[GeoNode-users] Edit option for CSV,KML file upload
Naresh N naresh919 at gmail.com
Thu Sep 22 22:48:02 PDT 2016
Dear Simone Dalmasso,
 I have verified DB ,the CSV  uploaded properly. And when we click on Map
composer i could able to see post WFS request and response contained the
features geometries along with attributes. Please help me to resolve the
issue. Please find the attached my settings.py and local settings.py file..
Is any settings issue?
I* have observed one more issue, is it bug or settings issue, please help
me to resolve.*
After uploading shapefile, if we use *Edit option and modify/Create  to
modify/create the geometry- modified/Created  geometry is not visible ,
some times visible in few zoom levels and some times partially*. Even if
newly created/modified feature is  invisible and if we click on it again,
the geometry is appearing with blue color for edit option, but once you
change  it is disappearing.Please help me to resolve the issue.
On Fri, Sep 16, 2016 at 7:06 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Can you check if they are loaded correctly in the db with geoserver?
> Also, when you open the map composer it issue an edit-cheeck http request
> to geonode. Can you take a look at what's the result of it?
> 2016-09-16 12:44 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>   Thank a lot for quick response. Yes I am using postgres database. If I
>> load shapefile  ,then Create, Modify options are working fine. But in case
>> of CSV and KML files the issues which I mentioned in my earlier mail is
>> coming. Please any idea to resolve.
>> Thanks&Regards,
>> Naresh
>> On Fri, Sep 16, 2016 at 2:22 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi, are you using a postgres database to store your data? Make sure they
>>> are correctly loaded there by geoserver otherwise the feature editing is
>>> not available.
>>> 2016-09-16 9:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Geonode Users,
>>>>  I have installed Geonode in Windows environment. To Upload CSV, KML
>>>> files the following is included in local_setting.py and able to upload csv,
>>>> kml files.
>>>> UPLOADER = {
>>>>     'BACKEND': 'geonode.rest',
>>>>     'OPTIONS': {
>>>>         'TIME_ENABLED': False,
>>>>         'GEOGIG_ENABLED': False,
>>>>     'BACKEND': 'geonode.importer',
>>>>     'OPTIONS': {
>>>> When we  visualize uploaded  file through the Explore Layers option and
>>>> if we select Edit Data option the following *issues *are facing
>>>> 1. In Map window section --> Edit --> *Create option* is in *grey out
>>>> mode* .i.e not able to select
>>>> 2. If we click on* Modify option* and click on features option then *feature
>>>> info option is not visible* and not able to edit the feature geometry
>>>> and attributes information. I could able to find through the firebug that
>>>> the  features information is returning to browser but popup is not visible.
>>>> Please find the attached  screenshot
>>>> Please suggest me to resolve the issue.
>>>> Thanks&Regards,
>>>> Naresh
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160923/217f5508/attachment-0001.html>
# -*- coding: utf-8 -*-
# Copyright (C) 2012 OpenPlans
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
# Django settings for the GeoNode project.
import os
from kombu import Queue
import geonode
from geonode.celery_app import app  # flake8: noqa
# General Django development settings
# GeoNode Version
VERSION = geonode.get_version()
# Defines the directory that contains the settings file as the PROJECT_ROOT
# It is used for relative settings elsewhere.
PROJECT_ROOT = os.path.abspath(os.path.dirname(__file__))
# Setting debug to true makes Django serve static media and
# present pretty error pages.
DEBUG = TEMPLATE_DEBUG = True
# Set to True to load non-minified versions of (static) client dependencies
# Requires to set-up Node and tools that are required for static development
# otherwise it will raise errors for the missing non-minified dependencies
DEBUG_STATIC = False
# This is needed for integration tests, they require
# geonode to be listening for GeoServer auth requests.
os.environ['DJANGO_LIVE_TEST_SERVER_ADDRESS'] = 'localhost:8000'
