[GeoNode-users] Getting internal server error when trying to access layer page
Daniel Victoria
daniel.victoria at gmail.com
Tue Jul 19 11:04:14 PDT 2016
Hi list,
I just noticed that 2 layers in my GeoNode server gives my an internal
server error (status 500) when I try to see the layer page
(layers/geonode%3Alayer_name_here).
The layers were uploaded using geonode shell and I can see it fine in
GeoServer layer preview. I can also create a new map and add the faulty
layer to it.
I can see the layer information in the GeoNode Admin panel and when I try
to delete it, I get the status 500 error again.
I tried looking at the apache error log but I could not figure out what was
wrong. So I attached the part of the error that happened the minute I tryed
to load the layer. Any idea what's wrong?
I'm running GeoNode 2.4 on Ubuntu, installed via apt-get
Thanks
Daniel
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160719/f691a5ac/attachment-0001.html>
[Tue Jul 19 12:57:42.405619 2016] [:error] [pid 7947:tid 140651645970176] Internal Server Error: /layers/geonode:jam_a03_2013_plotsubplot_location
[Tue Jul 19 12:57:42.405702 2016] [:error] [pid 7947:tid 140651645970176] Traceback (most recent call last):
[Tue Jul 19 12:57:42.405718 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112, in get_response
[Tue Jul 19 12:57:42.405732 2016] [:error] [pid 7947:tid 140651645970176] response = wrapped_callback(request, *callback_args, **callback_kwargs)
[Tue Jul 19 12:57:42.405746 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py", line 290, in layer_detail
[Tue Jul 19 12:57:42.405759 2016] [:error] [pid 7947:tid 140651645970176] return render_to_response(template, RequestContext(request, context_dict))
[Tue Jul 19 12:57:42.405772 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/shortcuts/__init__.py", line 29, in render_to_response
[Tue Jul 19 12:57:42.405786 2016] [:error] [pid 7947:tid 140651645970176] return HttpResponse(loader.render_to_string(*args, **kwargs), **httpresponse_kwargs)
[Tue Jul 19 12:57:42.405799 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 164, in render_to_string
[Tue Jul 19 12:57:42.405812 2016] [:error] [pid 7947:tid 140651645970176] return t.render(Context(dictionary))
[Tue Jul 19 12:57:42.405824 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140, in render
[Tue Jul 19 12:57:42.405837 2016] [:error] [pid 7947:tid 140651645970176] return self._render(context)
[Tue Jul 19 12:57:42.405849 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Tue Jul 19 12:57:42.405862 2016] [:error] [pid 7947:tid 140651645970176] return self.nodelist.render(context)
[Tue Jul 19 12:57:42.405875 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.405887 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.405900 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.405913 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.405925 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 123, in render
[Tue Jul 19 12:57:42.405961 2016] [:error] [pid 7947:tid 140651645970176] return compiled_parent._render(context)
[Tue Jul 19 12:57:42.405975 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Tue Jul 19 12:57:42.405988 2016] [:error] [pid 7947:tid 140651645970176] return self.nodelist.render(context)
[Tue Jul 19 12:57:42.406000 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.406012 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.406024 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.406036 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.406048 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 123, in render
[Tue Jul 19 12:57:42.406060 2016] [:error] [pid 7947:tid 140651645970176] return compiled_parent._render(context)
[Tue Jul 19 12:57:42.406072 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Tue Jul 19 12:57:42.406084 2016] [:error] [pid 7947:tid 140651645970176] return self.nodelist.render(context)
[Tue Jul 19 12:57:42.406096 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.406108 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.406119 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.406132 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.406143 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 123, in render
[Tue Jul 19 12:57:42.406156 2016] [:error] [pid 7947:tid 140651645970176] return compiled_parent._render(context)
[Tue Jul 19 12:57:42.406168 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Tue Jul 19 12:57:42.406180 2016] [:error] [pid 7947:tid 140651645970176] return self.nodelist.render(context)
[Tue Jul 19 12:57:42.406192 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.406204 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.406215 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.406228 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.406240 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 62, in render
