[GeoNode-users] Geonode - Error on uploading layer
giuseppe musumeci musumeci.giuseppe at gmail.com
Mon Apr 24 06:30:50 PDT 2017
If I don't set at all everything works fine!!
2017-04-24 15:22 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> what about not setting it at all? :)
> 2017-04-24 15:21 GMT+02:00 giuseppe musumeci <musumeci.giuseppe at gmail.com>
>> If I set <proxyBaseUrl>http://localhost:8001/geoserver
>> <http://localhost/geoserver></proxyBaseUrl> geoserver *preview works*
>> but I'm *unable to load layers*
>> If I set <proxyBaseUrl>http://localhost:8080/geoserver
>> <http://localhost/geoserver></proxyBaseUrl> geoserver preview don'tworks
>> but I'm able to load layers
>> If I set <proxyBaseUrl>http://localhost:80/geoserver
>> 2017-04-24 8:07 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Hi Giuseppe,
>>> just give a try with
>>> <proxyBaseUrl>http://localhost:8001/geoserver <http://localhost/geoserver></proxyBaseUrl>
>>>  instead.
>>> Let us know
>>> 2017-04-22 16:08 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Giuseppe,
>>>> In your last error you were trying to open the wrong port in the
>>>> browser. The correct has to be 8001.
>>>> Thanks,
>>>> Francesco
>>>> 22 apr 2017, 14:59 +0200, giuseppe musumeci <
>>>> musumeci.giuseppe at gmail.com>, ha scritto:
>>>> I checked all steps of your tutorial. I have yet the errors I posted in
>>>> the last mail.
>>>> 2017-04-21 12:54 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>> Giuseppe,
>>>>> Please review all the updated configurations of the workshop. They are
>>>>> fully working now. In case try to restart the vagrant vm from scratch.
>>>>> Thanks,
>>>>> Francesco
>>>>> 21 apr 2017, 12:18 +0200, giuseppe musumeci <
>>>>> Hi francesco.
>>>>> I'm having problem with this configuration.
>>>>> 1.from geoserver if i want a preview I get this error:
>>>>> Impossibile trovare la pagina localhost
>>>>> Nessuna pagina web trovata per l'indirizzo web:*http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers
>>>>> <http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers>*
>>>>> HTTP ERROR 404
>>>>> 2. pOSTGRESQL
>>>>> i'M UNABLE TO CONNECT PGADMIN RUNNING IN WINDOWS TO GEONODE DATABASE
>>>>> RUNNING IN vm
>>>>> i'VE SPENT LAST TWO DAYS
>>>>> 2017-04-21 0:07 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> Hi Giuseppe,
>>>>>> I have to adjust my previous hints. To recap the required
>>>>>> configurations for geoserver are:
>>>>>> /usr/share/geoserver/data/security/role/geonode\ REST\ role\ service/config.
>>>>>> <baseUrl>http://localhost:80/</baseUrl>
>>>>>> /usr/share/geoserver/data/security/filter/geonode-oauth2/config.xml
>>>>>> <accessTokenUri>http://localhost/o/token/</accessTokenUri>
>>>>>> <userAuthorizationUri>http://localhost:8001/o/authorize/</userAuthorizationUri>
>>>>>> <redirectUri>http://localhost:8001/geoserver</redirectUri>
>>>>>> <checkTokenEndpointUrl>http://localhost/api/o/v4/tokeninfo/</checkTokenEndpointUrl>
>>>>>> <logoutUri>http://localhost:8001/account/logout/</logoutUri>
>>>>>> /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml
>>>>>> <baseUrl>http://localhost:8001/</baseUrl>
>>>>>> /usr/share/geoserver/data/global.xml
>>>>>> <proxyBaseUrl>http://localhost:80/geoserver</proxyBaseUrl>
>>>>>> I have updated the workshop, also figuring out that this
>>>>>> configuration is a GeoNode full proxied use case where the internal port
>>>>>> 8080 is not forwarded to the host machine.
>>>>>> Thanks for reporting your initial issues.
>>>>>> Hope this definitively clarifies,
>>>>>> Francesco
>>>>>> Il giorno 12/apr/2017, alle ore 21:34, giuseppe musumeci <
>>>>>> musumeci.giuseppe at gmail.com> ha scritto:
>>>>>> Leaving <proxyBaseUrl> unaltered. I'm able to load layer but I'm not
>>>>>> able to preview it in geoserver:
>>>>>> The port changes from 8001 to 8080 and I have the error
>>>>>>  "The requested URL /geoserver/geonode/wms was not found on this
>>>>>> server."
