[GeoNode-users] creating a layer from another django app
    Simone Dalmasso
    simone.dalmasso at gmail.com
    Tue Jul 26 23:08:49 PDT 2016
Hi, I think you should just pass the shp filename and not the zip. He
should be able to get the other files by itsefl as long as they are
together.
2016-07-26 21:40 GMT+02:00 Gavin Reich <Gavin.Reich at michaelcarder.co.uk>:
> Hi all,
> We’re trying to create a layer from within another project.  I was
> wondering what the best way to do this might be without using importlayers
> from the cmd line? I just need to take a zipped up shapefile and create a
> layer from that. I’ve been trying to use file_upload() from
> geonode.layers.utils to upload & create the layer but am running into the
> problem below. All the correct settings are being picked up when I look at
> django.conf.settings.OGC_SERVER and
> geonode.geoserver.helpers.ogc_server_settings. (the zip uploads fine into
> our geonode manually and if I use importlayers).
> Am I going about this the wrong way?
> Thanks
> Gavin
> For example:
> (geonode) ubuntu at ip-172-31-43-109:/opt/geonode/geonode $ python manage.py
> shell
> Python 2.7.6 (default, Jun 22 2015, 17:58:13)
> [GCC 4.8.2] on linux2
> Type "help", "copyright", "credits" or "license" for more information.
> (InteractiveConsole)
> >>> from geonode.layers.utils import file_upload
> >>> new_layer =
> file_upload(filename='/var/www/data_uploads/test_2000_01.zip')
> Traceback (most recent call last):
>   File "<console>", line 1, in <module>
>   File "/opt/geonode/geonode/geonode/layers/utils.py", line 481, in
> file_upload
>     defaults=defaults
>   File
> "/opt/venv/geonode/local/lib/python2.7/site-packages/django/db/models/manager.py",
> line 127, in manager_method
>     return getattr(self.get_queryset(), name)(*args, **kwargs)
>   File
> "/opt/venv/geonode/local/lib/python2.7/site-packages/modeltranslation/manager.py",
> line 389, in get_or_create
>     return super(MultilingualQuerySet, self).get_or_create(**kwargs)
>   File
> "/opt/venv/geonode/local/lib/python2.7/site-packages/django/db/models/query.py",
> line 407, in get_or_create
>     return self._create_object_from_params(lookup, params)
>   File
> line 439, in _create_object_from_params
>     obj = self.create(**params)
>   File
> line 381, in create
>     return super(MultilingualQuerySet, self).create(**kwargs)
>   File
> line 348, in create
>     obj.save(force_insert=True, using=self.db)
>   File
> "/opt/venv/geonode/local/lib/python2.7/site-packages/polymorphic/models.py",
> line 90, in save
>     return super(PolymorphicModel, self).save(*args, **kwargs)
>   File
> "/opt/venv/geonode/local/lib/python2.7/site-packages/django/db/models/base.py",
> line 734, in save
>     force_update=force_update, update_fields=update_fields)
>   File
> line 771, in save_base
>     update_fields=update_fields, raw=raw, using=using)
>   File
> "/opt/venv/geonode/local/lib/python2.7/site-packages/django/dispatch/dispatcher.py",
> line 189, in send
>     response = receiver(signal=self, sender=sender, **named)
>   File "/opt/geonode/geonode/geonode/geoserver/signals.py", line 190, in
> geoserver_post_save
>     workspace=instance.workspace)
>   File
> "/opt/venv/geonode/local/lib/python2.7/site-packages/geoserver/catalog.py",
> line 672, in get_resource
>     store = self.get_store(store, workspace)
>   File
> line 287, in get_store
>     raise FailedRequestError("No store found named: " + name)
> FailedRequestError: No store found named:
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160727/6e765c9e/attachment-0001.html>
More information about the geonode-users
