[GeoNode-users] Geonode - Error on uploading layer
Francesco Bartoli
xbartolone at gmail.com
Tue Apr 11 03:28:55 PDT 2017
Thanks Simone you are right. I will update the slide, it was my fault.
@Giuseppe you have to leave <proxyBaseUrl> unaltered.
Sent from [Nylas Pro](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-070d2acb-91ee/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-
pro%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the most powerful
email app for work
On apr 11 2017, at 7:23 am, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
> Dears, just a not.
> In the vagrant installation we made at the workshop, there's no need to
forward geoserver to the host as the apache proxy will take care of serving
under localhost:8001/geoserver.
> Best
> 2017-04-10 23:35 GMT+02:00 Francesco Bartoli
<[xbartolone at gmail.com](mailto:xbartolone at gmail.com)>:
>> See inline
>> Il giorno 10/apr/2017, alle ore 21:14, giuseppe musumeci
<[musumeci.giuseppe at gmail.com](mailto:musumeci.giuseppe at gmail.com)> ha
scritto:
>>> I followed your instructions.
>>> There are few differences:
>>> in order the system works I must set
>>> _<proxyBaseUrl>[http://localhost:8001/geoserver](http://localhost:8001/geo
server&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=) /</proxyBaseUrl>_
>>> instead of
>>> _<proxyBaseUrl>[http://localhost:8001/](http://localhost:8001/&r=Z2Vvbm9kZ
S11c2Vyc0BsaXN0cy5vc2dlby5vcmc=) /</proxyBaseUrl> _
>> This is not required if the settings are configured fine. During an
installation with apt-get this is done automatically while executing the
command geonode-updateip
>>> I cannot edit vagrant file with _config.vm.network "forwarded_port",
guest: 8080, host: __8080_
>>> infact I get the error
>>> "Vagrant cannot forward the specified ports on this VM, since they would
collide with some other application that is already listening on these ports.
The forwarded port to 8080 is already in use on the host machine.”
>> You have another process which is running on port 8080 in your host
machine. Please shutdown that.
>>> If I try to upload a layer I get this error [Errno 111] Connection refused
>>> but if I access geoserver on [http://localhost:8001/geoserver/web](http://
localhost:8001/geoserver/web&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
>> Apparently some geoserver configurations in your settings are still wrong.
Are you sure you started a new installation after a vagrant destroy?
>>> I see that layers have been uploaded into geoserver.
>>> Nevethless If I watch into geonode I see that "No content created yet"
>>> 2017-04-10 16:09 GMT+02:00 Francesco Bartoli
>>>> If you have run “sudo geonode-updateip localhost:8001” then the next
thing to do is to check again the configuration of geoserver in settings file
and for the security in the data directory.
>>>> Il giorno 10/apr/2017, alle ore 16:05, giuseppe musumeci
scritto:
>>>>> I've already done it in this attempt
>>>>> Il 10/apr/2017 16:02, "Francesco Bartoli"
<[xbartolone at gmail.com](mailto:xbartolone at gmail.com)> ha scritto:
>>>>>> Can you please repeat all the commands from scratch? You can do it by
running “vagrant destroy”
>>>>>> Il giorno 10/apr/2017, alle ore 15:46, giuseppe musumeci
scritto:
>>>>>>> I installed again geonode according the tutorial
>>>>>>> I run the command geonode-updateip
>>>>>>> I have problem to load layers:[Errno 111] Connection refused
>>>>>>> Where I'm wrong?
>>>>>>> 2017-04-10 14:43 GMT+02:00 Francesco Bartoli
>>>>>>>> Yes, absolutely. It looks like you missed this one
[http://geonode.org/geonode-workshop/foss4git2017/#/4/6](http://geonode.org
/geonode-
workshop/foss4git2017/#/4/6&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
>>>>>>>> Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci
scritto:
>>>>>>>>> I followed all the istructions in the tutorial you send me.
>>>>>>>>> Is there a way to correct these errors using a command (i.e sudo
geonode-updateip localhost:8001)?
>>>>>>>>> 2017-04-10 14:33 GMT+02:00 Francesco Bartoli
>>>>>>>>>> How did you perform the installation?
>>>>>>>>>> You were originally receive that error because
GEOSERVER_PUBLIC_LOCATION is wrong. It should be:
>>>>>>>>>> '[http://localhost:8001/geoserver'](http://localhost:8001/geoserver
&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=')
>>>>>>>>>> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci
scritto:
>>>>>>>>>>> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>>>>>>>>>>> GEOSERVER_LOCATION = os.getenv(
>>>>>>>>>>> 'GEOSERVER_LOCATION', '[http://localhost:8080/geoserver/](http
://localhost:8080/geoserver/&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)'
>>>>>>>>>>> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>>>>>>>>>>> 'GEOSERVER_PUBLIC_LOCATION', '[http://localhost:8080/geoserver
/](http://localhost:8080/geoserver/&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=
>>>>>>>>>>> From /etc/geonode/local_settings.py
>>>>>>>>>>> GEOSERVER_URL = SITEURL + 'geoserver/'
>>>>>>>>>>> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli
>>>>>>>>>>>> Can you double check what you have in the settings for the
geoserver configurations?
