[GeoNode-users] Geonode updatIP error
Joseph Kariuki joehene at gmail.com
Thu Sep 29 09:44:02 PDT 2016
I have successfully installed geonode in linux ubuntu 14.04 server. However
updateip renders an error shown below
root at ip-172-31-13-39:/# geonode updateip 127.0.0.1
> Not enabling BingMaps base layer as a BING_API_KEY is not defined in
> local_settings.py file.
> Unknown command: 'updateip'
> Type 'django-admin.py help' for usage.
> root at ip-172-31-13-39:/# geonode-updateip 127.0.0.1
> Replacing SITEURL value with '127.0.0.1' in /etc/geonode/local_settings.py
> ... done.
> Adding entry for '127.0.0.1' in
> /usr/share/geoserver/data/printing/config.yaml ... done.
> Adding 127.0.0.1 to ALLOWED_HOSTS in /etc/geonode/local_settings.py ...
> '127.0.0.1' already found in ALLOWED_HOSTS list.
>  * Restarting web server
> apache2                                                        [ OK ]
> Traceback (most recent call last):
>   File "/usr/bin/django-admin.py", line 5, in <module>
>     management.execute_from_command_line()
>   File
> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
> 399, in execute_from_command_line
>     utility.execute()
>   File
> 392, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
> line 242, in run_from_argv
>     self.execute(*args, **options.__dict__)
> line 285, in execute
>     output = self.handle(*args, **options)
>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py",
> line 108, in handle
>     remove_deleted=remove_deleted)
>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
> 395, in gs_slurp
>     resources = cat.get_resources()
>   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 723,
> in get_resources
>     for ws in self.get_workspaces():
>   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 861,
> in get_workspaces
>     description = self.get_xml("%s/workspaces.xml" % self.service_url)
>   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 216,
> in get_xml
>     raise FailedRequestError("Tried to make a GET request to %s but got a
> %d status code: \n%s" % (rest_url, response.status, content))
> geoserver.catalog.FailedRequestError: Tried to make a GET request to
> http://localhost:8080/geoserver/rest/workspaces.xml but got a 404 status
> code:
> <html><head><title>Apache Tomcat/7.0.52 (Ubuntu) - Error
> report</title><style><!--H1
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;}
> H2
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;}
> H3
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;}
> BODY
> {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} B
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;}
> P
> {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A
> {color : black;}A.name {color : black;}HR {color : #525D76;}--></style>
> </head><body><h1>HTTP Status 404 - /geoserver/rest/workspaces.xml</h1><HR
> size="1" noshade="noshade"><p><b>type</b> Status
> report</p><p><b>message</b>
> <u>/geoserver/rest/workspaces.xml</u></p><p><b>description</b> <u>The
> requested resource is not available.</u></p><HR size="1"
> noshade="noshade"><h3>Apache Tomcat/7.0.52 (Ubuntu)</h3></body></html>
Kindly help.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160929/d464ac02/attachment-0001.html>
More information about the geonode-users mailing list
