[GeoNode-users] Upload problem
Alessio alessio.dl at gmail.com
Wed May 4 00:28:48 PDT 2016
Hi all,
just to let you know that the issue was actually on my corporate's firewall
(and I can't chek or manage it on my own...).
A few days ago the VM where my Geonode instance is running was moved on a
new host machine and some firewall rules were changed.
Now the upload module is working again.
Many thanks for your help! It was anyway useful, also to tune some aspects
of my geonode configuration
2016-05-03 16:14 GMT+02:00 Alessio <alessio.dl at gmail.com>:
> Checking the local_settings.py with @afabiani (many thanks for your
> support!) it seems ok.
> The issue, maybe related to the DNS configuration in
> /etc/network/interfaces.
> I write into it both dns-nameservers and dns-domain:
> dns-search izs.it
> dns-nameservers 10.100.100.25 172.16.0.22 172.16.0.23 172.16.0.28
> ...what should I verify?
> When I upload a shapefile it is received by Geoserver (the layer is in the
> list and the preview works), but Geonode responds with an "[Errno 110]
> Connection time out" (the same error I can find into the apache error.log)
> after some minutes.
> 2016-05-03 12:16 GMT+02:00 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>:
>> - Remove DB passwords
>> - If you have absolute URLs, obfuscate them
>> I don't think you need to remove something else. If you are not sure,
>> just send the file privately to Simone and/or me.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Tue, May 3, 2016 at 12:13 PM, Alessio <alessio.dl at gmail.com> wrote:
>>> 2016-05-03 11:43 GMT+02:00 Alessio Fabiani <
>>>> Can you please send us your local_settings? (DO NOT FORGET TO REMOVE OR
>>>> OBFUSCATE THE PASSWORDS AND URLs)
>>> Of course! Just a few questions to be sure to not share something
>>> sensitive!
>>> The only password I see in my /etc/geonode/local_settings.py is the
>>> database password.
>>> I have to remove this... and what else? There are urls that I have to
>>> obfuscate? There are my portal url, some localhost entry and something in
>>> proxy allowed hosts
>>> Thanks for your help!
>>> Alessio
> Alessio
Alessio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160504/20bb032b/attachment.html>
More information about the geonode-users mailing list
