[GeoNode-users] Geonode and ArcGIS Server
Xenia Specka
specka at zalf.de
Tue Jun 28 02:59:52 PDT 2016
Hi again,
This sounds very promising. I will definitely checkout the mentioned branch and have a look at it. Do you know, when you are finished with those changes, so we can base our development on your core functions changes?
Kind regards
Xenia
Von: Etienne Trimaille [mailto:etienne.trimaille at gmail.com]
Gesendet: Dienstag, 28. Juni 2016 10:39
An: Xenia Specka
Cc: geonode-users at lists.osgeo.org
Betreff: Re: [GeoNode-users] Geonode and ArcGIS Server
Just for information, we are working on a patch to make geonode working with a QGIS Server backend. Geonode is very linked to geoserver, we needed to change some core functions.
This change may bring in the future a better architecture to have a different backend : geoserver, mapserver, qgis, esri ...
The branch is here https://github.com/kartoza/geonode/tree/qgis_server
2016-06-28 9:04 GMT+02:00 Xenia Specka <specka at zalf.de>:
Thanks for your advice. I will have a look at the Django-mapproxy. And I am aware, that we have to manually develop something, to connect Geonode and ArcGIS Server. Hopefully, we will be successful. Otherwise we have to use our fallback solution, which is ESRI Geoportal for Server.
Thanks again,
Xenia.
-----Ursprüngliche Nachricht-----
Von: Jeffrey Johnson [mailto:ortelius at gmail.com]
Gesendet: Montag, 27. Juni 2016 21:02
An: Xenia Specka
Cc: geonode-users
Hi Xenia,
This should be possible if you have the required permissions on the ArcGIS server to enable WMS and WFS (vs the default Image and Map Services).
Its not quite ready yet, but you should be able to use django-mapproxy in front of the Esri Server https://github.com/terranodo/django-mapproxy
This will certainly require some development work and wont simply work out of the box, but if you are prepared to put in some dev effort it could be made to work.
Jeff
On Mon, Jun 27, 2016 at 6:01 AM, Xenia Specka <specka at zalf.de> wrote:
> Hi everyone,
> Has anyone ever tried to user ArcGIS Server as a map server in Geonode
> instead of Geoserver?
> I am a developer in a german research project and we want to implement
> a dataportal, with focus on geospatial data. I really would like to
> use Geonode, but I am forced to use ArcGIS Server as a map server. Is
> there hope, that we can develop an interface to use ArcGIS server
> Has anyone done this already?
> Kind regards
> Xenia Specka
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/626cd52c/attachment.html>
More information about the geonode-users
