[GeoNode-users] Set active layer
David Alda Fernandez de Lezea dalda at hazi.eus
Thu May 19 04:34:47 PDT 2016
Thanks Simone, unfortunately I'm not an ExtJS/GeoExt expert... How can I get access to the layer tree.
Thanks in advance.
Regards,
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Enviado el: miércoles, 18 de mayo de 2016 9:43
Para: David Alda Fernandez de Lezea
CC: geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] Set active layer
Hi David,
not sure but maybe you can get the layer node and .select() it. There's something here http://docs.sencha.com/extjs/3.4.0/#!/api/Ext.tree.AsyncTreeNode-method-select
2016-05-18 9:33 GMT+02:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi list,
I'm developing a small form into the GeoExplorer view that does some stuff with the overlays and I need to set the selected layer of the layers tree from code . Is that possible?
I've looking into the code but I can't some kind of function like setSelectedLayer or something like that...
Could anyone point me to the right direction?
Thanks in advance,
Regards,
Agur bero bat,
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
More information about the geonode-users mailing list
