[GeoNode-users] Geonode and ArcGIS Server
Etienne Trimaille etienne.trimaille at gmail.com
Tue Jun 28 01:38:31 PDT 2016
Just for information, we are working on a patch to make geonode working
with a QGIS Server backend. Geonode is very linked to geoserver, we needed
to change some core functions.
This change may bring in the future a better architecture to have a
different backend : geoserver, mapserver, qgis, esri ...
The branch is here https://github.com/kartoza/geonode/tree/qgis_server
2016-06-28 9:04 GMT+02:00 Xenia Specka <specka at zalf.de>:
> Thanks for your advice. I will have a look at the Django-mapproxy. And I
> am aware, that we have to manually develop something, to connect Geonode
> and ArcGIS Server. Hopefully, we will be successful. Otherwise we have to
> use our fallback solution, which is ESRI Geoportal for Server.
> Thanks again,
> Xenia.
> -----Ursprüngliche Nachricht-----
> Von: Jeffrey Johnson [mailto:ortelius at gmail.com]
> Gesendet: Montag, 27. Juni 2016 21:02
> An: Xenia Specka
> Cc: geonode-users
> Betreff: Re: [GeoNode-users] Geonode and ArcGIS Server
> Hi Xenia,
> This should be possible if you have the required permissions on the ArcGIS
> server to enable WMS and WFS (vs the default Image and Map Services).
> Its not quite ready yet, but you should be able to use django-mapproxy in
> front of the Esri Server https://github.com/terranodo/django-mapproxy
> This will certainly require some development work and wont simply work out
> of the box, but if you are prepared to put in some dev effort it could be
> made to work.
> Jeff
> On Mon, Jun 27, 2016 at 6:01 AM, Xenia Specka <specka at zalf.de> wrote:
> > Hi everyone,
> > Has anyone ever tried to user ArcGIS Server as a map server in Geonode
> > instead of Geoserver?
> > I am a developer in a german research project and we want to implement
> > a dataportal, with focus on geospatial data. I really would like to
> > use Geonode, but I am forced to use ArcGIS Server as a map server. Is
> > there hope, that we can develop an  interface to use ArcGIS server
> > Has anyone done this already?
> > Kind regards
> > Xenia Specka
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/f7d9dc20/attachment.html>
More information about the geonode-users mailing list
