[GeoNode-users] proxy error in geoexplorer when adding wms server
admire addloe at gmail.com
Wed Jul 27 04:49:26 PDT 2016
Hi
I have a set up a geonode docker instance and everything works except
when I try to create a map I encounter an error.
error at /proxy/ [Errno 111] Connection refused Request Method: GET
Request URL:
http://localhost:8111/proxy/?url=http%3A%2F%2Flocalhost%3A8181%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26REQUEST%3DGetCapabilities%26TILED%3Dtrue%26VERSION
I have changed the setting.py file so that I can access geoserver using
an external port which I assigned when i was running the container by
docker run -d -p 8111:8000 -p 8181:8080 geonode.
I modified these  items in the settings.py
'PUBLIC_LOCATION': 'http://localhost:8181/geoserver/',
catalogue section changed to  'URL': 'http://localhost:8111/catalogue/csw' ,
and  the pycsw section to provider_url': "http://localhost:8111/",
   From the error log it seems the request being made inside the docker
container is now using an external port instead of internal. How can I
sort this out
Any help or documentation links.
Regards
More information about the geonode-users mailing list
