[GeoNode-users] 'geonode' command on Ubuntu throws "Unknown command" when called without arguments
Simone Dalmasso
simone.dalmasso at gmail.com
Wed May 11 06:11:41 PDT 2016
Ha! I see, sorry.
There's definitely a typo there.
Assuming you created the my_geonode template in /home/geonode the steps
should be:
1 $ cd /home/geonode/my_geonode
2 $ sudo pip install -e .
3 $ python manage.py collectstatic
4 $ python manage.py syncdb
5 $ sudo service apache2 restart
I'm going to fix the docs. Sorry to not have read carefully it before. And
thanks for reporting
2016-05-11 14:14 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm>:
> On 11/05/16 13:51, Simone Dalmasso wrote:
> > Sorry I don't understand which 'geonode' command are you referring to.
> > If you refer to geonode syncdb from the geonode quick setup then you
> > have to issue it before installing the theme.
> I am talking about step 4 in the sequence
> found here:
> http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/setup_admin.html#setup-admin
> This is what the official instructions tell
> me to do:
> 2 $ python manage.py collectstatic
> 3 $ python manage.py syncdb
> 4 $ /home/geonode/geonode
> 5 $ sudo pip install -e .
> 6 $ sudo service apache2 restart
> As you can see: in step 4 I am supposed to run
> the command 'geonode' without any arguments.
> On a Ubuntu install from packages, this 'geonode'
> script is located in '/usr/sbin', and when running
> it without arguments, it will throw an error
> message.
> > after it you can still issue all the commands but using python manage.py.
> Yes, that works fine.
> Cheers,
> Ben
> > 2016-05-11 13:37 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
> > <mailto:benducke at fastmail.fm>>:
> > Hi Simone --
> > On 11/05/16 13:28, Simone Dalmasso wrote:
> > > Hi,
> > > yes those steps are for when you installed geonode using apt-get.
> > Right, that's what I did.
> > > They can be issued as they are
> > But then 'geonode' will throw an error
> > message, as I described. I find that
> > a little disconcerting.
> > > and the geonode theme will be installed
> > > systemwide as geonode is and you need to have geonode installed
> before
> > > doing that.
> > > You don't have to use django-admin except for the template
> > creation. The
> > > commands as they are using manage.py work fine. If you installed
> > geonode
> > > manually then it depends on your configuration but still is very
> > similar.
> > > The geonode command is not used anymore to do collectstatic
> > because the
> > > manage.py will take care of it.
> > So do I understand correctly, that I can just
> > skip running 'geonode'?
> > Then maybe that step should be removed from
> > the instructions on the Web?
> > Cheers and Thanks for your quick reply!
> > Ben
> > > 2016-05-11 12:57 GMT+02:00 Benjamin Ducke <benducke at fastmail.fm
> > > <mailto:benducke at fastmail.fm <mailto:benducke at fastmail.fm>>>:
> > >> Dear GeoNoders,
> > >> I am currently setting up my first GeoNode installation, and
> > trying to
> > >> follow
> > >> the official documentation on customization and theming.
> > >> I would appreciate some help/feedback with the 'geonode' command.
> > >> My OS is Ubuntu 14.04 and I have installed GeoNode 2.4. from the
> > >> official
> > >> packages.
> > >> On this page:
> > >> There is a sequence of commands that includes a call to 'geonode'
> > (step
> > >> 4):
> > >> I am assuming that this refers to '/usr/sbin/geonode' when
> installed
> > >> from
> > >> the Ubuntu packages, correct? Said executable is a simple shell
> > script
> > >> wrapper for 'django-admin', which just determines whether to use
> > >> 'django-admin' or 'django-admin.py' (right choice for my OS). So
> > far so
> > >> good. However, when just calling 'geonode' without any arguments,
> > I get:
> > >> Unknown command: '--settings=geonode.settings'
> > >> Apparently, this is because the arguments placeholder '$@' in
> > >> '/usr/sbin/geonode'
> > >> stays empty in this case, but 'django-admin.py' really wants to
> > have the
> > >> name
> > >> of a subcommand.
> > >> So my question is: Did 'django-admin.py' use to have a default
> > >> subcommand in
> > >> the past, but no longer? Or are the instructions on the web page
> > above
> > >> incomplete?
> > >> Which django-admin subcommand should run in line 4 above?
> > >> Many thanks for any pointers,
> > >> Benjamin
> > >> Benjamin Ducke
> > >> {*} Geospatial Consultant
> > >> {*} GIS Developer
> > >> benducke AT fastmail.fm <http://fastmail.fm> <
> http://fastmail.fm>
> > >> _______________________________________________
> > >> geonode-users mailing list
> > >> geonode-users at lists.osgeo.org
> > <mailto:geonode-users at lists.osgeo.org>
> > <mailto:geonode-users at lists.osgeo.org>>
> > >> http://lists.osgeo.org/mailman/listinfo/geonode-users
> > > Simone
> > Dr. Benjamin Ducke
> > {*} GIS Developer
> > Spatial technology for the masses, not the classes:
> > experience free and open source GIS at http://gvsigce.org
> > geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
> > Simone
> Dr. Benjamin Ducke
> {*} GIS Developer
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160511/c8ac50d4/attachment-0001.html>
More information about the geonode-users
