988 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:10,988 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:10,988 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,989 DEBUG [org.geoserver] - Thread 658 locking in mode WRITE
2016-01-28 10:14:10,989 DEBUG [org.geoserver] - Thread 658 got the lock in mode WRITE
2016-01-28 10:14:10,989 DEBUG [org.geoserver] - Thread 659 locking in mode READ
2016-01-28 10:14:10,991 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,992 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,993 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,994 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,995 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:10,996 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,027 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode WRITE
2016-01-28 10:14:11,027 DEBUG [org.geoserver] - Thread 659 got the lock in mode READ
2016-01-28 10:14:11,027 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:11,027 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,028 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:11,028 DEBUG [org.geoserver] - Thread 659 releasing the lock in mode READ
2016-01-28 10:14:11,029 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,033 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,111 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:11,112 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,112 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:11,112 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,113 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,113 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,115 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:11,116 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,116 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,116 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:11,116 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:11,117 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:11,117 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:11,117 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,117 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,117 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,118 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,118 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:11,118 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,119 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,124 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:11,124 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,124 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:11,125 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:11,125 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,125 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:11,125 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,125 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:11,126 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,126 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,127 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,127 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:11,127 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:11,127 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,128 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,128 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:11,129 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,129 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,140 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:11,141 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:11,141 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,141 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,143 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:11,143 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:11,143 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,144 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,144 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,144 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:11,145 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:11,145 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,145 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:11,146 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,145 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,146 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,146 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,147 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,148 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:11,148 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,148 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:11,149 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,149 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,150 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:11,151 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,151 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,152 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:11,152 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:11,152 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:11,152 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,153 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:11,153 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,153 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:11,153 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,153 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,154 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:11,154 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,154 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:11,155 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:11,155 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,155 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,156 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,156 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:11,157 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,157 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,159 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:11,159 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,160 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:11,160 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,160 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,161 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:11,161 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,228 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:11,228 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:11,228 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:11,229 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,230 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,235 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:11,236 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:11,236 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,236 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,237 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:11,237 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:11,237 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:11,228 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,237 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:11,241 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:11,241 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:11,241 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:11,242 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,242 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,242 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,238 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,242 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:11,241 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,243 DEBUG [org.geoserver] - Thread 658 locking in mode WRITE
2016-01-28 10:14:11,243 DEBUG [org.geoserver] - Thread 658 got the lock in mode WRITE
2016-01-28 10:14:11,243 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,243 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,244 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,246 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,247 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,248 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,249 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,249 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:11,249 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,250 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,250 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,250 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,251 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:11,251 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:11,252 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,252 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,252 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,282 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode WRITE
2016-01-28 10:14:11,282 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:11,287 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,349 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:11,349 DEBUG [org.geoserver] - Thread 658 locking in mode WRITE
2016-01-28 10:14:11,350 DEBUG [org.geoserver] - Thread 658 got the lock in mode WRITE
2016-01-28 10:14:11,352 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,353 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,354 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,355 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,356 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,357 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,388 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode WRITE
2016-01-28 10:14:11,388 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:11,393 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,479 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:11,480 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:11,480 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,481 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:11,482 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,482 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:11,482 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:11,482 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,483 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:11,483 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,483 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,483 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,484 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,484 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:11,485 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,485 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,545 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:11,545 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,546 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,547 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:11,548 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,548 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,549 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:11,549 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:11,550 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:11,550 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:11,550 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,550 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,551 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,551 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,551 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:11,552 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,552 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,552 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:11,553 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:11,553 DEBUG [org.geoserver] - Thread 255 locking in mode WRITE
2016-01-28 10:14:11,553 DEBUG [org.geoserver] - Thread 255 got the lock in mode WRITE
2016-01-28 10:14:11,556 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,557 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,557 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,558 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,558 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:11,559 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:11,559 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,559 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,559 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,560 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,591 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode WRITE
2016-01-28 10:14:11,591 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:11,597 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,602 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:11,602 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,603 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,608 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:11,609 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:11,609 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,609 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,616 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:11,616 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,617 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,622 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:11,623 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:11,623 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,624 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,630 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:11,630 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,631 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,637 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:11,638 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,638 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,645 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:11,645 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,646 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,652 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:11,653 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,653 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,657 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:11,657 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:11,658 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:11,658 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:11,658 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,659 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:11,659 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:11,660 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,660 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,660 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:11,660 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,660 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:11,661 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:11,661 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,661 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,662 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,663 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,663 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,678 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:11,678 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,679 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,681 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:11,681 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:11,682 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:11,682 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:11,682 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,682 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,682 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:11,683 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:11,683 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,683 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,683 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:11,683 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:11,684 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:11,684 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,684 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,684 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,685 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,700 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:11,700 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,700 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:11,701 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:11,701 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,701 DEBUG [org.geoserver] - Thread 42 locking in mode WRITE
