[GeoNode-users] Error saving style back to server
Amedeo Fadini
fame at libero.it
Wed Jun 29 03:25:35 PDT 2016
Hi everybody,
2016-06-28 21:05 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
> Thanks Francesco!
> I ran the command here and I'm also seeing a different subject. I don't
> understand much about SSL and certificates, but I'll forward this to the
> people that maintains the network here.
I've just finished to setup my installation (ubuntu server via
apt-get) for working with ssl...
I've found this difference with the guide:
http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/ssl.html
Tomcat configuration
found file in
/etc/tomcat7/server.xml
instead of
/var/lib/tomcat6/conf/server.xml
GeoServer Configuration
found in
/usr/share/geoserver/WEB-INF/web.xml
instead of
/var/lib/tomcat6/webapps/geoserver/WEB-INF/web.xml
also the file
/var/lib/geoserver/geonode-data/global.xml
doesn't exist and seems not necessary
Also my server works without the step
"Next add the certificate to the cacerts file for python and java:"
Am I right?
Should I update the guide and make a merge request?
('d like to change also that static ip 192.168.10.10 mentioned in the snippets)
amefad
> Thanks
> Daniel
> On Tue, Jun 28, 2016 at 3:58 PM, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Are you sure?
>> If I run the check below I’m facing with a different CN in the subject
>> although the verification is ok:
>> openssl s_client -showcerts -connect
>> www.paisagenslidar.cnptia.embrapa.br:443
>> Il giorno 28/giu/2016, alle ore 19:38, Daniel Victoria
>> <daniel.victoria at gmail.com> ha scritto:
>> Francesco,
>> I believe the site certificate is OK. At least the only security complain
>> I get when I load the site is that some images were loaded through an
>> insecure connection. The public address of the site is
>> baseurl is set to https://www.paisagenslidar.cnptia.embrapa.br/
>> One thing I noticed is that I'm getting the same error when I try to
>> upload a layer. Geonode will show me the error in the layer upload page. But
>> the layer gets registered in GeoServer...
>> <Capturar.PNG>
>> On Tue, Jun 28, 2016 at 2:22 PM, Francesco Bartoli <xbartolone at gmail.com>
>> wrote:
>>> Daniel,
>>> I took a look at you apache log file and the message is an hostname
>>> mismatching so I presume that’s something wrong in the subject of the
>>> certificate. Are you sure that your servername is the hostname used for the
>>> subject? And what did you set as baseurl?
>>> F.
>>> Il giorno 28/giu/2016, alle ore 18:33, Daniel Victoria
>>> Hi Francesco,
>>> Thanks for the help. Just to clarify, what should I place in
>>> /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml?
>>> <BaseUrl> was set to http://localhost/. I changed to my site URL,
>>> restarted tomcat7 & apache, but it did not change anything.
>>> Cheers
>>> Daniel
>>> On Tue, Jun 28, 2016 at 1:00 PM, Francesco Bartoli <xbartolone at gmail.com>
>>> wrote:
>>>> Hi Daniel,
>>>> the SSL configuration is due just on the geonode virtual host of Apache
>>>> web server where GeoServer is proxy passed. So nothing special than a
>>>> standard SSL apache configuration. Actually GeoServer with the release 2.4
>>>> is deployed under Tomcat 7 so you should have a look there.
>>>> For instance to configure the geonode base url you can edit this file in
>>>> ubuntu:
>>>> Francesco
>>>> Il giorno 28/giu/2016, alle ore 17:20, Daniel Victoria
>>>> So, we've not been able to sort out this problem with a certificate that
>>>> is not matching our site. And since the guys that keep the network running
>>>> here do not know much about geonode/geoserver, we are a bit lost. Are there
>>>> any special configurations needed in order for GeoNode to play nice with SSL
>>>> certificates?
>>>> We found this doc online
>>>> But it mentions Tomcat6 and some directories that are not present in my
>>>> GeoNode install, like /var/lib/tomcat6/webapps/geoserver/WEB-INF/web.xml
>>>> I'm running geonode 2.4 in Ubuntu 14.04, installed using the apt-get
>>>> command.
>>>> My site uses a SSL certificate from Let's Encrypt
>>>> Thanks
>>>> Daniel
>>>> On Wed, Jun 22, 2016 at 8:54 AM, Daniel Victoria
>>>> <daniel.victoria at gmail.com> wrote:
>>>>> Just an update. I checked the same thing on an internal test server
>>>>> that I have (that I believe does not uses https) and I don't get the server
>>>>> error. So it's probably the hostname mismatch thing that is preventing me to
>>>>> change the layer style. Will talk to the network guys and hope they know how
>>>>> to fix it.
>>>>> cheers
>>>>> Daniel
>>>>> On Wed, Jun 22, 2016 at 8:34 AM, Daniel Victoria
>>>>>> Hi Simone,
>>>>>> Thanks for the tip. Looking at the apache2.log it appears that it's
>>>>>> some problem with a cerificateHostnameMismatch. Am I reading the log
>>>>>> correct? I'll talk to the people that maintains out network and see about
>>>>>> this certificate.
>>>>>> On the same topic, in local_setting.py what should I put in SITEURL.
>>>>>> The actual name of my virtual machine (some funny thing like dmzv014)? Or
>>>>>> the name it's known in the internet (https://www.some.pretty.name.here)
>>>>>> Thanks
>>>>>> Daniel
>>>>>> On Wed, Jun 22, 2016 at 6:41 AM, Simone Dalmasso
>>>>>> <simone.dalmasso at gmail.com> wrote:
>>>>>>> Hi, take a look at the apache logs when the 500 error code appears,
>>>>>>> they should tell you more.
>>>>>>> 2016-06-21 20:12 GMT+02:00 Daniel Victoria
>>>>>>>> Hi list,
>>>>>>>> I have a GeoNode instance running on Ubuntu, installed via
>>>>>>>> apt-get.Everything appears to be working fine however, when I try to change
>>>>>>>> a layer style, I get the error: "There was an error saving the style back to
>>>>>>>> the server."
>>>>>>>> Looking at the development console, I see that when I try to alter
>>>>>>>> the layer style there are 2 PUT calls to the server. The first one fails
>>>>>>>> with error 500 Internal server error. This is the call that's sending the
>>>>>>>> SLD to the server. The second one returns 200 OK and it's sending the a JSON
>>>>>>>> {"layer":{"defaultStyle":{"name":"estados"},"styles":{},"enabled":true}}
>>>>>>>> I'm trying to debug this error but can't find what is going on. I'm
>>>>>>>> running behind a proxy server. Could this be a security setting? Is it
>>>>>>>> normal that one PUT call fails and the other works?
>>>>>>>> Thanks
>>>>>>>> Daniel
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> Simone
More information about the geonode-users
