[GeoNode-users] 'geonode' command on Ubuntu throws "Unknown command" when called without arguments
Benjamin Ducke
benducke at fastmail.fm
Wed May 11 05:14:02 PDT 2016
On 11/05/16 13:51, Simone Dalmasso wrote:
> Sorry I don't understand which 'geonode' command are you referring to.
> If you refer to geonode syncdb from the geonode quick setup then you
> have to issue it before installing the theme.
I am talking about step 4 in the sequence
found here:
http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/setup_admin.html#setup-admin
This is what the official instructions tell
me to do:
1 $ cd /home/geonode/my_geonode
2 $ python manage.py collectstatic
3 $ python manage.py syncdb
4 $ /home/geonode/geonode
5 $ sudo pip install -e .
6 $ sudo service apache2 restart
As you can see: in step 4 I am supposed to run
the command 'geonode' without any arguments.
On a Ubuntu install from packages, this 'geonode'
script is located in '/usr/sbin', and when running
it without arguments, it will throw an error
message.
> after it you can still issue all the commands but using python manage.py.
Yes, that works fine.
Cheers,
Ben
> 2016-05-11 13:37 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
> <mailto:benducke at fastmail.fm>>:
> Hi Simone --
> On 11/05/16 13:28, Simone Dalmasso wrote:
> > Hi,
> > yes those steps are for when you installed geonode using apt-get.
> Right, that's what I did.
> > They can be issued as they are
> But then 'geonode' will throw an error
> message, as I described. I find that
> a little disconcerting.
> > and the geonode theme will be installed
> > systemwide as geonode is and you need to have geonode installed before
> > doing that.
> > You don't have to use django-admin except for the template
> creation. The
> > commands as they are using manage.py work fine. If you installed
> geonode
> > manually then it depends on your configuration but still is very
> similar.
> > The geonode command is not used anymore to do collectstatic
> because the
> > manage.py will take care of it.
> So do I understand correctly, that I can just
> skip running 'geonode'?
> Then maybe that step should be removed from
> the instructions on the Web?
> Cheers and Thanks for your quick reply!
> Ben
> > 2016-05-11 12:57 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
> > <mailto:benducke at fastmail.fm <mailto:benducke at fastmail.fm>>>:
> >> Dear GeoNoders,
> >> I am currently setting up my first GeoNode installation, and
> trying to
> >> follow
> >> the official documentation on customization and theming.
> >> I would appreciate some help/feedback with the 'geonode' command.
> >> My OS is Ubuntu 14.04 and I have installed GeoNode 2.4. from the
> >> official
> >> packages.
> >> On this page:
> >> There is a sequence of commands that includes a call to 'geonode'
> (step
> >> 4):
> >> I am assuming that this refers to '/usr/sbin/geonode' when installed
> >> from
> >> the Ubuntu packages, correct? Said executable is a simple shell
> script
> >> wrapper for 'django-admin', which just determines whether to use
> >> 'django-admin' or 'django-admin.py' (right choice for my OS). So
> far so
> >> good. However, when just calling 'geonode' without any arguments,
> I get:
> >> Unknown command: '--settings=geonode.settings'
> >> Apparently, this is because the arguments placeholder '$@' in
> >> '/usr/sbin/geonode'
> >> stays empty in this case, but 'django-admin.py' really wants to
> have the
> >> name
> >> of a subcommand.
> >> So my question is: Did 'django-admin.py' use to have a default
> >> subcommand in
> >> the past, but no longer? Or are the instructions on the web page
> above
> >> incomplete?
> >> Which django-admin subcommand should run in line 4 above?
> >> Many thanks for any pointers,
> >> Benjamin
> >> Benjamin Ducke
> >> {*} Geospatial Consultant
> >> {*} GIS Developer
> >> benducke AT fastmail.fm <http://fastmail.fm> <http://fastmail.fm>
> >> _______________________________________________
> >> geonode-users mailing list
> >> geonode-users at lists.osgeo.org
> <mailto:geonode-users at lists.osgeo.org>
> <mailto:geonode-users at lists.osgeo.org>>
> >> http://lists.osgeo.org/mailman/listinfo/geonode-users
> > Simone
> Dr. Benjamin Ducke
> {*} GIS Developer
> Spatial technology for the masses, not the classes:
> experience free and open source GIS at http://gvsigce.org
> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
> Simone
Dr. Benjamin Ducke
{*} GIS Developer
More information about the geonode-users
