[GeoNode-users] Geonode Error
    xbartolone@gmail.com
    xbartolone at gmail.com
    Fri Oct 28 21:42:10 PDT 2016
Hi Isabel,
Don't worry, you should try to login to geonode and then access geoserver from there. If you find the user directly authenticated into this latter then the configuration is correct.
Francesco
Inviato da TypeApp per iPhone
On 28 ott 2016 at 23:33, WAI TING CHAN <waichan at berkeley.edu> wrote:
Hi Francesco,
I am not too familiar with django and how does it work. Could you explain what do you mean by "django has released a session token"? Thank you so much.
Sincerely,
Isabel
On Fri, Oct 28, 2016 at 12:45 AM, Francesco Bartoli <xbartolone at gmail.com> wrote:
Ok that's fine. Then make sure that geoserver is properly configured for authentication/authorization. From the image I see the internal hostname of you aws instance is not being accepted. If you access geoserver on the public address from the browser do you get the user automatically logged in after django has released a session token?
Sent from Nylas N1, the extensible, open source mail client.
On ott 28 2016, at 8:30 am, WAI TING CHAN <waichan at berkeley.edu> wrote:
Hi Francesco,
Ambika has the "superuser status", so she should have access to all the layers. I also had the same error using the admin account too.
Sincerely,
Isabel
On Thu, Oct 27, 2016 at 9:55 PM, "xbartolone at gmail.com" <xbartolone at gmail.com> wrote:
Hi Tina,
Are you sure that the user is authorized to edit that specific layer?
Francesco
On 28 ott 2016 at 01:44, Tina Huang <tina at ecocitybuilders.org> wrote:
  One of our interns, Ambika (cc'ing here) ran into an error when she tried to edit layers on Geonode. Please see a screenshot for exact error. Do you have an idea for a solution? Much appreciated your insights! Thanks!
Best,
Tina
geonode-users mailing list
geonode-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geonode-users
Wai Ting Isabel Chan
B.S in Environmental Science, B.A in Sustainable Environmental Design
U.C Berkeley, Class of 2016
(650) 636-6782
(650) 636-6782
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161029/3bf27037/attachment.html>
More information about the geonode-users