[Tue Jul 19 12:57:42.406252 2016] [:error] [pid 7947:tid 140651645970176] result = block.nodelist.render(context)
[Tue Jul 19 12:57:42.406264 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.406276 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.406288 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.406300 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.406322 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 62, in render
[Tue Jul 19 12:57:42.406335 2016] [:error] [pid 7947:tid 140651645970176] result = block.nodelist.render(context)
[Tue Jul 19 12:57:42.406347 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.406360 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.406371 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.406383 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.406394 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/defaulttags.py", line 298, in render
[Tue Jul 19 12:57:42.406406 2016] [:error] [pid 7947:tid 140651645970176] match = condition.eval(context)
[Tue Jul 19 12:57:42.406418 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/defaulttags.py", line 867, in eval
[Tue Jul 19 12:57:42.406430 2016] [:error] [pid 7947:tid 140651645970176] return self.value.resolve(context, ignore_failures=True)
[Tue Jul 19 12:57:42.406442 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 585, in resolve
[Tue Jul 19 12:57:42.406454 2016] [:error] [pid 7947:tid 140651645970176] obj = self.var.resolve(context)
[Tue Jul 19 12:57:42.406465 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 735, in resolve
[Tue Jul 19 12:57:42.406477 2016] [:error] [pid 7947:tid 140651645970176] value = self._resolve_lookup(context)
[Tue Jul 19 12:57:42.406489 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 789, in _resolve_lookup
[Tue Jul 19 12:57:42.406501 2016] [:error] [pid 7947:tid 140651645970176] current = current()
[Tue Jul 19 12:57:42.406513 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/local/lib/python2.7/dist-packages/geonode/base/models.py", line 509, in get_legend
[Tue Jul 19 12:57:42.406525 2016] [:error] [pid 7947:tid 140651645970176] legends_link = self.link_set.get(name='Legend')
[Tue Jul 19 12:57:42.406537 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/db/models/manager.py", line 151, in get
[Tue Jul 19 12:57:42.406549 2016] [:error] [pid 7947:tid 140651645970176] return self.get_queryset().get(*args, **kwargs)
[Tue Jul 19 12:57:42.406561 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/db/models/query.py", line 313, in get
[Tue Jul 19 12:57:42.406573 2016] [:error] [pid 7947:tid 140651645970176] (self.model._meta.object_name, num))
[Tue Jul 19 12:57:42.406584 2016] [:error] [pid 7947:tid 140651645970176] MultipleObjectsReturned: get() returned more than one Link -- it returned 2!
[Tue Jul 19 12:57:42.406713 2016] [:error] [pid 7947:tid 140651645970176] ERROR:django.request:Internal Server Error: /layers/geonode:jam_a03_2013_plotsubplot_location
[Tue Jul 19 12:57:42.406736 2016] [:error] [pid 7947:tid 140651645970176] Traceback (most recent call last):
[Tue Jul 19 12:57:42.406748 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112, in get_response
[Tue Jul 19 12:57:42.406761 2016] [:error] [pid 7947:tid 140651645970176] response = wrapped_callback(request, *callback_args, **callback_kwargs)
[Tue Jul 19 12:57:42.406774 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py", line 290, in layer_detail
[Tue Jul 19 12:57:42.406787 2016] [:error] [pid 7947:tid 140651645970176] return render_to_response(template, RequestContext(request, context_dict))
[Tue Jul 19 12:57:42.406811 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/shortcuts/__init__.py", line 29, in render_to_response
[Tue Jul 19 12:57:42.406825 2016] [:error] [pid 7947:tid 140651645970176] return HttpResponse(loader.render_to_string(*args, **kwargs), **httpresponse_kwargs)
[Tue Jul 19 12:57:42.406837 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 164, in render_to_string
[Tue Jul 19 12:57:42.406850 2016] [:error] [pid 7947:tid 140651645970176] return t.render(Context(dictionary))
[Tue Jul 19 12:57:42.406862 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140, in render
[Tue Jul 19 12:57:42.406874 2016] [:error] [pid 7947:tid 140651645970176] return self._render(context)
[Tue Jul 19 12:57:42.406886 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Tue Jul 19 12:57:42.406898 2016] [:error] [pid 7947:tid 140651645970176] return self.nodelist.render(context)
[Tue Jul 19 12:57:42.406910 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.406922 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.406934 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.406946 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.406958 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 123, in render