2016-01-28 10:14:11,701 DEBUG [org.geoserver] - Thread 42 got the lock in mode WRITE
2016-01-28 10:14:11,704 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,704 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,705 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,706 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:11,706 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,706 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,707 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,707 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,708 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,711 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:11,712 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,712 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,717 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:11,717 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,718 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,722 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:11,722 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,723 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,727 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:11,728 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,728 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,734 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:11,735 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,735 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,740 DEBUG [org.geoserver] - Thread 42 releasing the lock in mode WRITE
2016-01-28 10:14:11,740 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:11,745 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,796 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:11,797 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:11,797 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,797 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,802 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:11,803 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,803 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,831 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:11,832 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:11,832 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:11,832 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,832 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,833 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,833 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:11,833 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:11,834 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,834 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,834 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,834 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:11,835 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:11,835 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,835 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,836 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:11,836 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,837 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,841 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:11,841 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:11,842 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:11,842 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:11,843 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:11,842 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:11,843 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:11,843 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:11,843 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:11,843 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,843 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,844 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,844 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:11,844 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,844 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,844 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,844 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:11,845 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:11,845 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,845 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,849 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:11,849 DEBUG [org.geoserver] - Thread 397 locking in mode WRITE
2016-01-28 10:14:11,849 DEBUG [org.geoserver] - Thread 397 got the lock in mode WRITE
2016-01-28 10:14:11,851 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:11,852 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,852 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,853 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,854 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,856 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,856 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,857 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:11,858 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:11,858 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,858 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,858 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,859 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,864 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:11,864 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,865 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,893 DEBUG [org.geoserver] - Thread 397 releasing the lock in mode WRITE
2016-01-28 10:14:11,893 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:11,898 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,921 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:11,922 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:11,922 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,922 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,928 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:11,929 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,929 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,934 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:11,935 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,935 DEBUG [org.geoserver] - Thread 397 locking in mode READ
2016-01-28 10:14:11,935 DEBUG [org.geoserver] - Thread 397 got the lock in mode READ
2016-01-28 10:14:11,936 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,936 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:11,937 DEBUG [org.geoserver] - Thread 397 releasing the lock in mode READ
2016-01-28 10:14:11,937 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,943 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:11,943 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,944 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,950 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:11,950 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,951 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,957 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:11,957 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,958 DEBUG [org.geoserver] - Thread 42 locking in mode READ
2016-01-28 10:14:11,958 DEBUG [org.geoserver] - Thread 42 got the lock in mode READ
2016-01-28 10:14:11,958 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,959 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:11,959 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,959 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,960 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:11,961 DEBUG [org.geoserver] - Thread 42 releasing the lock in mode READ
2016-01-28 10:14:11,961 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,985 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:11,985 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:11,986 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:11,986 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:11,986 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:11,986 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:11,987 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:11,987 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:11,987 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:11,987 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,987 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,988 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,988 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,988 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:11,988 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:11,988 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,989 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:11,989 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:11,989 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,989 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:11,990 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:11,991 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,049 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:12,049 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:12,050 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,050 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,050 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,050 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:12,050 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:12,049 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:12,051 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:12,051 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:12,051 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:12,051 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:12,051 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,052 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,052 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,052 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,052 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:12,053 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,053 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,060 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:12,060 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,061 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:12,061 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,061 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:12,061 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:12,062 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,062 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:12,062 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,062 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:12,063 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:12,063 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:12,063 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,064 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,063 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:12,065 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,065 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,065 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,064 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:12,066 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,066 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:12,066 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,067 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:12,067 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,067 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,068 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:12,068 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:12,069 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:12,069 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:12,069 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,069 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,069 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,070 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:12,071 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:12,071 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,071 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:12,071 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,071 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,072 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,072 DEBUG [org.geoserver] - Thread 255 locking in mode READ
2016-01-28 10:14:12,072 DEBUG [org.geoserver] - Thread 255 got the lock in mode READ
2016-01-28 10:14:12,072 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,072 DEBUG [org.geoserver] - Thread 655 locking in mode READ
2016-01-28 10:14:12,072 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:12,072 DEBUG [org.geoserver] - Thread 655 got the lock in mode READ
2016-01-28 10:14:12,073 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:12,073 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,073 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,073 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode READ
2016-01-28 10:14:12,073 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,073 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,074 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,074 DEBUG [org.geoserver] - Thread 658 locking in mode READ
2016-01-28 10:14:12,074 DEBUG [org.geoserver] - Thread 658 got the lock in mode READ
2016-01-28 10:14:12,074 DEBUG [org.geoserver] - Thread 655 releasing the lock in mode READ
2016-01-28 10:14:12,074 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,074 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,075 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:12,075 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:12,076 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:12,076 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,076 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,076 DEBUG [org.geoserver] - Thread 398 locking in mode READ
2016-01-28 10:14:12,076 DEBUG [org.geoserver] - Thread 398 got the lock in mode READ
2016-01-28 10:14:12,077 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:12,075 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,077 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,077 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,078 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,078 DEBUG [org.geoserver] - Thread 654 locking in mode READ
2016-01-28 10:14:12,078 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode READ
2016-01-28 10:14:12,078 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,079 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:12,080 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,080 DEBUG [org.geoserver] - Thread 658 locking in mode READ
2016-01-28 10:14:12,080 DEBUG [org.geoserver] - Thread 658 got the lock in mode READ
2016-01-28 10:14:12,081 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,081 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode READ
2016-01-28 10:14:12,081 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,078 DEBUG [org.geoserver] - Thread 398 releasing the lock in mode READ
2016-01-28 10:14:12,078 DEBUG [org.geoserver] - Thread 654 got the lock in mode READ
2016-01-28 10:14:12,082 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,082 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,083 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,083 DEBUG [org.geoserver] - Thread 654 releasing the lock in mode READ
2016-01-28 10:14:12,083 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,083 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:12,083 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:12,084 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:12,084 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:12,084 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,084 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:12,085 DEBUG [org.geoserver] - Thread 655 locking in mode READ
2016-01-28 10:14:12,085 DEBUG [org.geoserver] - Thread 655 got the lock in mode READ
2016-01-28 10:14:12,085 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,085 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,085 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,086 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,086 DEBUG [org.geoserver] - Thread 654 locking in mode READ
2016-01-28 10:14:12,086 DEBUG [org.geoserver] - Thread 654 got the lock in mode READ
2016-01-28 10:14:12,086 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:12,086 DEBUG [org.geoserver] - Thread 658 locking in mode READ
2016-01-28 10:14:12,086 DEBUG [org.geoserver] - Thread 658 got the lock in mode READ
2016-01-28 10:14:12,086 DEBUG [org.geoserver] - Thread 655 releasing the lock in mode READ
2016-01-28 10:14:12,086 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,087 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,087 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,087 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:12,087 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,087 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,087 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode READ