# Defines settings for development
DATABASES = {
    'default': {
        'ENGINE': 'django.db.backends.sqlite3',
        'NAME': os.path.join(PROJECT_ROOT, 'development.db'),
    # vector datastore for uploads
    # 'datastore' : {
    #    'ENGINE': 'django.contrib.gis.db.backends.postgis',
    #    'NAME': '',
    #    'USER' : '',
    #    'PASSWORD' : '',
    #    'HOST' : '',
    #    'PORT' : '',
# Local time zone for this installation. Choices can be found here:
# http://en.wikipedia.org/wiki/List_of_tz_zones_by_name
# although not all choices may be available on all operating systems.
# If running in a Windows environment this must be set to the same as your
# system time zone.
TIME_ZONE = 'America/Chicago'
# Language code for this installation. All choices can be found here:
# http://www.i18nguy.com/unicode/language-identifiers.html
LANGUAGE_CODE = 'en'
LANGUAGES = (
    ('en', 'English'),
    ('es', 'Español'),
    ('it', 'Italiano'),
    ('fr', 'Français'),
    ('de', 'Deutsch'),
    ('el', 'Ελληνικά'),
    ('id', 'Bahasa Indonesia'),
    ('zh-cn', '中文'),
    ('ja', '日本語'),
    ('fa', 'Persian'),
    ('ar', 'Arabic'),
    ('bn', 'Bengali'),
    ('ne', 'Nepali'),
    ('sq', 'Albanian'),
    ('af', 'Afrikaans'),
    ('sw', 'Swahili'),
    ('pt', 'Portuguese'),
    ('ru', 'Russian'),
    ('vi', 'Vietnamese'),
    ('ko', '한국어'),
    ('am', 'Amharic'),
    ('km', 'Khmer'),
    ('pl', 'Polish'),
    ('sv', 'Swedish'),
    ('th', 'ไทย'),
    ('uk', 'Ukranian'),
    ('si', 'Sinhala'),
    ('ta', 'Tamil'),
    ('tl', 'Tagalog'),
EXTRA_LANG_INFO = {
    'am': {
        'bidi': False,
        'code': 'am',
        'name': 'Amharic',
        'name_local': 'Amharic',
    'tl': {
        'bidi': False,
        'code': 'tl',
        'name': 'Tagalog',
        'name_local': 'tagalog',
    'ta': {
        'bidi': False,
        'code': 'ta',
        'name': 'Tamil',
        'name_local': u'tamil',
    'si': {
        'bidi': False,
        'code': 'si',
        'name': 'Sinhala',
        'name_local': 'sinhala',
AUTH_USER_MODEL = 'people.Profile'
# If you set this to False, Django will make some optimizations so as not
# to load the internationalization machinery.
USE_I18N = True
MODELTRANSLATION_LANGUAGES = ['en', ]
MODELTRANSLATION_DEFAULT_LANGUAGE = 'en'
MODELTRANSLATION_FALLBACK_LANGUAGES = ('en',)
# Absolute path to the directory that holds media.
# Example: "/home/media/media.lawrence.com/"
MEDIA_ROOT = os.path.join(PROJECT_ROOT, "uploaded")
# URL that handles the media served from MEDIA_ROOT. Make sure to use a
# trailing slash if there is a path component (optional in other cases).
# Examples: "http://media.lawrence.com", "http://example.com/media/"
MEDIA_URL = "/uploaded/"
# Absolute path to the directory that holds static files like app media.
# Example: "/home/media/media.lawrence.com/apps/"
STATIC_ROOT = os.path.join(PROJECT_ROOT, "static_root")
# URL that handles the static files like app media.
# Example: "http://media.lawrence.com"
STATIC_URL = "/static/"