[Tue Jul 19 12:57:42.406970 2016] [:error] [pid 7947:tid 140651645970176] return compiled_parent._render(context)
[Tue Jul 19 12:57:42.406982 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Tue Jul 19 12:57:42.406994 2016] [:error] [pid 7947:tid 140651645970176] return self.nodelist.render(context)
[Tue Jul 19 12:57:42.407005 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.407018 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.407032 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.407053 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.407072 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 123, in render
[Tue Jul 19 12:57:42.407093 2016] [:error] [pid 7947:tid 140651645970176] return compiled_parent._render(context)
[Tue Jul 19 12:57:42.407112 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Tue Jul 19 12:57:42.407132 2016] [:error] [pid 7947:tid 140651645970176] return self.nodelist.render(context)
[Tue Jul 19 12:57:42.407152 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.407167 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.407179 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.407191 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.407203 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 123, in render
[Tue Jul 19 12:57:42.407226 2016] [:error] [pid 7947:tid 140651645970176] return compiled_parent._render(context)
[Tue Jul 19 12:57:42.407240 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Tue Jul 19 12:57:42.407252 2016] [:error] [pid 7947:tid 140651645970176] return self.nodelist.render(context)
[Tue Jul 19 12:57:42.407263 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.407275 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.407287 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.407299 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.407311 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 62, in render
[Tue Jul 19 12:57:42.407323 2016] [:error] [pid 7947:tid 140651645970176] result = block.nodelist.render(context)
[Tue Jul 19 12:57:42.407335 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.407347 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.407359 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.407371 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.407383 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 62, in render
[Tue Jul 19 12:57:42.407395 2016] [:error] [pid 7947:tid 140651645970176] result = block.nodelist.render(context)
[Tue Jul 19 12:57:42.407406 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.407418 2016] [:error] [pid 7947:tid 140651645970176] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.407430 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.407442 2016] [:error] [pid 7947:tid 140651645970176] return node.render(context)
[Tue Jul 19 12:57:42.407454 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/defaulttags.py", line 298, in render
[Tue Jul 19 12:57:42.407466 2016] [:error] [pid 7947:tid 140651645970176] match = condition.eval(context)
[Tue Jul 19 12:57:42.407478 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/defaulttags.py", line 867, in eval
[Tue Jul 19 12:57:42.407490 2016] [:error] [pid 7947:tid 140651645970176] return self.value.resolve(context, ignore_failures=True)
[Tue Jul 19 12:57:42.407501 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 585, in resolve
[Tue Jul 19 12:57:42.407513 2016] [:error] [pid 7947:tid 140651645970176] obj = self.var.resolve(context)
[Tue Jul 19 12:57:42.407525 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 735, in resolve
[Tue Jul 19 12:57:42.407537 2016] [:error] [pid 7947:tid 140651645970176] value = self._resolve_lookup(context)
[Tue Jul 19 12:57:42.407549 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 789, in _resolve_lookup
[Tue Jul 19 12:57:42.407561 2016] [:error] [pid 7947:tid 140651645970176] current = current()
[Tue Jul 19 12:57:42.407581 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/local/lib/python2.7/dist-packages/geonode/base/models.py", line 509, in get_legend
[Tue Jul 19 12:57:42.407594 2016] [:error] [pid 7947:tid 140651645970176] legends_link = self.link_set.get(name='Legend')
[Tue Jul 19 12:57:42.407606 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/db/models/manager.py", line 151, in get
[Tue Jul 19 12:57:42.407618 2016] [:error] [pid 7947:tid 140651645970176] return self.get_queryset().get(*args, **kwargs)
[Tue Jul 19 12:57:42.407630 2016] [:error] [pid 7947:tid 140651645970176] File "/usr/lib/python2.7/dist-packages/django/db/models/query.py", line 313, in get
[Tue Jul 19 12:57:42.407642 2016] [:error] [pid 7947:tid 140651645970176] (self.model._meta.object_name, num))
[Tue Jul 19 12:57:42.407653 2016] [:error] [pid 7947:tid 140651645970176] MultipleObjectsReturned: get() returned more than one Link -- it returned 2!