2016-01-28 10:14:12,088 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,088 DEBUG [org.geoserver] - Thread 654 releasing the lock in mode READ
2016-01-28 10:14:12,088 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:12,089 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:12,089 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,090 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,092 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:12,093 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,093 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,094 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:12,095 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:12,095 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,095 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,095 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,096 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:12,096 DEBUG [org.geoserver] - Thread 660 locking in mode READ
2016-01-28 10:14:12,096 DEBUG [org.geoserver] - Thread 660 got the lock in mode READ
2016-01-28 10:14:12,096 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,096 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,096 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,097 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,097 DEBUG [org.geoserver] - Thread 660 releasing the lock in mode READ
2016-01-28 10:14:12,097 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,098 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:12,098 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,099 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,149 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:12,149 DEBUG [org.geoserver] - Thread 660 locking in mode WRITE
2016-01-28 10:14:12,149 DEBUG [org.geoserver] - Thread 660 got the lock in mode WRITE
2016-01-28 10:14:12,152 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,153 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,154 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,155 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,156 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,157 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,190 DEBUG [org.geoserver] - Thread 660 releasing the lock in mode WRITE
2016-01-28 10:14:12,191 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:12,196 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,233 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:12,233 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:12,234 DEBUG [org.geoserver] - Thread 658 locking in mode WRITE
2016-01-28 10:14:12,234 DEBUG [org.geoserver] - Thread 658 got the lock in mode WRITE
2016-01-28 10:14:12,234 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,234 DEBUG [org.geoserver] - Thread 660 locking in mode READ
2016-01-28 10:14:12,236 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,237 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,238 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,239 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,240 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,241 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,273 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode WRITE
2016-01-28 10:14:12,273 DEBUG [org.geoserver] - Thread 660 got the lock in mode READ
2016-01-28 10:14:12,273 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:12,274 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,274 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:12,275 DEBUG [org.geoserver] - Thread 660 releasing the lock in mode READ
2016-01-28 10:14:12,275 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,278 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,421 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:12,422 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,422 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,423 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:12,423 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:12,424 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,424 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:12,424 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,424 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,424 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:12,424 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,425 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:12,425 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,425 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,426 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,426 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:12,426 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,427 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,428 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:12,428 DEBUG [org.geoserver] - Thread 655 locking in mode WRITE
2016-01-28 10:14:12,428 DEBUG [org.geoserver] - Thread 655 got the lock in mode WRITE
2016-01-28 10:14:12,431 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,432 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,432 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,433 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,434 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:12,435 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,435 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,436 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,437 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,440 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:12,441 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:12,441 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,441 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,447 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:12,448 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,448 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,455 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:12,455 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,456 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,461 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:12,461 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,462 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,467 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:12,468 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,468 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,472 DEBUG [org.geoserver] - Thread 655 releasing the lock in mode WRITE
2016-01-28 10:14:12,472 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:12,473 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:12,474 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:12,474 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,474 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,478 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,479 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:12,480 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:12,480 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,480 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,487 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:12,487 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,488 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,493 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:12,493 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,494 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,502 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:12,503 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,503 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,509 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:12,509 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,510 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,515 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:12,515 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,516 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,522 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:12,523 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,523 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,528 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:12,529 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:12,529 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,529 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,556 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:12,556 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:12,557 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:12,557 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,557 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,557 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,557 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:12,558 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,556 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:12,558 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:12,558 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:12,558 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,558 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:12,559 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:12,558 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,559 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:12,560 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:12,560 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,560 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,560 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,561 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,623 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:12,623 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:12,624 DEBUG [org.geoserver] - Thread 255 locking in mode WRITE
2016-01-28 10:14:12,624 DEBUG [org.geoserver] - Thread 255 got the lock in mode WRITE
2016-01-28 10:14:12,624 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,624 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,626 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,627 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,628 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,629 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,630 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,631 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:12,631 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,631 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,632 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,637 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:12,638 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:12,638 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,638 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,644 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:12,644 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,645 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,650 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:12,650 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,651 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,657 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:12,657 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,658 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,664 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:12,664 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode WRITE
2016-01-28 10:14:12,664 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:12,664 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,665 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,669 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,671 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:12,671 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,672 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,678 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:12,678 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,679 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,686 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:12,686 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,687 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,693 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:12,693 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,693 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,699 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:12,700 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,700 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,706 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:12,706 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,707 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,713 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:12,713 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,714 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,720 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:12,720 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,721 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,730 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:12,730 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:12,731 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:12,731 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,731 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,731 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,732 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:12,732 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,733 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,754 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:12,755 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:12,755 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:12,755 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:12,755 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,756 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,756 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:12,756 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,756 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,757 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,757 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:12,757 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:12,757 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:12,758 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:12,758 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:12,758 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:12,758 DEBUG [org.geoserver] - Thread 255 locking in mode WRITE
2016-01-28 10:14:12,758 DEBUG [org.geoserver] - Thread 255 got the lock in mode WRITE
2016-01-28 10:14:12,759 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,759 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,759 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,761 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,761 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:12,762 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,762 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,762 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,763 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,764 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,765 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,765 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,767 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:12,768 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:12,768 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,768 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,774 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:12,775 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,775 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,779 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:12,780 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:12,780 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,780 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,800 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode WRITE
2016-01-28 10:14:12,800 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:12,805 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,841 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:12,841 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,842 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,854 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:12,855 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,855 DEBUG [org.geoserver] - Thread 255 locking in mode READ
2016-01-28 10:14:12,855 DEBUG [org.geoserver] - Thread 255 got the lock in mode READ
2016-01-28 10:14:12,856 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,856 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,857 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode READ
