[GeoNode-users] Geonode Error
WAI TING CHAN
waichan at berkeley.edu
Fri Oct 28 14:32:37 PDT 2016
Hi Francesco,
I am not too familiar with django and how does it work. Could you explain
what do you mean by "django has released a session token"? Thank you so
much.
Sincerely,
Isabel
On Fri, Oct 28, 2016 at 12:45 AM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Ok that's fine. Then make sure that geoserver is properly configured for
> authentication/authorization. From the image I see the internal hostname of
> you aws instance is not being accepted. If you access geoserver on the
> public address from the browser do you get the user automatically logged in
> after django has released a session token?
> Sent from Nylas N1
> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-87e06c7d-7160/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=d2FpY2hhbkBiZXJrZWxleS5lZHU=>,
> the extensible, open source mail client.
> On ott 28 2016, at 8:30 am, WAI TING CHAN <waichan at berkeley.edu> wrote:
>> Hi Francesco,
>> Ambika has the "superuser status", so she should have access to all the
>> layers. I also had the same error using the admin account too.
>> Sincerely,
>> Isabel
>> On Thu, Oct 27, 2016 at 9:55 PM, "xbartolone at gmail.com" <
>> xbartolone at gmail.com> wrote:
>> Hi Tina,
>> Are you sure that the user is authorized to edit that specific layer?
>> Francesco
>> Inviato da TypeApp
>> <http://www.typeapp.com/r&r=d2FpY2hhbkBiZXJrZWxleS5lZHU=> per iPhone
>> On 28 ott 2016 at 01:44, Tina Huang <tina at ecocitybuilders.org> wrote:
>> Hi,
>> One of our interns, Ambika (cc'ing here) ran into an error when she
>> tried to edit layers on Geonode. Please see a screenshot for exact error.
>> Do you have an idea for a solution? Much appreciated your insights! Thanks!
>> Best,
>> Tina
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=d2FpY2hhbkBiZXJrZWxleS5lZHU=>
>> Wai Ting Isabel Chan
>> B.S in Environmental Science, B.A in Sustainable Environmental Design
>> U.C Berkeley, Class of 2016
>> (650) 636-6782
(650) 636-6782
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161028/73d63163/attachment.html>
More information about the geonode-users
