[GeoNode-users] Error 401 & Error 404
Simone Dalmasso
simone.dalmasso at gmail.com
Fri May 6 05:25:45 PDT 2016
Did you start with this setup or you migrated to this setup after having
loaded the layers? also, what requests are hitting the wrong url?
2016-05-05 14:19 GMT+02:00 said lahssini <marghadi at gmail.com>:
> Dear All,
> I would like to ask you if it is possible to have a separate instance of
> geocode and geoserver (we installed a geocode on a local machine, then a
> geoserver on a remote machine and other machine contains the RDBMS)?
> After we installed and configured adequately the three servers, we can
> display spatial data within the RDBMS. But when we try to visualize or to
> edit the Data through geoportal it fails with error 401 and 404.
> SITEURL2='http://192.168.2.39:8080/'
> GEOSERVER_URL = SITEURL2 + 'geoserver/'
> # OGC (WMS/WFS/WCS) Server Settings
> OGC_SERVER = {
> 'default' : {
> 'BACKEND' : 'geonode.geoserver',
> #'LOCATION' : 'http://localhost:8080/geoserver/',
> 'LOCATION' : 'http://192.168.2.39:8080/geoserver/',
> 'PUBLIC_LOCATION' : GEOSERVER_URL,
> 'USER' : ‘admin',
> 'PASSWORD' : ‘xxxxxx',
> 'MAPFISH_PRINT_ENABLED' : True,
> 'PRINT_NG_ENABLED' : True,
> 'GEONODE_SECURITY_ENABLED' : True,
> 'GEOGIG_ENABLED' : False,
> 'WMST_ENABLED' : False,
> 'BACKEND_WRITE_ENABLED': True,
> 'WPS_ENABLED' : True,
> 'LOG_FILE':'/usr/share/geoserver/data/logs/geoserver.log',
> # Set to name of database in DATABASES dictionary to enable
> 'DATASTORE': 'datastore',
> What could be the problem with our configuration?
> Said
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160506/ce2e2f96/attachment.html>
More information about the geonode-users