2016-01-28 10:14:12,857 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,863 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:12,864 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,864 DEBUG [org.geoserver] - Thread 255 locking in mode READ
2016-01-28 10:14:12,864 DEBUG [org.geoserver] - Thread 255 got the lock in mode READ
2016-01-28 10:14:12,865 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,865 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:12,865 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:12,866 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,866 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode READ
2016-01-28 10:14:12,866 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,887 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:12,887 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,888 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,888 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:12,889 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:12,889 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,889 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:12,889 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,889 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,890 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,890 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,891 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:12,891 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:12,892 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:12,892 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:12,892 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,892 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,893 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,898 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:12,898 DEBUG [org.geoserver] - Thread 42 locking in mode WRITE
2016-01-28 10:14:12,898 DEBUG [org.geoserver] - Thread 42 got the lock in mode WRITE
2016-01-28 10:14:12,899 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:12,900 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,900 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,901 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,902 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,903 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,903 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,904 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,905 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,906 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:12,906 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,907 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,937 DEBUG [org.geoserver] - Thread 42 releasing the lock in mode WRITE
2016-01-28 10:14:12,938 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:12,943 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,969 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:12,970 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,970 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,976 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:12,977 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,977 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,982 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:12,983 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:12,983 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,983 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,989 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:12,989 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,990 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:12,996 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:12,996 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:12,997 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,002 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,003 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,003 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,003 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,032 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:13,033 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:13,033 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,034 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:13,034 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:13,034 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:13,035 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,035 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:13,035 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,035 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,035 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,036 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,037 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:13,038 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,038 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,043 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:13,043 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,044 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,046 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:13,046 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:13,047 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:13,047 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:13,047 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,047 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,047 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:13,048 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:13,048 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,048 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:13,048 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:13,049 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:13,049 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,048 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,049 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,049 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,050 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:13,050 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,050 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,051 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,055 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:13,056 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:13,056 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:13,056 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,056 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,057 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,057 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,057 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:13,057 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:13,058 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:13,058 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,058 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,058 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,058 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:13,059 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:13,059 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,059 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,060 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:13,061 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:13,061 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,061 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,063 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:13,063 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,063 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,065 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:13,066 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:13,066 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:13,066 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,066 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,067 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,067 DEBUG [org.geoserver] - Thread 255 locking in mode READ
2016-01-28 10:14:13,067 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:13,067 DEBUG [org.geoserver] - Thread 255 got the lock in mode READ
2016-01-28 10:14:13,067 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:13,068 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:13,068 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,068 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,068 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,067 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,069 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,069 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,069 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,069 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode READ
2016-01-28 10:14:13,070 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,070 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,070 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,070 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,071 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,071 DEBUG [org.geoserver] - Thread 658 locking in mode READ
2016-01-28 10:14:13,071 DEBUG [org.geoserver] - Thread 658 got the lock in mode READ
2016-01-28 10:14:13,071 DEBUG [org.geoserver] - Thread 397 locking in mode READ
2016-01-28 10:14:13,072 DEBUG [org.geoserver] - Thread 397 got the lock in mode READ
2016-01-28 10:14:13,072 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,072 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,072 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode READ
2016-01-28 10:14:13,072 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,073 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,073 DEBUG [org.geoserver] - Thread 397 releasing the lock in mode READ
2016-01-28 10:14:13,073 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,074 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:13,074 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,075 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,075 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:13,076 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,076 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:13,077 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:13,077 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,077 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:13,077 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,078 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,078 DEBUG [org.geoserver] - Thread 397 locking in mode READ
2016-01-28 10:14:13,078 DEBUG [org.geoserver] - Thread 397 got the lock in mode READ
2016-01-28 10:14:13,078 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,078 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,079 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,079 DEBUG [org.geoserver] - Thread 397 releasing the lock in mode READ
2016-01-28 10:14:13,079 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,082 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:13,083 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,083 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:13,083 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,084 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,084 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:13,084 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:13,084 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,084 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,085 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,085 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,085 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:13,086 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,086 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:13,086 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,087 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,087 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,089 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:13,089 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,090 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,090 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:13,091 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:13,091 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:13,091 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,091 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,091 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,091 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:13,092 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:13,092 DEBUG [org.geoserver] - Thread 654 locking in mode READ
2016-01-28 10:14:13,092 DEBUG [org.geoserver] - Thread 654 got the lock in mode READ
2016-01-28 10:14:13,092 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,092 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,092 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,093 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,093 DEBUG [org.geoserver] - Thread 654 releasing the lock in mode READ
2016-01-28 10:14:13,093 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,165 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:13,166 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:13,166 DEBUG [org.geoserver] - Thread 654 locking in mode WRITE
2016-01-28 10:14:13,166 DEBUG [org.geoserver] - Thread 654 got the lock in mode WRITE
2016-01-28 10:14:13,169 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,169 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,171 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,171 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,172 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,173 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:13,173 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,174 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:13,174 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,175 DEBUG [org.geoserver] - Thread 398 locking in mode READ
2016-01-28 10:14:13,207 DEBUG [org.geoserver] - Thread 654 releasing the lock in mode WRITE
2016-01-28 10:14:13,207 DEBUG [org.geoserver] - Thread 398 got the lock in mode READ
2016-01-28 10:14:13,207 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:13,208 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,209 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:13,209 DEBUG [org.geoserver] - Thread 398 releasing the lock in mode READ
2016-01-28 10:14:13,209 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,213 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,300 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:13,301 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:13,301 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,301 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,302 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:13,303 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,303 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,303 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:13,304 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:13,304 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:13,304 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:13,304 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,305 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,305 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,304 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:13,305 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:13,305 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,305 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,306 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,307 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,315 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:13,315 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:13,316 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:13,316 DEBUG [org.geoserver] - Thread 655 locking in mode WRITE
2016-01-28 10:14:13,316 DEBUG [org.geoserver] - Thread 655 got the lock in mode WRITE
2016-01-28 10:14:13,316 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,317 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,318 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,319 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,320 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,321 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,322 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,323 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,323 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:13,323 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,324 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,329 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:13,330 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,330 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,335 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:13,335 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,336 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,342 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:13,342 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,343 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,359 DEBUG [org.geoserver] - Thread 655 releasing the lock in mode WRITE
