[GeoNode-users] HOW should I run update layers to publish layers from Geoserver?
Simone Dalmasso simone.dalmasso at gmail.com
Thu May 26 00:00:03 PDT 2016
Hi Amedeo,
updatelayers should run as a normal user as it doesn't write any file to
disk, it will only register the data available in geoserver into the
geonode db.
Your error seems more to be related on geonode - gesoserver setup.  Do you
have any other information on this error?
2016-05-25 17:02 GMT+02:00 Amedeo Fadini <amefad at gmail.com>:
> Hi everybody...
> In my instance of Geonode (Ubuntu 14.40 installed via apt-get I'd like
> to publish data from other databases than geonode-data, and soon sql
> views also. So I published my layers from geoserver and then ran
> geonode update-layers but I've experienced e trouble in modifying
> styles (403 forbidden error)
> So I think that the  geonode updatelayers command should be executed
> by user www-data I launched it sometime as root and seems that now
> there are wrong permissions inside /var/www/geonode folder...
> - with which user I must run the comand updatelayers? this ubuntu
> installation doesn't allow make su www-data
> - what are the righ privileges  for the geonode folders?
> Thanks a lot.
> Amedeo Fadini
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160526/b568b8e7/attachment.html>
More information about the geonode-users mailing list