# Additional directories which hold static files
STATICFILES_DIRS = [
    os.path.join(PROJECT_ROOT, "static"),
# List of finder classes that know how to find static files in
# various locations.
STATICFILES_FINDERS = (
    'django.contrib.staticfiles.finders.FileSystemFinder',
    'django.contrib.staticfiles.finders.AppDirectoriesFinder',
    #    'django.contrib.staticfiles.finders.DefaultStorageFinder',
# Note that Django automatically includes the "templates" dir in all the
# INSTALLED_APPS, se there is no need to add maps/templates or admin/templates
TEMPLATE_DIRS = (
    os.path.join(PROJECT_ROOT, "templates"),
# Location of translation files
LOCALE_PATHS = (
    os.path.join(PROJECT_ROOT, "locale"),
# Make this unique, and don't share it with anybody.
SECRET_KEY = 'myv-y4#7j-d*p-__ at j#*3z@!y24fz8%^z2v6atuy4bo9vqr1_a'
# Location of url mappings
ROOT_URLCONF = 'geonode.urls'
# Site id in the Django sites framework
SITE_ID = 1
# Login and logout urls override
LOGIN_URL = '/account/login/'
LOGOUT_URL = '/account/logout/'
# Documents application
ALLOWED_DOCUMENT_TYPES = [
    'doc', 'docx', 'gif', 'jpg', 'jpeg', 'ods', 'odt', 'odp', 'pdf', 'png', 'ppt',
    'pptx', 'rar', 'sld', 'tif', 'tiff', 'txt', 'xls', 'xlsx', 'xml', 'zip', 'gz','csv','txt'
MAX_DOCUMENT_SIZE = 2  # MB
# DOCUMENT_TYPE_MAP and DOCUMENT_MIMETYPE_MAP update enumerations in
# documents/enumerations.py and should only
# need to be uncommented if adding other types
# to settings.ALLOWED_DOCUMENT_TYPES
# DOCUMENT_TYPE_MAP = {}
# DOCUMENT_MIMETYPE_MAP = {}
GEONODE_APPS = (
    # GeoNode internal apps
    'geonode.people',
    'geonode.base',
    'geonode.layers',
    'geonode.maps',
    'geonode.proxy',
    'geonode.security',
    'geonode.social',
    'geonode.catalogue',
    'geonode.documents',
    'geonode.api',
    'geonode.groups',
    'geonode.services',
    # GeoServer Apps
    # Geoserver needs to come last because
    # it's signals may rely on other apps' signals.
    'geonode.geoserver',
    'geonode.upload',
    'geonode.tasks'
GEONODE_CONTRIB_APPS = (
    # GeoNode Contrib Apps
    'geonode.contrib.dynamic',
    'geonode.contrib.exif',
    'geonode.contrib.favorite',
    'geonode.contrib.geogig',
    'geonode.contrib.geosites',
    'geonode.contrib.nlp',
    'geonode.contrib.slack'
# Uncomment the following line to enable contrib apps
# GEONODE_APPS = GEONODE_APPS + GEONODE_CONTRIB_APPS
INSTALLED_APPS = (
    # Boostrap admin theme
    # 'django_admin_bootstrapped.bootstrap3',
    # 'django_admin_bootstrapped',
    # Apps bundled with Django
    'django.contrib.auth',
    'django.contrib.contenttypes',
    'django.contrib.sessions',
    'django.contrib.sites',
    'django.contrib.admin',
    'django.contrib.sitemaps',
    'django.contrib.staticfiles',
    'django.contrib.messages',
    'django.contrib.humanize',
    'django.contrib.gis',
    # Third party apps
    # Utility
    'pagination',
    'taggit',
    'friendlytagloader',
    'geoexplorer',
    'leaflet',
    'django_extensions',
    # 'haystack',
    'autocomplete_light',
    'mptt',
    'modeltranslation',
    'djcelery',
    # Theme
    "pinax_theme_bootstrap_account",
    "pinax_theme_bootstrap",
    'django_forms_bootstrap',
    # Social
    'account',
    'avatar',
    'dialogos',
    'agon_ratings',
    #'notification',
    'announcements',
    'actstream',
    'user_messages',
    'tastypie',
    'polymorphic',
    'guardian',
) + GEONODE_APPS
LOGGING = {
    'version': 1,
    'disable_existing_loggers': True,
    'formatters': {
        'verbose': {
            'format': '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d %(message)s'
        'simple': {
            'format': '%(message)s',
    'filters': {
        'require_debug_false': {
            '()': 'django.utils.log.RequireDebugFalse'
    'handlers': {
        'null': {
            'level': 'ERROR',
            'class': 'django.utils.log.NullHandler',
        'console': {
            'level': 'ERROR',
            'class': 'logging.StreamHandler',
            'formatter': 'simple'