>>>>>> 2017-04-11 12:28 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>>> Thanks Simone you are right. I will update the slide, it was my
>>>>>>> fault.
>>>>>>>  @Giuseppe you have to leave <proxyBaseUrl> unaltered.
>>>>>>> Sent from Nylas Pro
>>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-070d2acb-91ee/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>>>> the most powerful email app for work
>>>>>>> On apr 11 2017, at 7:23 am, Simone Dalmasso <
>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>> Dears, just a not.
>>>>>>>> In the vagrant installation we made at the workshop, there's no
>>>>>>>> need to forward geoserver to the host as the apache proxy will take care of
>>>>>>>> serving under localhost:8001/geoserver.
>>>>>>>> Best
>>>>>>>> 2017-04-10 23:35 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>
>>>>>>>> See inline
>>>>>>>> Il giorno 10/apr/2017, alle ore 21:14, giuseppe musumeci <
>>>>>>>> I followed your instructions.
>>>>>>>> There are few differences:
>>>>>>>> in order the system works I must set
>>>>>>>> *<proxyBaseUrl>http://localhost:8001/geoserver
>>>>>>>> <http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> /</proxyBaseUrl>*
>>>>>>>> instead of
>>>>>>>> <http://localhost:8001/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> /</proxyBaseUrl>*
>>>>>>>> This is not required if the settings are configured fine. During an
>>>>>>>> installation with apt-get this is done automatically while executing the
>>>>>>>> command geonode-updateip
>>>>>>>> I cannot edit vagrant file with *config.vm.network
>>>>>>>> "forwarded_port", guest: 8080, host:* *8080*
>>>>>>>> infact I get the error
>>>>>>>> "Vagrant cannot forward the specified ports on this VM, since they
>>>>>>>> would collide with some other application that is already listening on
>>>>>>>> these ports. The forwarded port to 8080 is already in use on the host
>>>>>>>> machine.”
>>>>>>>> You have another process which is running on port 8080 in your host
>>>>>>>> machine. Please shutdown that.
>>>>>>>> If I try to upload a layer I get this error [Errno 111] Connection
>>>>>>>> refused
>>>>>>>> but if I access geoserver on http://localhost:8001/geoserver/web
>>>>>>>> <http://localhost:8001/geoserver/web&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> Apparently some geoserver configurations in your settings are still
>>>>>>>> wrong. Are you sure you started a new installation after a vagrant destroy?
>>>>>>>> I see that layers have been uploaded into geoserver.
>>>>>>>> Nevethless If I watch into geonode I see that "No content created
>>>>>>>> yet"
>>>>>>>> 2017-04-10 16:09 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>
>>>>>>>> If you have run “sudo geonode-updateip localhost:8001” then the
>>>>>>>> next thing to do is to check again the configuration of geoserver in
>>>>>>>> settings file and for the security in the data directory.
>>>>>>>> Il giorno 10/apr/2017, alle ore 16:05, giuseppe musumeci <
>>>>>>>> I've already done it in this attempt
>>>>>>>> Il 10/apr/2017 16:02, "Francesco Bartoli" <xbartolone at gmail.com>
>>>>>>>> ha scritto:
>>>>>>>> Can you please repeat all the commands from scratch? You can do it
>>>>>>>> by running “vagrant destroy”
>>>>>>>> Il giorno 10/apr/2017, alle ore 15:46, giuseppe musumeci <
>>>>>>>> I installed again geonode according the tutorial
>>>>>>>> I run the command geonode-updateip
>>>>>>>> I have problem to load layers:[Errno 111] Connection refused
>>>>>>>> Where I'm wrong?
>>>>>>>> 2017-04-10 14:43 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>
>>>>>>>> Yes, absolutely. It looks like you missed this one
>>>>>>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/6
>>>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/6&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci <
>>>>>>>> I followed all the istructions in the tutorial you send me.
>>>>>>>> Is there a way to correct these errors using a command (i.e sudo
>>>>>>>> geonode-updateip localhost:8001)?
>>>>>>>> 2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>
>>>>>>>> How did you perform the installation?
