[GeoNode-users] Geonode - Error on uploading layer
giuseppe musumeci musumeci.giuseppe at gmail.com
Mon Apr 10 12:14:31 PDT 2017
I followed your instructions.
There are few differences:
in order the system works I must set
*<proxyBaseUrl>http://localhost:8001/geoserver
<http://localhost:8001/geoserver> /</proxyBaseUrl>*
instead of
*<proxyBaseUrl>http://localhost:8001/ <http://localhost:8001/>
/</proxyBaseUrl> *
I cannot edit vagrant file with *config.vm.network "forwarded_port", guest:
8080, host: **8080*
infact I get the error
"Vagrant cannot forward the specified ports on this VM, since they would
collide with some other application that is already listening on these
ports. The forwarded port to 8080 is already in use on the host machine."
If I try to upload a layer I get this error [Errno 111] Connection refused
but if I access geoserver on http://localhost:8001/geoserver/web
I see that layers have been uploaded into geoserver.
Nevethless If I watch into geonode I see that "No content created yet"
2017-04-10 16:09 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> If you have run “sudo geonode-updateip localhost:8001” then the next thing
> to do is to check again the configuration of geoserver in settings file and
> for the security in the data directory.
> Il giorno 10/apr/2017, alle ore 16:05, giuseppe musumeci <
> musumeci.giuseppe at gmail.com> ha scritto:
> I've already done it in this attempt
> Il 10/apr/2017 16:02, "Francesco Bartoli" <xbartolone at gmail.com> ha
> scritto:
>> Can you please repeat all the commands from scratch? You can do it by
>> running “vagrant destroy”
>> Il giorno 10/apr/2017, alle ore 15:46, giuseppe musumeci <
>> I installed again geonode according the tutorial
>> I run the command geonode-updateip
>> I have problem to load layers:[Errno 111] Connection refused
>> Where I'm wrong?
>> 2017-04-10 14:43 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Yes, absolutely. It looks like you missed this one
>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/6
>>> Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci <
>>> I followed all the istructions in the tutorial you send me.
>>> Is there a way to correct these errors using a command (i.e sudo
>>> geonode-updateip localhost:8001)?
>>> 2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> How did you perform the installation?
>>>> You were originally receive that error because
>>>> GEOSERVER_PUBLIC_LOCATION is wrong. It should be:
>>>> 'http://localhost:8001/geoserver'
>>>> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <
>>>> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>>>> GEOSERVER_LOCATION = os.getenv(
>>>>     'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/'
>>>> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>>>>     'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/'
>>>> From /etc/geonode/local_settings.py
>>>> GEOSERVER_URL = SITEURL + 'geoserver/'
>>>> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>> Can you double check what you have in the settings for the
>>>>> geoserver configurations?
>>>>> Sent from Nylas Pro
>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>> the most powerful email app for work
>>>>> On apr 10 2017, at 1:28 pm, giuseppe musumeci <
>>>>> musumeci.giuseppe at gmail.com> wrote:
>>>>>> Dear Francesco,
>>>>>> I followed the tutorial
>>>>>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/
>>>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> </proxyBaseUrl>
>>>>>> and not <proxyBaseUrl>http://localhost:8001/
>>>>>> </proxyBaseUrl>
>>>>>> In this way geoserver seems to work fine.
>>>>>> The problem is I'm not able to upload layers from geonode menu
>>>>>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> Giuseppe,
>>>>>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/
>>>>>> </proxyBaseUrl>" then you have to make that url reachable from your
>>>>>> host. That means
>>>>>> the configuration "config.vm.network
>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>  "forwarded_port", guest: 8080, host: 8080” is required otherwise
>>>>>> you get the 404 error.
>>>>>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <
>>>>>> To be able to upload layers I must set
>>>>>> </proxyBaseUrl>
>>>>>> into usr/share/geoserver/data/global.xml
>>>>>> If I open geoserver from the admin panel the address is
>>>>>> http://localhost:8001/geoserver/web/?1
>>>>>> <http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> but If i want for example a layer preview
>>>>>> address change to
>>>>>> http://localhost:8080/geoserver/geonode/wms?access_token=h4o
>>>>>> WfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geono
>>>>>> de:fiora_amianto
>>>>>> <http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> with error The requested URL /geoserver/geonode/wms was not found on
>>>>>> this server.
>>>>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> config.vm.network
>>>>>> is simply redundant. It has been added to access geoserver out of the
>>>>>> scope of oauth2.
>>>>>> What url are you going to call in the browser for geoserver?
>>>>>> Sent from Nylas Pro
>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>>> On apr 10 2017, at 10:49 am, giuseppe musumeci <
>>>>>> I ran the installation of Geonode using the instructions at the link
>>>>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>> I think there are problems in the instructions about geoserver
>>>>>> configuration:
>>>>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>>>>> I changed the default settings with those specified:
>>>>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>>>>> But geoserver don't works: I then set the value to
>>>>>> moreover i Think that to configure vagrantfile as suggested:
>>>>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>>>>> is not correct.
>>>>>> Could someone tell me the correct settings values for geoserver and
>>>>>> vagrantfile?
>>>>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> Dear Giuseppe,
>>>>>> as already replied on the italian gfoss list you should check to
>>>>>> follow from scratch the workshop http://geonode.org/ge
>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t> we
>>>>>> did during foss4g-it. If the error is still happening please let me know as
>>>>>> probably in this case the beta release is also affected and you can help us
>>>>>> with your feedback.
>>>>>> Thanks,
>>>>>> Francesco
>>>>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
>>>>>> Dear list I'm working with Geonode that I installed on a VM set via
>>>>>> Vagrant When I try to load the shape file, I get this error: *failed
>>>>>> to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In the
>>>>>> Apache error log is as follows: *ERROR: geonode.layers.views: failed
>>>>>> to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying to
>>>>>> google around I found that in the settings.py file should add the line:
>>>>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
>>>>>> that the www-data user has all permissions on the www / folder geonode
>>>>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
>>>>>> that I can't upload. Does anyone know help me?
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/671041b4/attachment-0001.html>
More information about the geonode-users mailing list