        'mail_admins': {
            'level': 'ERROR', 'filters': ['require_debug_false'],
            'class': 'django.utils.log.AdminEmailHandler',
    "loggers": {
        "django": {
            "handlers": ["console"], "level": "ERROR", },
        "geonode": {
        "gsconfig.catalog": {
        "owslib": {
        "pycsw": {
# Customizations to built in Django settings required by GeoNode
TEMPLATE_CONTEXT_PROCESSORS = (
    'django.contrib.auth.context_processors.auth',
    'django.core.context_processors.debug',
    'django.core.context_processors.i18n',
    "django.core.context_processors.tz",
    'django.core.context_processors.media',
    "django.core.context_processors.static",
    'django.core.context_processors.request',
    'django.contrib.messages.context_processors.messages',
    'account.context_processors.account',
    # The context processor below adds things like SITEURL
    # and GEOSERVER_BASE_URL to all pages that use a RequestContext
    'geonode.context_processors.resource_urls',
    'geonode.geoserver.context_processors.geoserver_urls',
MIDDLEWARE_CLASSES = (
    'django.middleware.common.CommonMiddleware',
    'django.contrib.sessions.middleware.SessionMiddleware',
    'django.contrib.messages.middleware.MessageMiddleware',
    # The setting below makes it possible to serve different languages per
    # user depending on things like headers in HTTP requests.
    'django.middleware.locale.LocaleMiddleware',
    'pagination.middleware.PaginationMiddleware',
    'django.middleware.csrf.CsrfViewMiddleware',
    'django.contrib.auth.middleware.AuthenticationMiddleware',
    'django.middleware.clickjacking.XFrameOptionsMiddleware',
    # This middleware allows to print private layers for the users that have
    # the permissions to view them.
    # It sets temporary the involved layers as public before restoring the permissions.
    # Beware that for few seconds the involved layers are public there could be risks.
    # 'geonode.middleware.PrintProxyMiddleware',
# Replacement of default authentication backend in order to support
# permissions per object.
AUTHENTICATION_BACKENDS = (
    'django.contrib.auth.backends.ModelBackend',
    'guardian.backends.ObjectPermissionBackend',
ANONYMOUS_USER_ID = -1
GUARDIAN_GET_INIT_ANONYMOUS_USER = 'geonode.people.models.get_anonymous_user_instance'
# Whether the uplaoded resources should be public and downloadable by default or not
DEFAULT_ANONYMOUS_VIEW_PERMISSION = True
DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION = True
# Settings for default search size
DEFAULT_SEARCH_SIZE = 10
# Settings for third party apps
# Agon Ratings
AGON_RATINGS_CATEGORY_CHOICES = {
    "maps.Map": {
        "map": "How good is this map?"
    "layers.Layer": {
        "layer": "How good is this layer?"
    "documents.Document": {
        "document": "How good is this document?"
# Activity Stream
ACTSTREAM_SETTINGS = {
    'MODELS': (
        'people.Profile',
        'layers.layer',
        'maps.map',
        'dialogos.comment',
        'documents.document',
        'services.service'),
    'FETCH_RELATIONS': True,
    'USE_PREFETCH': False,
    'USE_JSONFIELD': True,
    'GFK_FETCH_DEPTH': 1,
# Settings for Social Apps
REGISTRATION_OPEN = False
ACCOUNT_EMAIL_CONFIRMATION_EMAIL = False
ACCOUNT_EMAIL_CONFIRMATION_REQUIRED = False
ACCOUNT_APPROVAL_REQUIRED = False
# Email for users to contact admins.
THEME_ACCOUNT_CONTACT_EMAIL = 'admin at example.com'
# Test Settings
# Setting a custom test runner to avoid running the tests for
# some problematic 3rd party apps
TEST_RUNNER = 'django_nose.NoseTestSuiteRunner'
# Arguments for the test runner
NOSE_ARGS = [
    '--nocapture',
    '--detailed-errors',
# GeoNode specific settings
SITEURL = "http://localhost:8000/"
USE_QUEUE = False
DEFAULT_WORKSPACE = 'geonode'
CASCADE_WORKSPACE = 'geonode'
OGP_URL = "http://geodata.tufts.edu/solr/select"
# Topic Categories list should not be modified (they are ISO). In case you
# absolutely need it set to True this variable
MODIFY_TOPICCATEGORY = False
MISSING_THUMBNAIL = 'geonode/img/missing_thumb.png'
# Search Snippet Cache Time in Seconds
CACHE_TIME = 0
# OGC (WMS/WFS/WCS) Server Settings
OGC_SERVER = {
    'default': {