2016-01-28 10:14:13,359 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:13,365 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,404 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:13,404 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,405 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,410 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:13,411 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,411 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,454 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:13,455 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,455 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,457 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:13,457 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,458 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,458 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,459 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,459 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:13,459 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,459 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,460 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,460 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:13,460 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,461 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,461 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,461 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,461 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,462 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,516 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:13,517 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,517 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,519 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:13,520 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,520 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:13,520 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:13,520 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,520 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,521 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:13,521 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,521 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,522 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:13,522 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,522 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,523 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,525 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:13,526 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:13,526 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,526 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,527 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:13,527 DEBUG [org.geoserver] - Thread 658 locking in mode WRITE
2016-01-28 10:14:13,528 DEBUG [org.geoserver] - Thread 658 got the lock in mode WRITE
2016-01-28 10:14:13,530 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,531 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,532 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:13,532 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,532 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,533 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,533 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,534 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,535 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,539 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:13,540 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:13,540 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,540 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,546 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:13,546 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,547 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,571 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode WRITE
2016-01-28 10:14:13,571 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:13,576 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,605 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:13,606 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,606 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,620 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:13,621 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:13,621 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,621 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,626 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:13,626 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,627 DEBUG [org.geoserver] - Thread 658 locking in mode READ
2016-01-28 10:14:13,627 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:13,627 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:13,628 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:13,628 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:13,627 DEBUG [org.geoserver] - Thread 658 got the lock in mode READ
2016-01-28 10:14:13,628 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:13,628 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,629 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,629 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,629 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,630 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,630 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,630 DEBUG [org.geoserver] - Thread 660 locking in mode READ
2016-01-28 10:14:13,630 DEBUG [org.geoserver] - Thread 660 got the lock in mode READ
2016-01-28 10:14:13,630 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,631 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,631 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode READ
2016-01-28 10:14:13,631 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,632 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,632 DEBUG [org.geoserver] - Thread 660 releasing the lock in mode READ
2016-01-28 10:14:13,633 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,633 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:13,634 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,634 DEBUG [org.geoserver] - Thread 660 locking in mode READ
2016-01-28 10:14:13,634 DEBUG [org.geoserver] - Thread 660 got the lock in mode READ
2016-01-28 10:14:13,634 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:13,635 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:13,635 DEBUG [org.geoserver] - Thread 658 locking in mode WRITE
2016-01-28 10:14:13,635 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,636 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:13,636 DEBUG [org.geoserver] - Thread 660 releasing the lock in mode READ
2016-01-28 10:14:13,636 DEBUG [org.geoserver] - Thread 658 got the lock in mode WRITE
2016-01-28 10:14:13,636 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,637 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:13,637 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,638 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,639 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,640 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,640 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:13,640 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:13,641 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,641 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:13,642 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,642 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:13,642 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,642 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,642 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,643 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,643 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,644 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,644 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,651 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:13,652 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:13,652 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,652 DEBUG [org.geoserver] - Thread 655 locking in mode READ
2016-01-28 10:14:13,653 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:13,654 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:13,654 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,655 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,661 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:13,662 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,662 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:13,662 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,662 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,663 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,663 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,663 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,663 DEBUG [org.geoserver] - Thread 397 locking in mode READ
2016-01-28 10:14:13,663 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,667 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:13,667 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:13,668 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:13,668 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,668 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:13,668 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,667 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,669 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,669 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,670 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,673 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:13,674 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,674 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,675 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:13,675 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,675 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:13,676 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,676 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:13,676 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,677 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,682 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,682 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,683 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode WRITE
2016-01-28 10:14:13,683 DEBUG [org.geoserver] - Thread 254 locking in mode READ
2016-01-28 10:14:13,683 DEBUG [org.geoserver] - Thread 397 got the lock in mode READ
2016-01-28 10:14:13,683 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:13,683 DEBUG [org.geoserver] - Thread 254 got the lock in mode READ
2016-01-28 10:14:13,683 DEBUG [org.geoserver] - Thread 655 got the lock in mode READ
2016-01-28 10:14:13,683 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,684 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,684 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,685 DEBUG [org.geoserver] - Thread 397 releasing the lock in mode READ
2016-01-28 10:14:13,685 DEBUG [org.geoserver] - Thread 254 releasing the lock in mode READ
2016-01-28 10:14:13,685 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,685 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,685 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:13,686 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:13,686 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,686 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,686 DEBUG [org.geoserver] - Thread 655 releasing the lock in mode READ
2016-01-28 10:14:13,686 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,687 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:13,687 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,687 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,688 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,689 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,750 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:13,750 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:13,751 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,751 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:13,751 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,751 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:13,751 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,752 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,752 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,752 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,753 DEBUG [org.geoserver] - Thread 654 locking in mode READ
2016-01-28 10:14:13,753 DEBUG [org.geoserver] - Thread 654 got the lock in mode READ
2016-01-28 10:14:13,753 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,754 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,754 DEBUG [org.geoserver] - Thread 654 releasing the lock in mode READ
2016-01-28 10:14:13,754 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,782 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:13,782 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,783 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:13,784 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,784 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,785 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,790 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:13,791 DEBUG [org.geoserver] - Thread 397 locking in mode WRITE
2016-01-28 10:14:13,791 DEBUG [org.geoserver] - Thread 397 got the lock in mode WRITE
2016-01-28 10:14:13,791 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:13,792 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,792 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:13,793 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:13,792 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,793 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,793 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,793 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:13,794 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:13,794 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,793 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:13,794 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:13,794 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,794 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,795 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,795 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,795 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,796 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,797 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,798 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,803 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:13,803 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,804 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,810 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:13,811 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,811 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,817 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:13,818 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:13,818 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,818 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,823 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:13,824 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:13,824 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,824 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,829 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:13,830 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:13,830 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,830 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,833 DEBUG [org.geoserver] - Thread 397 releasing the lock in mode WRITE
