[GeoNode-users] Geosites installation error
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Apr 19 08:43:15 PDT 2017
no you don't need a development installation, you can achieve the same
using a standard apt geonode installation or a geonode-project.
Unfortunately the documentation for geosites is a bit outdated but you can
make it work even without any automatic script. I suggest you to take a
look at the geonode repo as geosites is now part of it as a contrib app
(optional and less maintained) https://github.com
/GeoNode/geonode/tree/2.6.x/geonode/contrib/geosites and the geonode
homepage and docs for the installation http://www.geonode.org.
In order to use geosites you will have to understand the basics of django
projects, nothing too tricky though.
Recently Eugenio made some interesting comments on the geosites doc that
could help you, see here https://github.com/GeoNode/geonode/commit/
740af85ab5654cee3d27b6611b74c39687a4187c#commitcomment-21731038
hope this helps
2017-04-19 17:23 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
> Hi, I'm trying to install geosites.
> I followed this guide for ubuntu development installation:
> https://github.com/simod/geonode#ubuntu
> and then this guide for geosites: https://github.com/t
> erranodo/geosites-project/blob/master/GEOSITES-README.md
> I realized that to have geosites I have to do development installation, is
> it true?
> When I give *bash ./setup.sh example.org <http://example.org>* I have
> this error:
> *Command "python setup.py egg_info" failed with error code 1 in
> /tmp/pip-build-8XOXyi/Paver**/*
> I looked for directory pip-build-8XOXyi but doesn't exist.
> Is this command the same of geonode-updateip for standard installation?
> Can I give *bash ./setup.sh IP* instead of example.org?
> Thanks
> Fosco
> Fosco
> http://studiotypo.it/
> http://www.studiotypo.it/fosco/
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170419/7428fcd3/attachment.html>
More information about the geonode-users