        'BACKEND': 'geonode.geoserver',
        'LOCATION': 'http://localhost:8080/geoserver/',
        # PUBLIC_LOCATION needs to be kept like this because in dev mode
        # the proxy won't work and the integration tests will fail
        # the entire block has to be overridden in the local_settings
        'PUBLIC_LOCATION': 'http://localhost:8080/geoserver/',
        'USER': 'admin',
        'PASSWORD': 'geoserver',
        'MAPFISH_PRINT_ENABLED': True,
        'PRINT_NG_ENABLED': True,
        'GEONODE_SECURITY_ENABLED': True,
        'WMST_ENABLED': False,
        'BACKEND_WRITE_ENABLED': True,
        'WPS_ENABLED': False,
        'LOG_FILE': '%s/geoserver/data/logs/geoserver.log' % os.path.abspath(os.path.join(PROJECT_ROOT, os.pardir)),
        # Set to name of database in DATABASES dictionary to enable
        'DATASTORE': '',  # 'datastore',
        'TIMEOUT': 10  # number of seconds to allow for HTTP requests
# Uploader Settings
UPLOADER = {
    'OPTIONS': {
        'TIME_ENABLED': True,
	'BACKEND' : 'geonode.importer',
    'OPTIONS' : {
# CSW settings
CATALOGUE = {
    'default': {
        # The underlying CSW implementation
        # default is pycsw in local mode (tied directly to GeoNode Django DB)
        'ENGINE': 'geonode.catalogue.backends.pycsw_local',
        # pycsw in non-local mode
        # 'ENGINE': 'geonode.catalogue.backends.pycsw_http',
        # GeoNetwork opensource
        # 'ENGINE': 'geonode.catalogue.backends.geonetwork',
        # deegree and others
        # 'ENGINE': 'geonode.catalogue.backends.generic',
        # The FULLY QUALIFIED base url to the CSW instance for this GeoNode
        'URL': '%scatalogue/csw' % SITEURL,
        # 'URL': 'http://localhost:8080/geonetwork/srv/en/csw',
        # 'URL': 'http://localhost:8080/deegree-csw-demo-3.0.4/services',
        # login credentials (for GeoNetwork)
        # 'USER': 'admin',
        # 'PASSWORD': 'admin',
# pycsw settings
PYCSW = {
    # pycsw configuration
    'CONFIGURATION': {
        # uncomment / adjust to override server config system defaults
        #'server': {
        #    'maxrecords': '10',
        #    'pretty_print': 'true',
        #    'federatedcatalogues': 'http://catalog.data.gov/csw'
        'metadata:main': {
            'identification_title': 'GeoNode Catalogue',
            'identification_abstract': 'GeoNode is an open source platform that facilitates the creation, sharing, ' \
            'and collaborative use of geospatial data',
            'identification_keywords': 'sdi,catalogue,discovery,metadata,GeoNode',
            'identification_keywords_type': 'theme',
            'identification_fees': 'None',
            'identification_accessconstraints': 'None',
            'provider_name': 'Organization Name',
            'provider_url': SITEURL,
            'contact_name': 'Lastname, Firstname',
            'contact_position': 'Position Title',
            'contact_address': 'Mailing Address',
            'contact_city': 'City',
            'contact_stateorprovince': 'Administrative Area',
            'contact_postalcode': 'Zip or Postal Code',
            'contact_country': 'Country',
            'contact_phone': '+xx-xxx-xxx-xxxx',
            'contact_fax': '+xx-xxx-xxx-xxxx',
            'contact_email': 'Email Address',
            'contact_url': 'Contact URL',
            'contact_hours': 'Hours of Service',
            'contact_instructions': 'During hours of service. Off on weekends.',
            'contact_role': 'pointOfContact',
        'metadata:inspire': {
            'enabled': 'true',
            'languages_supported': 'eng,gre',
            'default_language': 'eng',
            'date': 'YYYY-MM-DD',
            'gemet_keywords': 'Utility and governmental services',
            'conformity_service': 'notEvaluated',
            'contact_name': 'Organization Name',
            'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD',
# GeoNode javascript client configuration
# default map projection
# Note: If set to EPSG:4326, then only EPSG:4326 basemaps will work.
#DEFAULT_MAP_CRS = "EPSG:900913"
DEFAULT_MAP_CRS = "EPSG:4326"
# Where should newly created maps be focused?
DEFAULT_MAP_CENTER = (22, 77)
