[GeoNode-users] QGIS SLD and GeoNode/GeoServer
Daniel Victoria daniel.victoria at gmail.com
Tue Mar 1 08:44:43 PST 2016
Update 2: An issue regarding the error I'm seeing is already opened in
GitHub
https://github.com/boundlessgeo/qgis-geoserver-plugin/issues/35
On Tue, Mar 1, 2016 at 1:34 PM, Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> An update on the GeoServer Explorer plugin.
> Using the plugin I can see all the layers in my GeoServer and the styles
> associated with it. However, when I try to edit the style using QGis
> dialog, I get the following error when I try to apply the new style
> must be string or buffer, not tuple
> Traceback (most recent call last):
>   File "C:/Users/daniel/.qgis2/python/plugins\geoserverexplorer\gui\explorer.py", line 98, in run
>     command(*params)
>   File "C:\Users\daniel\.qgis2\python\plugins\geoserverexplorer\ext-libs\gsconfig-1.0.0-py2.7.egg\geoserver\style.py", line 108, in update_body
>     self.body_href, "PUT", body, headers)
>   File "C:/Users/daniel/.qgis2/python/plugins\geoserverexplorer\geoserver\retry.py", line 14, in decorator
>     raise e
> TypeError: must be string or buffer, not tuple
> I don't get any errors in QGis log messages. I'll report an issue in github
> Cheers
> Daniel
> On Tue, Mar 1, 2016 at 8:36 AM, Daniel Victoria <daniel.victoria at gmail.com
> > wrote:
>> I tried the plugin but there are some messed up layers in my geoserver
>> and so the Plugin cannot list the entire contents of the server.
>> As for comparing what happens to the SLD after I edit it using GeoNode,
>> here are the tests and results I got:
>> 1) I created a simple black outline style in QGis and saved as a SLD file
>> (style_qgis.sld).
>> 2) I pasted this style in GeoServer and it worked both in the GeoServer
>> layer preview and GeoNode
>> 3) I tried to edit the style using Geonode interface and I got the error
>> message: "There was an error saving the style back to the server."
>> 4) After this error, the layer style in GeoServer contained only
>> <?xml version="1.0" encoding="UTF-8"?><sld:StyledLayerDescriptor
>> xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ogc="
>> http://www.opengis.net/ogc" xmlns:sld="http://www.opengis.net/sld"
>> xmlns:gml="http://www.opengis.net/gml" xmlns:se="
>> http://www.opengis.net/se"/>
>> 5) I cannot edit the style in GeoNode and I have to set it manually using
>> GeoServer interface
>> Daniel
>> On Mon, Feb 29, 2016 at 4:56 PM, Francesco Bartoli <xbartolone at gmail.com>
>> wrote:
>>> Hi,
>>> have you tried to edit styles with this plugin
>>> <https://github.com/boundlessgeo/qgis-geoserver-plugin> from Boundless?
>>> Also did you try to compare the SLD file from geoserver before and after
>>> you edited it from the geonode editor and see what are the differences?
>>> Francesco
>>> Il giorno 29/feb/2016, alle ore 20:25, Stefan Steiniger <
>>> sstein at geo.uzh.ch> ha scritto:
>>> Hi Daniel,
>>> no solution - but confirming.
>>> I have the same problem: Creating Styles in QGIS and c&p in GeoServer,
>>> and when I try editing style I get errors. So I am also just sticking to
>>> "don't edit styles" set in GeoServer :(
>>> Related to that, perhaps: I also have problem with spanish names and
>>> accent-letters when used for classification. In a weird case (don't
>>> remember the details) the polygons of a particular class didn't even get
>>> rendered.
>>> cheers,
>>> stefan
>>> On 2/29/16 15:19, Daniel Victoria wrote:
>>> Hi List,
>>> This is probaly more of a GeoServer question but, GeoNode users probably
>>> have faced this some time or another, so here we go:
>>> I have a soil vector layer with lots of different soil classes. In order
>>> to create a nice layer style, I used QGis v2.12 to create some nice legend.
>>> I then saved the layer style as a SLD file and pasted it in GeoServer. This
>>> process has worked quite nice, despite differences in SLD version between
>>> QGis (v1.1) and GeoSever (1.0). But it's not 100% and if I try to edit the
>>> layer style using GeoNode Style editor, thing stop working and the style is
>>> messed up.
>>> So, what are the workflows for setting complex layer styles? Anyone
>>> using QGis to generate SLD? I heard uDig is also a good tool for style
>>> generation? And what about the Geoserver Explorer plugin? I never had much
>>> luck using the plugin but I believe there is a problem with some of the
>>> layers in my geoserver instance that is messing things up.
>>> Thanks
>>> Daniel
>>> geonode-users mailing listgeonode-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160301/4cf17927/attachment-0001.html>
More information about the geonode-users mailing list
