[GeoNode-users] Geonode - Error on uploading layer
giuseppe musumeci
musumeci.giuseppe at gmail.com
Mon Apr 10 01:49:29 PDT 2017
I ran the installation of Geonode using the instructions at the link
http://geonode.org/geonode-workshop/foss4git2017/#/4/2
I think there are problems in the instructions about geoserver
configuration:
$ Sudo vi usr / share / geoserver / data / global.xml
I changed the default settings with those specified:
<ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
But geoserver don't works: I then set the value to
moreover i Think that to configure vagrantfile as suggested:
config.vm.network "forwarded_port", guest: 8080, host: 8080
is not correct.
Could someone tell me the correct settings values for geoserver and
vagrantfile?
2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> Dear Giuseppe,
> as already replied on the italian gfoss list you should check to follow
> from scratch the workshop http://geonode.org/
> geonode-workshop/foss4git2017/#/4/2 we did during foss4g-it. If the error
> is still happening please let me know as probably in this case the beta
> release is also affected and you can help us with your feedback.
> Thanks,
> Francesco
> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
> musumeci.giuseppe at gmail.com> ha scritto:
> Dear list I'm working with Geonode that I installed on a VM set via
> Vagrant When I try to load the shape file, I get this error: *failed to
> create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In the Apache
> error log is as follows: *ERROR: geonode.layers.views: failed to create
> /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying to google around I
> found that in the settings.py file should add the line:
> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
> that the www-data user has all permissions on the www / folder geonode
> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
> that I can't upload. Does anyone know help me?
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/c57f6c29/attachment.html>
More information about the geonode-users