# How tightly zoomed should newly created maps be?
# 0 = entire world;
# maximum zoom is between 12 and 15 (for Google Maps, coverage varies by area)
DEFAULT_MAP_ZOOM = 0
MAP_BASELAYERS = [{
    "source": {"ptype": "gxp_olsource"},
    "type": "OpenLayers.Layer",
    "args": ["No background"],
    "visibility": False,
    "fixed": True,
    "group":"background"
    "source": {"ptype": "gxp_osmsource"},
    "type": "OpenLayers.Layer.OSM",
    "name": "mapnik",
    "fixed": True,
    "group": "background"
    "source": {"ptype": "gxp_mapquestsource"},
    "name": "osm",
    "group": "background",
    "visibility": True
    "name": "naip",
    "visibility": False
    "source": {"ptype": "gxp_mapboxsource"},
SOCIAL_BUTTONS = True
SOCIAL_ORIGINS = [{
    "label":"Email",
    "url":"mailto:?subject={name}&body={url}",
    "css_class":"email"
    "label":"Facebook",
    "url":"http://www.facebook.com/sharer.php?u={url}",
    "css_class":"fb"
    "label":"Twitter",
    "url":"https://twitter.com/share?url={url}&hashtags={hashtags}",
    "css_class":"tw"
    "label":"Google +",
    "url":"https://plus.google.com/share?url={url}",
    "css_class":"gp"
#CKAN Query String Parameters names pulled from
#https://github.com/ckan/ckan/blob/2052628c4a450078d58fb26bd6dc239f3cc68c3e/ckan/logic/action/create.py#L43
CKAN_ORIGINS = [{
    "label":"Humanitarian Data Exchange (HDX)",
    "url":"https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}&notes={abstract}&caveats={caveats}",
    "css_class":"hdx"
#SOCIAL_ORIGINS.extend(CKAN_ORIGINS)
# Setting TWITTER_CARD to True will enable Twitter Cards
# https://dev.twitter.com/cards/getting-started
# Be sure to replace @GeoNode with your organization or site's twitter handle.
TWITTER_CARD = True
TWITTER_SITE = '@GeoNode'
TWITTER_HASHTAGS = ['geonode']
OPENGRAPH_ENABLED = True
# Enable Licenses User Interface
# Regardless of selection, license field stil exists as a field in the Resourcebase model.
# Detail Display: above, below, never
# Metadata Options: verbose, light, never
LICENSES = {
    'ENABLED': True,
    'DETAIL': 'above',
    'METADATA': 'verbose',
SRID = {
    'DETAIL': 'never',
SESSION_SERIALIZER = 'django.contrib.sessions.serializers.PickleSerializer'
# Require users to authenticate before using Geonode
LOCKDOWN_GEONODE = False
# Add additional paths (as regular expressions) that don't require
# authentication.
AUTH_EXEMPT_URLS = ()
# A tuple of hosts the proxy can send requests to.
PROXY_ALLOWED_HOSTS = ()
# The proxy to use when making cross origin requests.
PROXY_URL = '/proxy/?url=' if DEBUG else None
# Haystack Search Backend Configuration.  To enable, first install the following:
# - pip install django-haystack
# - pip install pyelasticsearch
# Set HAYSTACK_SEARCH to True
# Run "python manage.py rebuild_index"
HAYSTACK_SEARCH = False
# Avoid permissions prefiltering
SKIP_PERMS_FILTER = False
# Update facet counts from Haystack
HAYSTACK_FACET_COUNTS = False
# HAYSTACK_CONNECTIONS = {
#    'default': {
#        'ENGINE': 'haystack.backends.elasticsearch_backend.ElasticsearchSearchEngine',
#        'URL': 'http://127.0.0.1:9200/',
#        'INDEX_NAME': 'geonode',
# HAYSTACK_SIGNAL_PROCESSOR = 'haystack.signals.RealtimeSignalProcessor'
# HAYSTACK_SEARCH_RESULTS_PER_PAGE = 20
# Available download formats
DOWNLOAD_FORMATS_METADATA = [
    'Atom', 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO',
DOWNLOAD_FORMATS_VECTOR = [
    'JPEG', 'PDF', 'PNG', 'Zipped Shapefile', 'GML 2.0', 'GML 3.1.1', 'CSV',
    'Excel', 'GeoJSON', 'KML', 'View in Google Earth', 'Tiles',
DOWNLOAD_FORMATS_RASTER = [
    'JPEG',
    'PDF',
    'PNG',
    'ArcGrid',
    'GeoTIFF',
    'Gtopo30',
    'ImageMosaic',
    'KML',
    'Tiles',
ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE = False
TASTYPIE_DEFAULT_FORMATS = ['json']
# gravatar settings
AUTO_GENERATE_AVATAR_SIZES = (20, 32, 80, 100, 140, 200)
# notification settings
NOTIFICATION_LANGUAGE_MODULE = "account.Account"