2016-01-28 10:14:13,833 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:13,835 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:13,836 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:13,837 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:13,837 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,838 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,843 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,845 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:13,845 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,846 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,852 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:13,853 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,853 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,859 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:13,859 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,860 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,866 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:13,867 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,867 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,872 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:13,872 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,873 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,877 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:13,878 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,878 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,883 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:13,884 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:13,884 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,884 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,889 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:13,889 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,890 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,896 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:13,896 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,897 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,901 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:13,902 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:13,902 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,903 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:13,903 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:13,903 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:13,903 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,904 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:13,904 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,904 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:13,904 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:13,904 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,904 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,905 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,905 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,905 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:13,905 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:13,906 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:13,906 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,906 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,906 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,911 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:13,912 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,912 DEBUG [org.geoserver] - Thread 660 locking in mode READ
2016-01-28 10:14:13,912 DEBUG [org.geoserver] - Thread 660 got the lock in mode READ
2016-01-28 10:14:13,913 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,913 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,914 DEBUG [org.geoserver] - Thread 660 releasing the lock in mode READ
2016-01-28 10:14:13,914 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,914 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:13,914 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:13,915 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,914 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:13,915 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:13,915 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:13,915 DEBUG [org.geoserver] - Thread 658 locking in mode READ
2016-01-28 10:14:13,915 DEBUG [org.geoserver] - Thread 658 got the lock in mode READ
2016-01-28 10:14:13,915 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,916 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,916 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,916 DEBUG [org.geoserver] - Thread 398 locking in mode READ
2016-01-28 10:14:13,916 DEBUG [org.geoserver] - Thread 398 got the lock in mode READ
2016-01-28 10:14:13,916 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,916 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,916 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,916 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode READ
2016-01-28 10:14:13,917 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,917 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:13,917 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,917 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,918 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:13,918 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:13,918 DEBUG [org.geoserver] - Thread 398 releasing the lock in mode READ
2016-01-28 10:14:13,918 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,918 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,919 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,919 DEBUG [org.geoserver] - Thread 655 locking in mode READ
2016-01-28 10:14:13,919 DEBUG [org.geoserver] - Thread 655 got the lock in mode READ
2016-01-28 10:14:13,919 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,919 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,920 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,920 DEBUG [org.geoserver] - Thread 655 releasing the lock in mode READ
2016-01-28 10:14:13,920 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,942 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:13,942 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:13,943 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:13,942 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:13,943 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:13,943 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,944 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,944 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,944 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,945 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:13,945 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,946 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,947 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:13,947 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,948 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,951 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:13,952 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,952 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,954 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:13,955 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,955 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:13,955 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:13,955 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,955 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,956 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:13,956 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,956 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,956 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:13,957 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:13,957 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,957 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,958 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:13,958 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:13,959 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,959 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,959 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,960 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:13,961 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:13,961 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:13,961 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,961 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,962 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,962 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:13,962 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,963 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:13,963 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:13,963 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,964 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,964 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,965 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:13,966 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:13,968 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:13,968 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:13,968 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:13,968 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:13,968 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,969 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:13,969 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:13,969 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,969 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:13,969 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:13,970 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,970 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:13,970 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,970 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,970 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:13,970 DEBUG [org.geoserver] - Thread 255 locking in mode READ
2016-01-28 10:14:13,971 DEBUG [org.geoserver] - Thread 255 got the lock in mode READ
2016-01-28 10:14:13,971 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,971 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,971 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,971 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,971 DEBUG [org.geoserver] - Thread 42 locking in mode READ
2016-01-28 10:14:13,971 DEBUG [org.geoserver] - Thread 42 got the lock in mode READ
2016-01-28 10:14:13,972 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:13,972 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:13,972 DEBUG [org.geoserver] - Thread 255 releasing the lock in mode READ
2016-01-28 10:14:13,972 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:13,973 DEBUG [org.geoserver] - Thread 42 releasing the lock in mode READ
2016-01-28 10:14:13,973 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,030 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:14,031 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:14,031 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:14,031 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,031 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:14,031 DEBUG [org.geoserver] - Thread 654 locking in mode READ
2016-01-28 10:14:14,031 DEBUG [org.geoserver] - Thread 654 got the lock in mode READ
2016-01-28 10:14:14,032 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,032 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,032 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,032 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,033 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:14,033 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,033 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:14,033 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,034 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,035 DEBUG [org.geoserver] - Thread 660 locking in mode READ
2016-01-28 10:14:14,035 DEBUG [org.geoserver] - Thread 660 got the lock in mode READ
2016-01-28 10:14:14,035 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,036 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:14,036 DEBUG [org.geoserver] - Thread 660 releasing the lock in mode READ
2016-01-28 10:14:14,036 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,033 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,037 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,037 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,037 DEBUG [org.geoserver] - Thread 649 locking in mode READ
2016-01-28 10:14:14,039 DEBUG [org.geoserver] - Thread 649 got the lock in mode READ
2016-01-28 10:14:14,039 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,034 DEBUG [org.geoserver] - Thread 654 releasing the lock in mode READ
2016-01-28 10:14:14,039 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,039 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:14,040 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:14,040 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:14,041 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:14,041 DEBUG [org.geoserver] - Thread 649 releasing the lock in mode READ
2016-01-28 10:14:14,041 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,041 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:14,041 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,042 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,042 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,042 DEBUG [org.geoserver] - Thread 32 locking in mode READ
2016-01-28 10:14:14,042 DEBUG [org.geoserver] - Thread 32 got the lock in mode READ
2016-01-28 10:14:14,043 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,044 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:14,045 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:14,045 DEBUG [org.geoserver] - Thread 32 releasing the lock in mode READ
2016-01-28 10:14:14,045 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,045 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:14,046 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:14,046 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,046 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,047 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,048 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:14,049 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,049 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,050 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:14,050 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,050 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:14,051 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:14,051 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,051 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,054 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:14,055 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,055 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,056 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:14,056 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:14,057 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:14,057 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,057 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,057 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,058 DEBUG [org.geoserver] - Thread 657 locking in mode READ
2016-01-28 10:14:14,058 DEBUG [org.geoserver] - Thread 657 got the lock in mode READ
2016-01-28 10:14:14,058 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,059 DEBUG [geoserver.filters] - Compressing output for mimetype: text/css;charset=UTF-8
2016-01-28 10:14:14,059 DEBUG [org.geoserver] - Thread 657 releasing the lock in mode READ
2016-01-28 10:14:14,059 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,075 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:14,075 DEBUG [org.geoserver] - Thread 657 locking in mode WRITE
2016-01-28 10:14:14,075 DEBUG [org.geoserver] - Thread 657 got the lock in mode WRITE
2016-01-28 10:14:14,078 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,079 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,080 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,080 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,081 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,082 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,116 DEBUG [org.geoserver] - Thread 657 releasing the lock in mode WRITE
2016-01-28 10:14:14,116 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:14,121 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,217 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:14,218 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,218 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,219 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:14,219 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:14,219 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,220 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,220 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,220 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:14,221 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:14,221 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:14,221 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,221 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,221 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:14,222 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,222 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:14,222 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,222 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,223 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,231 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:14,231 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:14,232 DEBUG [org.geoserver] - Thread 657 locking in mode WRITE
2016-01-28 10:14:14,232 DEBUG [org.geoserver] - Thread 657 got the lock in mode WRITE
