[GeoNode-users] Set active layer
Simone Dalmasso
simone.dalmasso at gmail.com
Thu May 19 05:20:19 PDT 2016
I think that looping over the app.tools you could find a component named
"gxp_layertree" or something like this.
2016-05-19 13:34 GMT+02:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Thanks Simone, unfortunately I'm not an ExtJS/GeoExt expert... How can I
> get access to the layer tree.
> Thanks in advance.
> Regards,
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> ********************* LEGE OHARRA ******************* AVISOLEGAL
> ******************* DISCLAIMER *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Enviado el: miércoles, 18 de mayo de 2016 9:43
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] Set active layer
> Hi David,
> not sure but maybe you can get the layer node and .select() it. There's
> something here
> http://docs.sencha.com/extjs/3.4.0/#!/api/Ext.tree.AsyncTreeNode-method-select
> 2016-05-18 9:33 GMT+02:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi list,
> I'm developing a small form into the GeoExplorer view that does some stuff
> with the overlays and I need to set the selected layer of the layers tree
> from code . Is that possible?
> I've looking into the code but I can't some kind of function like
> setSelectedLayer or something like that...
> Could anyone point me to the right direction?
> Thanks in advance,
> Regards,
> Agur bero bat,
> Arloa.
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> kontserbatu gabe.
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160519/5bd78b1f/attachment.html>
More information about the geonode-users