# Number of results per page listed in the GeoNode search pages
CLIENT_RESULTS_LIMIT = 100
# Number of items returned by the apis 0 equals no limit
API_LIMIT_PER_PAGE = 0
API_INCLUDE_REGIONS_COUNT = False
LEAFLET_CONFIG = {
    'TILES': [
        # Find tiles at:
        # http://leaflet-extras.github.io/leaflet-providers/preview/
        # Stamen toner lite.
        ('Watercolor',
         'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png',
         'Map tiles by <a href="http://stamen.com">Stamen Design</a>, \
         <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> — Map data © \
         <a href="http://openstreetmap.org">OpenStreetMap</a> contributors, \
         <a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>'),
        ('Toner Lite',
         'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png',
    'PLUGINS': {
        'esri-leaflet': {
            'js': 'lib/js/esri-leaflet.js?v=%s' % VERSION,
            'auto-include': True,
        'leaflet-fullscreen': {
            'css': 'lib/css/leaflet.fullscreen.css?v=%s' % VERSION,
            'js': 'lib/js/Leaflet.fullscreen.min.js?v=%s' % VERSION,
# option to enable/disable resource unpublishing for administrators
RESOURCE_PUBLISHING = False
# Settings for EXIF contrib app
EXIF_ENABLED = False
# Settings for NLP contrib app
NLP_ENABLED = False
NLP_LOCATION_THRESHOLD = 1.0
NLP_LIBRARY_PATH = "/opt/MITIE/mitielib"
NLP_MODEL_PATH = "/opt/MITIE/MITIE-models/english/ner_model.dat"
# Settings for Slack contrib app
SLACK_ENABLED = False
SLACK_WEBHOOK_URLS = [
    "https://hooks.slack.com/services/T000/B000/XX"
CACHES = {
    # DUMMY CACHE FOR DEVELOPMENT
    'default': {
        'BACKEND': 'django.core.cache.backends.dummy.DummyCache',
    # MEMCACHED EXAMPLE
    # 'default': {
    #     'BACKEND': 'django.core.cache.backends.memcached.MemcachedCache',
    #     'LOCATION': '127.0.0.1:11211',
    # FILECACHE EXAMPLE
    # 'default': {
    #     'BACKEND': 'django.core.cache.backends.filebased.FileBasedCache',
    #     'LOCATION': '/tmp/django_cache',
LAYER_PREVIEW_LIBRARY = 'geoext'
SERVICE_UPDATE_INTERVAL = 0
SEARCH_FILTERS = {
    'TEXT_ENABLED': True,
    'TYPE_ENABLED': True,
    'CATEGORIES_ENABLED': True,
    'OWNERS_ENABLED': True,
    'KEYWORDS_ENABLED': True,
    'DATE_ENABLED': True,
    'REGION_ENABLED': True,
    'EXTENT_ENABLED': True,
# Queue non-blocking notifications.
NOTIFICATION_QUEUE_ALL = False
BROKER_URL = "django://"
CELERY_ALWAYS_EAGER = True
CELERY_EAGER_PROPAGATES_EXCEPTIONS = True
CELERY_IGNORE_RESULT = True
CELERY_SEND_EVENTS = False
CELERY_RESULT_BACKEND = None
CELERY_TASK_RESULT_EXPIRES = 1
CELERY_DISABLE_RATE_LIMITS = True
CELERY_DEFAULT_QUEUE = "default"
CELERY_DEFAULT_EXCHANGE = "default"
CELERY_DEFAULT_EXCHANGE_TYPE = "direct"
CELERY_DEFAULT_ROUTING_KEY = "default"
CELERY_CREATE_MISSING_QUEUES = True
CELERY_IMPORTS = (
    'geonode.tasks.deletion',
    'geonode.tasks.update',
    'geonode.tasks.email'
CELERY_QUEUES = [
    Queue('default', routing_key='default'),
    Queue('cleanup', routing_key='cleanup'),
    Queue('update', routing_key='update'),
    Queue('email', routing_key='email'),
import djcelery
djcelery.setup_loader()
# Load more settings from a file called local_settings.py if it exists
try:
    from local_settings import *  # noqa
except ImportError:
    pass
try:
    BING_LAYER = {
        "source": {
            "ptype": "gxp_bingsource",
            "apiKey": BING_API_KEY
        "name": "AerialWithLabels",
        "fixed": True,
    MAP_BASELAYERS.append(BING_LAYER)
except NameError:
    print "Not enabling BingMaps base layer as a BING_API_KEY is not defined in local_settings.py file."
