[GeoNode-users] Error saving style back to server
Daniel Victoria
daniel.victoria at gmail.com
Tue Jun 28 12:05:23 PDT 2016
Thanks Francesco!
I ran the command here and I'm also seeing a different subject. I don't
understand much about SSL and certificates, but I'll forward this to the
people that maintains the network here.
Thanks
Daniel
On Tue, Jun 28, 2016 at 3:58 PM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Are you sure?
> If I run the check below I’m facing with a different CN in the subject
> although the verification is ok:
> openssl s_client -showcerts -connect www.paisagenslidar.cnptia.embrapa.br
> :443
> Il giorno 28/giu/2016, alle ore 19:38, Daniel Victoria <
> daniel.victoria at gmail.com> ha scritto:
> Francesco,
> I believe the site certificate is OK. At least the only security complain
> I get when I load the site is that some images were loaded through an
> insecure connection. The public address of the site is
> baseurl is set to https://www.paisagenslidar.cnptia.embrapa.br/
> One thing I noticed is that I'm getting the same error when I try to
> upload a layer. Geonode will show me the error in the layer upload page.
> But the layer gets registered in GeoServer...
> <Capturar.PNG>
> On Tue, Jun 28, 2016 at 2:22 PM, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Daniel,
>> I took a look at you apache log file and the message is an hostname
>> mismatching so I presume that’s something wrong in the subject of the
>> certificate. Are you sure that your servername is the hostname used for the
>> subject? And what did you set as baseurl?
>> F.
>> Il giorno 28/giu/2016, alle ore 18:33, Daniel Victoria <
>> Hi Francesco,
>> Thanks for the help. Just to clarify, what should I place in
>> /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml?
>> <BaseUrl> was set to http://localhost/. I changed to my site URL,
>> restarted tomcat7 & apache, but it did not change anything.
>> Cheers
>> Daniel
>> On Tue, Jun 28, 2016 at 1:00 PM, Francesco Bartoli <xbartolone at gmail.com>
>> wrote:
>>> Hi Daniel,
>>> the SSL configuration is due just on the geonode virtual host of Apache
>>> web server where GeoServer is proxy passed. So nothing special than a
>>> standard SSL apache configuration. Actually GeoServer with the release 2.4
>>> is deployed under Tomcat 7 so you should have a look there.
>>> For instance to configure the geonode base url you can edit this file in
>>> ubuntu:
>>> Francesco
>>> Il giorno 28/giu/2016, alle ore 17:20, Daniel Victoria <
>>> So, we've not been able to sort out this problem with a certificate that
>>> is not matching our site. And since the guys that keep the network running
>>> here do not know much about geonode/geoserver, we are a bit lost. Are there
>>> any special configurations needed in order for GeoNode to play nice with
>>> SSL certificates?
>>> We found this doc online
>>> http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/ssl.html
>>> But it mentions Tomcat6 and some directories that are not present in my
>>> GeoNode install, like /var/lib/tomcat6/webapps/geoserver/WEB-INF/web.xml
>>> I'm running geonode 2.4 in Ubuntu 14.04, installed using the apt-get
>>> command.
>>> My site uses a SSL certificate from Let's Encrypt
>>> Thanks
>>> Daniel
>>> On Wed, Jun 22, 2016 at 8:54 AM, Daniel Victoria <
>>> daniel.victoria at gmail.com> wrote:
>>>> Just an update. I checked the same thing on an internal test server
>>>> that I have (that I believe does not uses https) and I don't get the server
>>>> error. So it's probably the hostname mismatch thing that is preventing me
>>>> to change the layer style. Will talk to the network guys and hope they know
>>>> how to fix it.
>>>> cheers
>>>> Daniel
>>>> On Wed, Jun 22, 2016 at 8:34 AM, Daniel Victoria <
>>>>> Hi Simone,
>>>>> Thanks for the tip. Looking at the apache2.log it appears that it's
>>>>> some problem with a cerificateHostnameMismatch. Am I reading the log
>>>>> correct? I'll talk to the people that maintains out network and see about
>>>>> this certificate.
>>>>> On the same topic, in local_setting.py what should I put in SITEURL.
>>>>> The actual name of my virtual machine (some funny thing like dmzv014)? Or
>>>>> the name it's known in the internet (https://www.some.pretty.name.here
>>>>> Thanks
>>>>> Daniel
>>>>> On Wed, Jun 22, 2016 at 6:41 AM, Simone Dalmasso <
>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>> Hi, take a look at the apache logs when the 500 error code appears,
>>>>>> they should tell you more.
>>>>>> 2016-06-21 20:12 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com
>>>>>>> Hi list,
>>>>>>> I have a GeoNode instance running on Ubuntu, installed via
>>>>>>> apt-get.Everything appears to be working fine however, when I try to change
>>>>>>> a layer style, I get the error: "There was an error saving the
>>>>>>> style back to the server."
>>>>>>> Looking at the development console, I see that when I try to alter
>>>>>>> the layer style there are 2 PUT calls to the server. The first one fails
>>>>>>> with error 500 Internal server error. This is the call that's sending the
>>>>>>> SLD to the server. The second one returns 200 OK and it's sending the a
>>>>>>> JSON
>>>>>>> {"layer":{"defaultStyle":{"name":"estados"},"styles":{},"enabled":true}}
>>>>>>> I'm trying to debug this error but can't find what is going on. I'm
>>>>>>> running behind a proxy server. Could this be a security setting? Is it
>>>>>>> normal that one PUT call fails and the other works?
>>>>>>> Thanks
>>>>>>> Daniel
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160628/ade51011/attachment-0001.html>
More information about the geonode-users