2016-01-28 10:14:14,232 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,232 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,234 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,235 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,236 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,237 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,238 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,239 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,249 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:14,250 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,250 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,255 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:14,256 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,256 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,261 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,262 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,262 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,267 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:14,267 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,268 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,272 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:14,273 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:14,273 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,274 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,275 DEBUG [org.geoserver] - Thread 657 releasing the lock in mode WRITE
2016-01-28 10:14:14,275 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:14,278 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:14,279 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:14,279 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,279 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,280 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,284 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:14,285 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,285 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,290 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:14,290 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,291 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,295 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:14,296 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:14,296 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,296 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,302 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:14,303 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,303 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,308 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:14,308 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,309 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,313 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:14,314 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,314 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,319 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:14,319 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,320 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,325 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:14,326 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,326 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,331 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:14,332 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,332 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,338 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:14,338 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,339 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,339 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,339 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:14,340 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:14,340 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,340 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:14,340 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,340 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,340 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:14,339 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,341 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,341 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,342 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,342 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:14,343 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,343 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,343 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,425 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:14,425 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:14,426 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,426 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,427 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:14,427 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:14,427 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,427 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,427 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:14,428 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:14,428 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:14,428 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:14,428 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,429 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,429 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,429 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,429 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,430 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,437 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:14,437 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:14,438 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,438 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:14,438 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:14,437 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,438 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,439 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:14,440 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:14,439 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:14,440 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,440 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,441 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,441 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:14,441 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,442 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,439 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:14,438 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,442 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:14,443 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,442 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,443 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,443 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,444 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,444 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,451 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:14,451 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:14,452 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:14,452 DEBUG [org.geoserver] - Thread 32 locking in mode WRITE
2016-01-28 10:14:14,452 DEBUG [org.geoserver] - Thread 32 got the lock in mode WRITE
2016-01-28 10:14:14,452 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,452 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,455 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,456 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,457 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,458 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:14,458 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,458 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,459 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,459 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,460 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,467 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:14,467 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,468 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,473 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:14,473 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,474 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,478 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:14,479 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,479 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,485 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:14,486 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,486 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,491 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:14,491 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,492 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,497 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:14,497 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,498 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,500 DEBUG [org.geoserver] - Thread 32 releasing the lock in mode WRITE
2016-01-28 10:14:14,500 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:14,503 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:14,503 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,504 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,506 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,509 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:14,510 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,510 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,515 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,516 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,516 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,516 DEBUG [org.geoserver] - Thread 32 locking in mode READ
2016-01-28 10:14:14,517 DEBUG [org.geoserver] - Thread 32 got the lock in mode READ
2016-01-28 10:14:14,517 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,517 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:14,518 DEBUG [org.geoserver] - Thread 32 releasing the lock in mode READ
2016-01-28 10:14:14,518 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,525 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:14,526 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,526 DEBUG [org.geoserver] - Thread 32 locking in mode READ
2016-01-28 10:14:14,526 DEBUG [org.geoserver] - Thread 32 got the lock in mode READ
2016-01-28 10:14:14,527 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,527 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:14,528 DEBUG [org.geoserver] - Thread 32 releasing the lock in mode READ
2016-01-28 10:14:14,528 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,534 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:14,535 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:14,535 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,536 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,540 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:14,541 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:14,541 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,541 DEBUG [org.geoserver] - Thread 654 locking in mode READ
2016-01-28 10:14:14,542 DEBUG [org.geoserver] - Thread 654 got the lock in mode READ
2016-01-28 10:14:14,542 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,542 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:14,543 DEBUG [org.geoserver] - Thread 654 releasing the lock in mode READ
2016-01-28 10:14:14,543 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,549 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:14,550 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:14,550 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,551 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,556 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:14,557 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,557 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,562 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:14,563 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,563 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,583 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:14,583 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,584 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,585 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:14,585 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:14,585 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:14,586 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:14,586 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,586 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,587 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,587 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,587 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:14,588 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,588 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,589 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:14,590 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,590 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,595 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:14,595 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,596 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:14,596 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,596 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:14,596 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:14,597 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,597 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:14,596 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,597 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,598 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:14,598 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,599 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,599 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,598 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,598 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,597 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,599 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,600 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,600 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,600 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,602 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:14,602 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,603 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,605 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:14,606 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:14,606 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:14,606 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,606 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,607 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,607 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,608 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:14,609 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,609 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,610 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:14,610 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:14,610 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,611 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:14,611 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,611 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,612 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,623 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:14,624 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:14,623 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:14,624 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:14,625 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,625 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,625 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,626 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:14,626 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:14,627 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,627 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,627 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,628 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:14,628 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,629 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,629 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,630 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,630 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,630 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,631 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:14,631 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,632 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,632 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:14,633 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,633 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:14,633 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,633 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:14,634 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2016-01-28 10:14:14,634 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,634 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,634 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,635 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,635 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:14,636 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/print.css]