if LOCKDOWN_GEONODE:
    MIDDLEWARE_CLASSES = MIDDLEWARE_CLASSES + \
        ('geonode.security.middleware.LoginRequiredMiddleware',)
#for windows users check if they didn't set GEOS and GDAL in local_settings.py
#maybe they set it as a windows environment
if os.name == 'nt':
    if not "GEOS_LIBRARY_PATH" in locals() or not "GDAL_LIBRARY_PATH" in locals():
        if os.environ.get("GEOS_LIBRARY_PATH", None) \
            and os.environ.get("GDAL_LIBRARY_PATH", None):
            GEOS_LIBRARY_PATH = os.environ.get('GEOS_LIBRARY_PATH')
            GDAL_LIBRARY_PATH = os.environ.get('GDAL_LIBRARY_PATH')
        else:
            #maybe it will be found regardless if not it will throw 500 error
            from django.contrib.gis.geos import GEOSGeometry
# define the urls after the settings are overridden
if 'geonode.geoserver' in INSTALLED_APPS:
    LOCAL_GEOSERVER = {
        "source": {
            "ptype": "gxp_wmscsource",
            "url": OGC_SERVER['default']['PUBLIC_LOCATION'] + "wms",
            "restUrl": "/gs/rest"
    baselayers = MAP_BASELAYERS
    MAP_BASELAYERS = [LOCAL_GEOSERVER]
    MAP_BASELAYERS.extend(baselayers)
import os
SITEURL = "http://localhost/"
DATABASES = {
    "default": {
        "ENGINE": "django.db.backends.postgresql_psycopg2",
        "NAME": "geonode",
        "USER": "geonode",
        "PASSWORD": "geonode",
        "HOST" : "localhost",
        "PORT" : "5454",
    "datastore" : {
       "ENGINE": "django.contrib.gis.db.backends.postgis",
       "NAME": "geonode_imports",
       "USER" : "geonode",
       "PASSWORD" : "geonode",
       "PORT" : "5454",
OGC_SERVER = {
    "default": {
        "BACKEND": "geonode.geoserver",
        "LOCATION": "http://localhost:8080/geoserver/",
        "PUBLIC_LOCATION": "http://localhost/geoserver/",
        "USER": "admin",
        "PASSWORD": "geoserver",
        "MAPFISH_PRINT_ENABLED": True,
        "PRINT_NG_ENABLED": True,
        "GEONODE_SECURITY_ENABLED": True,
        "GEOGIG_ENABLED": False,
        "WMST_ENABLED": False,
        "BACKEND_WRITE_ENABLED": True,
        "WPS_ENABLED": False,
        "LOG_FILE": "%s/geoserver/data/logs/geoserver.log" % os.path.abspath(os.path.join(PROJECT_ROOT, os.pardir)),
        "DATASTORE": "datastore",
        "TIMEOUT": 10  # number of seconds to allow for HTTP requests
REGISTRATION_OPEN=True
MAP_BASELAYERS = [{
    "fixed": True,
    "name": "mapnik",
    "fixed": True,
    "source": {"ptype": "gx_olsource"},
    "type":"OpenLayers.Layer.WMS",
    "group":"background",
    "fixed": True,
    "args":[
      "Bhuvan Satellite Imagery",
      "http://bhuvan3.nrsc.gov.in/tilecache/tilecache.py",
        "layers":["bhuvan_imagery"]
    "visibility": True,
    "fixed": True,
    "args":[
      "Bhuvan Base Map",
      "http://bhuvannuis.nrsc.gov.in/bhuvan/gwc/service/wms/",
        "layers":["india3"]
More information about the geonode-users mailing list