[Tue Jul 19 12:57:42.435500 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] mod_wsgi (pid=7947): Exception occurred processing WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
[Tue Jul 19 12:57:42.435588 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] Traceback (most recent call last):
[Tue Jul 19 12:57:42.435637 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 206, in __call__
[Tue Jul 19 12:57:42.435709 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] response = self.get_response(request)
[Tue Jul 19 12:57:42.435744 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 194, in get_response
[Tue Jul 19 12:57:42.435792 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] response = self.handle_uncaught_exception(request, resolver, sys.exc_info())
[Tue Jul 19 12:57:42.435823 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 236, in handle_uncaught_exception
[Tue Jul 19 12:57:42.435869 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] return callback(request, **param_dict)
[Tue Jul 19 12:57:42.435898 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/utils/decorators.py", line 99, in _wrapped_view
[Tue Jul 19 12:57:42.435942 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] response = view_func(request, *args, **kwargs)
[Tue Jul 19 12:57:42.435971 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/views/defaults.py", line 46, in server_error
[Tue Jul 19 12:57:42.436014 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] return http.HttpResponseServerError(template.render(Context({})))
[Tue Jul 19 12:57:42.436044 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140, in render
[Tue Jul 19 12:57:42.436086 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] return self._render(context)
[Tue Jul 19 12:57:42.436115 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Tue Jul 19 12:57:42.436156 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] return self.nodelist.render(context)
[Tue Jul 19 12:57:42.436185 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.436225 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.436313 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.436366 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] return node.render(context)
[Tue Jul 19 12:57:42.436397 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 53, in render
[Tue Jul 19 12:57:42.436438 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] result = self.nodelist.render(context)
[Tue Jul 19 12:57:42.436467 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.436508 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.436537 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.436577 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] return node.render(context)
[Tue Jul 19 12:57:42.436605 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 155, in render
[Tue Jul 19 12:57:42.436646 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] return self.render_template(self.template, context)
[Tue Jul 19 12:57:42.436675 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 137, in render_template
[Tue Jul 19 12:57:42.436715 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] output = template.render(context)
[Tue Jul 19 12:57:42.436744 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140, in render
[Tue Jul 19 12:57:42.436784 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] return self._render(context)
[Tue Jul 19 12:57:42.436812 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Tue Jul 19 12:57:42.436852 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] return self.nodelist.render(context)
[Tue Jul 19 12:57:42.436880 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Tue Jul 19 12:57:42.436919 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] bit = self.render_node(node, context)
[Tue Jul 19 12:57:42.436947 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Tue Jul 19 12:57:42.436986 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] return node.render(context)
[Tue Jul 19 12:57:42.437015 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/announcements/templatetags/announcements_tags.py", line 24, in render
[Tue Jul 19 12:57:42.437056 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] request = context["request"]
[Tue Jul 19 12:57:42.437085 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] File "/usr/lib/python2.7/dist-packages/django/template/context.py", line 56, in __getitem__
[Tue Jul 19 12:57:42.437126 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] raise KeyError(key)
[Tue Jul 19 12:57:42.437170 2016] [:error] [pid 7947:tid 140651645970176] [remote 10.129.128.11:0] KeyError: 'request'
More information about the geonode-users
