[GeoNode-users] Valid backup GeoNode 2.4
Daniel Berry dberry at boundlessgeo.com
Mon Oct 17 07:14:30 PDT 2016
Also you will need to backup any Django media files e.g. thumbnails and
avatars.  There was an addition recently in master that includes a backup
and restore command.  You may want to look at trying that out if you are
able to update.  If not soon we will have a 2.6 release that will include
it.
Dan
On Oct 17, 2016 09:11, "Paolo Corti" <pcorti at gmail.com> wrote:
> Hi
> I am not familiar with the directories where the package installer put
> things, but yes, these are all the things that you need to backup.
> Make sure to backup the data PostgreSQL database (together with the
> Django one) in case you are using PostgreSQL as a data store.
> p
> On Mon, Oct 17, 2016 at 10:06 AM, LEOPOLDO JAVIER NUNEZ DE SANTIAGO .
> <lnunezde at guanajuato.gob.mx> wrote:
> > Hi, It is still validates this configuration to create a backup of your
> > entire system GeoNode 2.4:
> > Creating a backup
> > #. Make a backup of the GeoNode database (PostgreSQL needs to be
> running)::
> >     sudo -u postgres -i pg_dump -c -Fc geonode > geonodedb.backup
> > #. Stop all services::
> >     sudo /etc/init.d/apache2 stop
> >     sudo /etc/init.d/tomcat6 stop
> >     sudo /etc/init.d/postgresql-8.4 stop
> > #. Backup Geonode config & GeoServer data directory::
> >     tar -cvzf geonodeConfigBackup.tgz /etc/geonode
> >     tar -cvzf geonodeDataBackup.tgz  /var/lib/geoserver/geonode-data/
> > #. In addition, any templates, design changes, and/or CSS files will also
> > need to be captured.
> > #. Restart all services::
> >     sudo /etc/init.d/apache2 start
> >     sudo /etc/init.d/tomcat6 start
> >     sudo /etc/init.d/postgresql-8.4 start
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161017/4fc8edaf/attachment.html>
More information about the geonode-users mailing list