>>>>>>>> You were originally receive that error because
>>>>>>>> GEOSERVER_PUBLIC_LOCATION is wrong. It should be:
>>>>>>>> 'http://localhost:8001/geoserver'
>>>>>>>> <http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t'>
>>>>>>>> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <
>>>>>>>> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>>>>>>>> GEOSERVER_LOCATION = os.getenv(
>>>>>>>>     'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/
>>>>>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>>>>>>>>     'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/
>>>>>>>> From /etc/geonode/local_settings.py
>>>>>>>> GEOSERVER_URL = SITEURL + 'geoserver/'
>>>>>>>> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>
>>>>>>>> Can you double check what you have in the settings for the
>>>>>>>> geoserver configurations?
>>>>>>>> Sent from Nylas Pro
>>>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>>>>> On apr 10 2017, at 1:28 pm, giuseppe musumeci <
>>>>>>>> musumeci.giuseppe at gmail.com> wrote:
>>>>>>>> Dear Francesco,
>>>>>>>> I followed the tutorial
>>>>>>>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/
>>>>>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> </proxyBaseUrl>
>>>>>>>> and not <proxyBaseUrl>http://localhost:8001/
>>>>>>>> </proxyBaseUrl>
>>>>>>>> In this way geoserver seems to work fine.
>>>>>>>> The problem is I'm not able to upload layers from geonode menu
>>>>>>>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>
>>>>>>>> Giuseppe,
>>>>>>>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/
>>>>>>>> </proxyBaseUrl>" then you have to make that url reachable from
>>>>>>>> your host. That means
>>>>>>>> the configuration "config.vm.network
>>>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>>  "forwarded_port", guest: 8080, host: 8080” is required otherwise
>>>>>>>> you get the 404 error.
>>>>>>>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <
>>>>>>>> To be able to upload layers I must set
>>>>>>>> </proxyBaseUrl>
>>>>>>>> into usr/share/geoserver/data/global.xml
>>>>>>>> If I open geoserver from the admin panel the address is
>>>>>>>> http://localhost:8001/geoserver/web/?1
>>>>>>>> <http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> but If i want for example a layer preview
>>>>>>>> address change to
>>>>>>>> http://localhost:8080/geoserver/geonode/wms?access_token=h4o
>>>>>>>> WfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geono
>>>>>>>> de:fiora_amianto
>>>>>>>> <http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> with error The requested URL /geoserver/geonode/wms was not found
>>>>>>>> on this server.
>>>>>>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>
>>>>>>>> config.vm.network
>>>>>>>> is simply redundant. It has been added to access geoserver out of
>>>>>>>> the scope of oauth2.
>>>>>>>> What url are you going to call in the browser for geoserver?
>>>>>>>> Sent from Nylas Pro
>>>>>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>>>>>> On apr 10 2017, at 10:49 am, giuseppe musumeci <
>>>>>>>> I ran the installation of Geonode using the instructions at the
>>>>>>>> link http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>>>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> I think there are problems in the instructions about geoserver
>>>>>>>> configuration:
>>>>>>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>>>>>>> I changed the default settings with those specified:
>>>>>>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>>>>>>> But geoserver don't works: I then set the value to
>>>>>>>> moreover i Think that to configure vagrantfile as suggested:
>>>>>>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>>>>>>> is not correct.
>>>>>>>> Could someone tell me the correct settings values for geoserver and
>>>>>>>> vagrantfile?
>>>>>>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>
>>>>>>>> Dear Giuseppe,
>>>>>>>> as already replied on the italian gfoss list you should check to
>>>>>>>> follow from scratch the workshop http://geonode.org/ge
>>>>>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t> we
>>>>>>>> did during foss4g-it. If the error is still happening please let me know as
>>>>>>>> probably in this case the beta release is also affected and you can help us
>>>>>>>> with your feedback.
>>>>>>>> Thanks,
>>>>>>>> Francesco
>>>>>>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
>>>>>>>> Dear list I'm working with Geonode that I installed on a VM set via
>>>>>>>> Vagrant When I try to load the shape file, I get this error: *failed
>>>>>>>> to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In
>>>>>>>> the Apache error log is as follows: *ERROR: geonode.layers.views:
>>>>>>>> failed to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying
>>>>>>>> to google around I found that in the settings.py file should add the line:
>>>>>>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
>>>>>>>> that the www-data user has all permissions on the www / folder geonode
>>>>>>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
>>>>>>>> that I can't upload. Does anyone know help me?
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170424/627fc9bd/attachment-0001.html>
More information about the geonode-users mailing list