__Sent from [Nylas Pro](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1
&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5v
cmc=), the most powerful email app for
work__
On apr 10 2017, at 1:28 pm, giuseppe musumeci
<[musumeci.giuseppe at gmail.com](mailto:musumeci.giuseppe at gmail.com)> wrote:
>>>>>>>>>>>>> Dear Francesco,
>>>>>>>>>>>>> I followed the tutorial
>>>>>>>>>>>>> I need to set <proxyBaseUrl>[http://localhost:8001/geoserver/](h
ttp://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=Z2Vvb
m9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)</proxyBaseUrl>
>>>>>>>>>>>>> and not <proxyBaseUrl>[http://localhost:8001/](http://localhost:
8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=Z2Vvbm9kZS11c2Vyc0Bsa
>>>>>>>>>>>>> In this way geoserver seems to work fine.
>>>>>>>>>>>>> The problem is I'm not able to upload layers from geonode menu
>>>>>>>>>>>>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli
>>>>>>>>>>>>>> Giuseppe,
>>>>>>>>>>>>>> if you set "<proxyBaseUrl>[http://localhost:8080/geoserver/](ht
tp://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=Z2Vvbm
9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)</proxyBaseUrl>" then you have to make that
url reachable from your host. That means
>>>>>>>>>>>>>> the configuration
"[config.vm.network](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ2
1haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy
5vc2dlby5vcmc=) "forwarded_port", guest: 8080, host: 8080” is required
otherwise you get the 404 error.
>>>>>>>>>>>>>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci
scritto:
>>>>>>>>>>>>>>> To be able to upload layers I must set
>>>>>>>>>>>>>>> <proxyBaseUrl>[http://localhost:8080/geoserver/](http://localh
ost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=Z2Vvbm9kZS11c2Vyc
>>>>>>>>>>>>>>> into usr/share/geoserver/data/global.xml
>>>>>>>>>>>>>>> If I open geoserver from the admin panel the address is
>>>>>>>>>>>>>>> [http://localhost:8001/geoserver/web/?1](http://localhost:8001
/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=Z2Vvbm9kZS11c2Vyc0B
>>>>>>>>>>>>>>> but If i want for example a layer preview
>>>>>>>>>>>>>>> address change to
>>>>>>>>>>>>>>> [http://localhost:8080/geoserver/geonode/wms?access_token=h4oW
feewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto](h
ttp://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nm
XSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2
VwcGVAZ21haWwuY29t&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
>>>>>>>>>>>>>>> with error The requested URL /geoserver/geonode/wms was not
found on this server.
>>>>>>>>>>>>>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli
>>>>>>>>>>>>>>>> is simply redundant. It has been added to access geoserver
out of the scope of oauth2.
>>>>>>>>>>>>>>>> What url are you going to call in the browser for geoserver?
/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1
&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t
&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the most powerful email app for
work__
On apr 10 2017, at 10:49 am, giuseppe musumeci
>>>>>>>>>>>>>>>>> I ran the installation of Geonode using the instructions at
the link [http://geonode.org/geonode-
workshop/foss4git2017/#/4/2](http://geonode.org/geonode-workshop/foss4git2017/
#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWw
>>>>>>>>>>>>>>>>> I think there are problems in the instructions about
geoserver configuration:
>>>>>>>>>>>>>>>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>>>>>>>>>>>>>>>> I changed the default settings with those specified:
>>>>>>>>>>>>>>>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>>>>>>>>>>>>>>>> But geoserver don't works: I then set the value to
>>>>>>>>>>>>>>>>> moreover i Think that to configure vagrantfile as suggested:
>>>>>>>>>>>>>>>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>>>>>>>>>>>>>>>> is not correct.
>>>>>>>>>>>>>>>>> Could someone tell me the correct settings values for
geoserver and vagrantfile?
>>>>>>>>>>>>>>>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli
>>>>>>>>>>>>>>>>>> Dear Giuseppe,
>>>>>>>>>>>>>>>>>> as already replied on the italian gfoss list you should
check to follow from scratch the workshop [http://geonode.org/geonode-
uY29t&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=) we did during foss4g-it. If
the error is still happening please let me know as probably in this case the
beta release is also affected and you can help us with your feedback.
>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>> Francesco
>>>>>>>>>>>>>>>>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci
scritto:
>>>>>>>>>>>>>>>>>>> Dear list I'm working with Geonode that I installed on a
VM set via Vagrant When I try to load the shape file, I get this error:
**failed to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777** In the
Apache error log is as follows: **ERROR: geonode.layers.views: failed to
create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778** Trying to google
around I found that in the settings.py file should add the line:
NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified that
the www-data user has all permissions on the www / folder geonode drwxr-xr-x 5
www-data root March 21 4096 14:27 geonode The fact remains that I can't
upload. Does anyone know help me?
>>>>>>>>>>>>>>>>>>> _______________________________________________
geonode-users mailing list
[geonode-users at lists.osgeo.org](mailto:geonode-users at lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/geonode-
users](https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2
l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=Z2Vvbm9kZS11c2
users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170411/93d22ebf/attachment-0001.html>
More information about the geonode-users
