[GeoNode-users] Edit option for CSV,KML file upload
Simone Dalmasso simone.dalmasso at gmail.com
Thu Sep 22 23:05:47 PDT 2016
I think that we can file a bug for the editing issue. Do you mind to do it?
https://github.com/GeoNode/geonode/issues/new. We will take a look asap.
For the layer disappearing, by default GeoNode uses a cached version of the
layers so in you r case when editing them the cache is not updated. You can
disable the cache for specific layers or disable the direct cache
integration in the geoserver UI  -> tile cache tab
2016-09-23 7:48 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone Dalmasso,
>  I have verified DB ,the CSV  uploaded properly. And when we click on Map
> composer i could able to see post WFS request and response contained the
> features geometries along with attributes. Please help me to resolve the
> issue. Please find the attached my settings.py and local settings.py file..
> Is any settings issue?
> I* have observed one more issue, is it bug or settings issue, please help
> me to resolve.*
> After uploading shapefile, if we use *Edit option and modify/Create  to
> modify/create the geometry- modified/Created  geometry is not visible ,
> some times visible in few zoom levels and some times partially*. Even if
> newly created/modified feature is  invisible and if we click on it again,
> the geometry is appearing with blue color for edit option, but once you
> change  it is disappearing.Please help me to resolve the issue.
> On Fri, Sep 16, 2016 at 7:06 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Can you check if they are loaded correctly in the db with geoserver?
>> Also, when you open the map composer it issue an edit-cheeck http request
>> to geonode. Can you take a look at what's the result of it?
>> 2016-09-16 12:44 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>   Thank a lot for quick response. Yes I am using postgres database. If I
>>> load shapefile  ,then Create, Modify options are working fine. But in case
>>> of CSV and KML files the issues which I mentioned in my earlier mail is
>>> coming. Please any idea to resolve.
>>> Thanks&Regards,
>>> Naresh
>>> On Fri, Sep 16, 2016 at 2:22 PM, Simone Dalmasso <
>>>> Hi, are you using a postgres database to store your data? Make sure
>>>> they are correctly loaded there by geoserver otherwise the feature editing
>>>> is not available.
>>>> 2016-09-16 9:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Geonode Users,
>>>>>  I have installed Geonode in Windows environment. To Upload CSV, KML
>>>>> files the following is included in local_setting.py and able to upload csv,
>>>>> kml files.
>>>>> UPLOADER = {
>>>>>     'BACKEND': 'geonode.rest',
>>>>>     'OPTIONS': {
>>>>>         'TIME_ENABLED': False,
>>>>>         'GEOGIG_ENABLED': False,
>>>>>     'BACKEND': 'geonode.importer',
>>>>>     'OPTIONS': {
>>>>> When we  visualize uploaded  file through the Explore Layers option
>>>>> and if we select Edit Data option the following *issues *are facing
>>>>> 1. In Map window section --> Edit --> *Create option* is in *grey out
>>>>> mode* .i.e not able to select
>>>>> 2. If we click on* Modify option* and click on features option then *feature
>>>>> info option is not visible* and not able to edit the feature geometry
>>>>> and attributes information. I could able to find through the firebug that
>>>>> the  features information is returning to browser but popup is not visible.
>>>>> Please find the attached  screenshot
>>>>> Please suggest me to resolve the issue.
>>>>> Thanks&Regards,
>>>>> Naresh
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160923/b2a0928b/attachment.html>
More information about the geonode-users mailing list
