[GeoNode-users] QGIS SLD and GeoNode/GeoServer
Daniel Victoria daniel.victoria at gmail.com
Tue Mar 1 08:34:32 PST 2016
An update on the GeoServer Explorer plugin.
Using the plugin I can see all the layers in my GeoServer and the styles
associated with it. However, when I try to edit the style using QGis
dialog, I get the following error when I try to apply the new style
must be string or buffer, not tuple
  File "C:/Users/daniel/.qgis2/python/plugins\geoserverexplorer\gui\explorer.py",
line 98, in run
    command(*params)
  File "C:\Users\daniel\.qgis2\python\plugins\geoserverexplorer\ext-libs\gsconfig-1.0.0-py2.7.egg\geoserver\style.py",
line 108, in update_body
    self.body_href, "PUT", body, headers)
  File "C:/Users/daniel/.qgis2/python/plugins\geoserverexplorer\geoserver\retry.py",
line 14, in decorator
    raise e
TypeError: must be string or buffer, not tuple
I don't get any errors in QGis log messages. I'll report an issue in github
Cheers
Daniel
On Tue, Mar 1, 2016 at 8:36 AM, Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> I tried the plugin but there are some messed up layers in my geoserver and
> so the Plugin cannot list the entire contents of the server.
> As for comparing what happens to the SLD after I edit it using GeoNode,
> here are the tests and results I got:
> 1) I created a simple black outline style in QGis and saved as a SLD file
> (style_qgis.sld).
> 2) I pasted this style in GeoServer and it worked both in the GeoServer
> layer preview and GeoNode
> 3) I tried to edit the style using Geonode interface and I got the error
> message: "There was an error saving the style back to the server."
> 4) After this error, the layer style in GeoServer contained only
> <?xml version="1.0" encoding="UTF-8"?><sld:StyledLayerDescriptor xmlns:xs="
> http://www.w3.org/2001/XMLSchema" xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:sld="http://www.opengis.net/sld" xmlns:gml="
> http://www.opengis.net/gml" xmlns:se="http://www.opengis.net/se"/>
> 5) I cannot edit the style in GeoNode and I have to set it manually using
> GeoServer interface
> Daniel
> On Mon, Feb 29, 2016 at 4:56 PM, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Hi,
>> have you tried to edit styles with this plugin
>> <https://github.com/boundlessgeo/qgis-geoserver-plugin> from Boundless?
>> Also did you try to compare the SLD file from geoserver before and after
>> you edited it from the geonode editor and see what are the differences?
>> Francesco
>> Il giorno 29/feb/2016, alle ore 20:25, Stefan Steiniger <
>> sstein at geo.uzh.ch> ha scritto:
>> Hi Daniel,
>> no solution - but confirming.
>> I have the same problem: Creating Styles in QGIS and c&p in GeoServer,
>> and when I try editing style I get errors. So I am also just sticking to
>> "don't edit styles" set in GeoServer :(
>> Related to that, perhaps: I also have problem with spanish names and
>> accent-letters when used for classification. In a weird case (don't
>> remember the details) the polygons of a particular class didn't even get
>> rendered.
>> cheers,
>> stefan
>> On 2/29/16 15:19, Daniel Victoria wrote:
>> Hi List,
>> This is probaly more of a GeoServer question but, GeoNode users probably
>> have faced this some time or another, so here we go:
>> I have a soil vector layer with lots of different soil classes. In order
>> to create a nice layer style, I used QGis v2.12 to create some nice legend.
>> I then saved the layer style as a SLD file and pasted it in GeoServer. This
>> process has worked quite nice, despite differences in SLD version between
>> QGis (v1.1) and GeoSever (1.0). But it's not 100% and if I try to edit the
>> layer style using GeoNode Style editor, thing stop working and the style is
>> messed up.
>> So, what are the workflows for setting complex layer styles? Anyone using
>> QGis to generate SLD? I heard uDig is also a good tool for style
>> generation? And what about the Geoserver Explorer plugin? I never had much
>> luck using the plugin but I believe there is a problem with some of the
>> layers in my geoserver instance that is messing things up.
>> Thanks
>> Daniel
>> geonode-users mailing listgeonode-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160301/f517fdd2/attachment.html>
More information about the geonode-users mailing list
