[GeoNode-users] Geoserver error 502
LEOPOLDO JAVIER NUNEZ DE SANTIAGO . lnunezde at guanajuato.gob.mx
Mon May 16 11:15:32 PDT 2016
Geoserver problem, you can not see the layers, or edit or delete them, you
can not open the site geoserver, but if you open your administrative site
GeoNode as well as the overall site.
Message when trying to open http://192.168.1.94/geoserver/
502 Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server Could not handle the request GET / geoserver /.
Reason: Error reading from remote server,
Problema con geoserver, no se pueden ver los layers, ni editarlos, ni
eliminarlos, no se puede abrir el sitio de geoserver, pero si abre bien el
sitio administrativo de geonode, así como el sitio en general.
Mensaje al intentar abrir http://192.168.1.94/geoserver/
502 Proxy Error
The proxy server could not handle the request GET /geoserver/.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160516/be4d2d91/attachment.html>
More information about the geonode-users mailing list