2016-01-28 10:14:14,636 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,637 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,637 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,638 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:14,639 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,639 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,639 DEBUG [org.geoserver] - Thread 398 locking in mode READ
2016-01-28 10:14:14,639 DEBUG [org.geoserver] - Thread 398 got the lock in mode READ
2016-01-28 10:14:14,639 DEBUG [org.geoserver] - Thread 32 locking in mode READ
2016-01-28 10:14:14,639 DEBUG [org.geoserver] - Thread 32 got the lock in mode READ
2016-01-28 10:14:14,640 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,640 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:14,640 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:14,640 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,640 DEBUG [org.geoserver] - Thread 398 releasing the lock in mode READ
2016-01-28 10:14:14,641 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,641 DEBUG [org.geoserver] - Thread 32 releasing the lock in mode READ
2016-01-28 10:14:14,641 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:14,641 DEBUG [org.geoserver] - Thread 658 locking in mode READ
2016-01-28 10:14:14,641 DEBUG [org.geoserver] - Thread 658 got the lock in mode READ
2016-01-28 10:14:14,641 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:14,641 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,641 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,642 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:14,642 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,642 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,642 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:14,642 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode READ
2016-01-28 10:14:14,643 DEBUG [org.geoserver] - Thread 32 locking in mode READ
2016-01-28 10:14:14,643 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,643 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2016-01-28 10:14:14,643 DEBUG [org.geoserver] - Thread 32 got the lock in mode READ
2016-01-28 10:14:14,643 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,643 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,644 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2016-01-28 10:14:14,644 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,644 DEBUG [org.geoserver] - Thread 32 releasing the lock in mode READ
2016-01-28 10:14:14,649 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.UserGroupRoleServicesPage/img/icons/silk/group.png]
2016-01-28 10:14:14,649 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/group.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,650 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,650 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.data.DataSecurityPage/null/img/icons/silk/database_key.png]
2016-01-28 10:14:14,651 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAccessRulePage/server_key.png]
2016-01-28 10:14:14,651 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/database_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,651 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,651 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:14,652 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2016-01-28 10:14:14,652 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,652 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,700 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:14,700 DEBUG [org.geoserver] - Thread 658 locking in mode WRITE
2016-01-28 10:14:14,700 DEBUG [org.geoserver] - Thread 658 got the lock in mode WRITE
2016-01-28 10:14:14,703 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,704 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,705 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,706 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,707 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,707 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,723 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:14,723 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,724 DEBUG [org.geoserver] - Thread 398 locking in mode READ
2016-01-28 10:14:14,742 DEBUG [org.geoserver] - Thread 658 releasing the lock in mode WRITE
2016-01-28 10:14:14,742 DEBUG [org.geoserver] - Thread 398 got the lock in mode READ
2016-01-28 10:14:14,742 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:14,743 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,743 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:14,744 DEBUG [org.geoserver] - Thread 398 releasing the lock in mode READ
2016-01-28 10:14:14,744 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,748 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,797 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:14,798 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
2016-01-28 10:14:14,798 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,799 DEBUG [org.geoserver] - Thread 398 locking in mode READ
2016-01-28 10:14:14,799 DEBUG [org.geoserver] - Thread 398 got the lock in mode READ
2016-01-28 10:14:14,799 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2016-01-28 10:14:14,799 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/favicon.ico to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,799 DEBUG [org.geoserver] - Thread 42 locking in mode WRITE
2016-01-28 10:14:14,800 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/x-icon
2016-01-28 10:14:14,800 DEBUG [org.geoserver] - Thread 398 releasing the lock in mode READ
2016-01-28 10:14:14,800 DEBUG [org.geoserver] - Thread 42 got the lock in mode WRITE
2016-01-28 10:14:14,800 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,803 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,804 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/print.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,804 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,805 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/ie.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,806 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,807 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,843 DEBUG [org.geoserver] - Thread 42 releasing the lock in mode WRITE
2016-01-28 10:14:14,843 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2016-01-28 10:14:14,848 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,961 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:14,961 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:14,962 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css]
2016-01-28 10:14:14,962 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:14,963 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:14,962 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:14,963 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/css/blueprint/screen.css]
2016-01-28 10:14:14,963 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:14,963 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/blueprint/screen.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,963 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:14,964 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery-1.2.6.min.js]
2016-01-28 10:14:14,964 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/mappreview_keyshortcut.js]
2016-01-28 10:14:14,964 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,964 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-demo-2.7.4.jar!/org/geoserver/web/demo/mappreview_keyshortcut.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,965 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/js/jquery.inline-info.js]
2016-01-28 10:14:14,963 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/css/geoserver.css to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,965 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,966 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery.inline-info.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,966 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/js/jquery-1.2.6.min.js to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,966 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:14,966 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,967 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.StatusPage/null/img/icons/silk/server_error.png]
2016-01-28 10:14:14,967 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,967 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server_error.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,968 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,974 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:14,975 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.ContactPage/null/img/icons/silk/vcard.png]
2016-01-28 10:14:14,975 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.LogPage/null/img/icons/silk/page_white_text.png]
2016-01-28 10:14:14,975 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:14,975 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/vcard.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,976 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/page_white_text.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,976 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.AboutGeoServerPage/img/icons/silk/help.png]
2016-01-28 10:14:14,976 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,976 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,976 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/help.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,976 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:14,977 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.ProcessStatusPage/null/null/web/img/icons/silk/cog.png]
2016-01-28 10:14:14,977 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.demo.MapPreviewPage/null/img/icons/geosilk/map.png]
2016-01-28 10:14:14,977 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,977 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.importer.web.ImportDataPage/map_add.png]
2016-01-28 10:14:14,977 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/geosilk/map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,977 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,978 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-importer-web-2.7.4.jar!/org/geoserver/importer/web/map_add.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,978 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,979 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,984 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.workspace.WorkspacePage/null/null/img/icons/silk/folder.png]
2016-01-28 10:14:14,985 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.store.StorePage/null/null/img/icons/silk/database.png]
2016-01-28 10:14:14,986 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/database.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,986 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,986 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/folder.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,987 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:14,988 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layer.LayerPage/null/null/img/icons/silk/picture_empty.png]
2016-01-28 10:14:14,988 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:14,988 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:14,988 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/picture_empty.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,988 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,989 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wcs.web.WCSAdminPage/server_raster.png]
2016-01-28 10:14:14,989 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.data.StylePage/palette.png]
2016-01-28 10:14:14,989 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,989 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/data/palette.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,989 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.data.layergroup.LayerGroupPage/null/null/img/icons/silk/layers.png]
2016-01-28 10:14:14,990 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,990 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/layers.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,990 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wcs-2.7.4.jar!/org/geoserver/wcs/web/server_raster.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,992 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wfs.web.WFSAdminPage/server_vector.png]
2016-01-28 10:14:14,992 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wfs-2.7.4.jar!/org/geoserver/wfs/web/server_vector.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,993 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,996 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wps.web.WPSAdminPage/server_gear.png]
2016-01-28 10:14:14,996 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.GlobalSettingsPage/null/img/icons/silk/server.png]
2016-01-28 10:14:14,996 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wps-2.7.4.jar!/org/geoserver/wps/web/server_gear.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,996 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/server.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,997 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,998 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.JAIPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:14,999 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.layer.CachedLayersPage/null/tilelayer.png]
2016-01-28 10:14:14,999 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:14,999 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:14,999 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/tilelayer.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:15,000 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:15,001 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.wms.web.WMSAdminPage/server_map.png]
2016-01-28 10:14:15,001 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-wms-2.7.4.jar!/org/geoserver/wms/web/server_map.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:15,001 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:15,002 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.admin.CoverageAccessPage/null/img/icons/silk/cog_photo.png]
2016-01-28 10:14:15,002 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:15,002 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.GWCSettingsPage/geowebcache-16.png]
2016-01-28 10:14:15,003 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/geowebcache-16.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:15,003 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/cog_photo.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:15,003 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:15,004 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:15,005 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.gridset.GridSetsPage/null/gridset.png]
2016-01-28 10:14:15,005 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/gridset.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:15,005 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.gwc.web.diskquota.DiskQuotaSettingsPage/null/diskquota.png]
2016-01-28 10:14:15,005 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:15,006 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RepositoriesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:15,006 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-gwc-2.7.4.jar!/org/geoserver/gwc/web/diskquota.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:15,006 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:15,006 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:15,007 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:15,010 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/icons/silk/wrench.png]
2016-01-28 10:14:15,010 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-core-2.7.4.jar!/org/geoserver/web/img/icons/silk/wrench.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:15,011 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geogig.geoserver.web.RemotesPage/geogig_16x16_darkblue.png]
2016-01-28 10:14:15,011 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2016-01-28 10:14:15,011 DEBUG [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.auth.AuthenticationPage/null/img/icons/silk/shield.png]
2016-01-28 10:14:15,012 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-web-sec-core-2.7.4.jar!/org/geoserver/security/web/img/icons/silk/shield.png to file (URI is not hierarchical), falling back to the inputstream for polling
2016-01-28 10:14:15,012 DEBUG [geoserver.web] - cannot convert url: jar:file:/usr/share/geoserver/WEB-INF/lib/gs-geogig-2.7-SNAPSHOT-shaded-plugin.jar!/org/geogig/geoserver/web/geogig_16x16_darkblue.png to file (URI is not hierarchical),
