[GeoNode-users] Error 401 & Error 404
    said LAHSSINI
    marghadi at gmail.com
    Fri May  6 10:51:32 PDT 2016
Thank you for your answer.
We installed geoserver on a server 'http://192.168.2.39:8080/', then we
installed a geonode with its geoserver on 'http://192.168.2.
<http://192.168.2.39:8080/>38 and then postgis server on '
http://192.168.2.40/ <http://192.168.2.39:8080/>'. Our choice was, instead
of using geonode's geoserver, to use a dedicated remote machine for
geoserver.
After installing the three servers, we loaded a postgis dump into the
database. In addition, we changed the initial setting (local_settings) and
then we defined for geoserver (192.168.2.39) datastores to postgis tables.
Finally,  we executed geonode updatelayers. (We did not any extra setting
in the dedicated geoserver : 192.168.39)
As geonode permitted us to visualize all spatial data within geoserver all
seem working fine. Unforunately, when we tray to modify or to insert a new
geometry within geoportal (geonode) it through the 401 and 404 error
(please see the attached file) .
Is it something wrong to set in the dedicated geoserver? or geoserver must
be with geonode within the same machine?
Thank you very much
Said
2016-05-06 13:25 GMT+01:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Did you start with this setup or you migrated to this setup after having
> loaded the layers? also, what requests are hitting the wrong url?
> 2016-05-05 14:19 GMT+02:00 said lahssini <marghadi at gmail.com>:
>> Dear All,
>> I would like to ask you if it is possible to have a separate instance of
>> geocode and geoserver (we installed a geocode on a local machine, then a
>> geoserver on a remote machine and other machine contains the RDBMS)?
>> After we installed and configured adequately the three servers, we can
>> display spatial data within the RDBMS. But when we try to visualize or to
>> edit the Data through geoportal it fails with error 401 and 404.
>> SITEURL2='http://192.168.2.39:8080/'
>> GEOSERVER_URL = SITEURL2 + 'geoserver/'
>> # OGC (WMS/WFS/WCS) Server Settings
>> OGC_SERVER = {
>>     'default' : {
>>         'BACKEND' : 'geonode.geoserver',
>>         #'LOCATION' : 'http://localhost:8080/geoserver/',
>>         'LOCATION' : 'http://192.168.2.39:8080/geoserver/',
>>         'PUBLIC_LOCATION' : GEOSERVER_URL,
>>         'USER' : ‘admin',
>>         'PASSWORD' : ‘xxxxxx',
>>         'MAPFISH_PRINT_ENABLED' : True,
>>         'PRINT_NG_ENABLED' : True,
>>         'GEONODE_SECURITY_ENABLED' : True,
>>         'GEOGIG_ENABLED' : False,
>>         'WMST_ENABLED' : False,
>>         'BACKEND_WRITE_ENABLED': True,
>>         'WPS_ENABLED' : True,
>>         'LOG_FILE':'/usr/share/geoserver/data/logs/geoserver.log',
>>         # Set to name of database in DATABASES dictionary to enable
>>         'DATASTORE': 'datastore',
>> What could be the problem with our configuration?
>> Said
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
*-*      Saïd LAHSSINI
*-*     P.A Sciences Forestières
*-*     Ecole Nationale Forestière d'Ingénieurs
*-*      BP 511 Tabriquet, Salé
*-*     Tél.: *+212(0) 37 86 37 04* // Fax.: *+212(0) 37 86 11 49*
*-*      GSM : 00212 663 666596
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160506/15a6d113/attachment-0001.html>
Type: application/vnd.openxmlformats-officedocument.wordprocessingml.document
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160506/15a6d113/attachment-0001.docx>
More information about the geonode-users
