[GeoNode-users] Geosites installation error
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Apr 24 10:29:44 PDT 2017
in your project's dir is fine. It works like any django project, if you
take a look at the django tutorial you can find very similar setups.
2017-04-24 19:28 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
> And I have to copy site-template in dir/dir/contrib/geosites or only in
> dir/dir like in this guide https://github.com/terranodo/landscapeportal ?
> 2017-04-24 18:07 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi,
>> geonode-project is just a template, all you may need you can copy into
>> it. In this case just copy the site-template either from githiub or your
>> geonode installation (you can search for it and copy) and rename
>> accordingly.
>> 2017-04-24 16:52 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>> Hi Simone,
>>> I am trying to use geonode-project as base template. For single site it
>>> works fine but I do not understand how to set it as a multisite. In
>>> geonode-project template there are not all files mentioned in the geosites
>>> guides.
>>> For example in this Eugenio's comment https://github.com/Geo
>>> Node/geonode/commit/740af85ab5654cee3d27b6611b74c39687a4187c
>>> #commitcomment-21731291 I need site_template in contrib directory but
>>> in geonode-project template there isn't.
>>> How can I do?
>>> Thanks.
>>> Fosco
>>> 2017-04-21 12:41 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> No don't need to checkout another geonode or delete the settings in
>>>> etc. I suggest you to start from here https://github.com/GeoNod
>>>> e/geonode-project and once you have it set up then you can create your
>>>> own settings with geosites enabled and make your own geosites in it.
>>>> 2017-04-21 12:31 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>>>> Ok, I have installed geonode 2.6 like quick installation tells, then I
>>>>> deleted /etc/geonode to replace it with *git
>>>>> clone https://github.com/GeoNode/geonode
>>>>> <https://github.com/GeoNode/geonode>*, is it right?
>>>>> I have duplicated /geonode/geonode/contrib/geosites/site_template
>>>>> whit a new name.
>>>>> Now I would like to have:
>>>>> - www.example.com/site1
>>>>> - www.example.com/site2
>>>>> so I go to www.example.com/admin/sites/site/ and add site1 and site2
>>>>> Now have I to edit /etc/apache2/sites-enabled/geonode.conf? In which
>>>>> way?
>>>>> I did:
>>>>> WSGIDaemonProcess new_name_site_template user=www-data threads=15
>>>>> processes=2
>>>>> <VirtualHost *:80>
>>>>> DocumentRoot /etc/geonode/geonode/contrib/geosites/
>>>>> WSGIProcessGroup fosco_geosites
>>>>> WSGIScriptAlias / /etc/geonode/geonode/contrib/g
>>>>> eosites/new_name_site_template/wsgi.py
>>>>> but doesn't work.
>>>>> Where am I wrong?
>>>>> Thanks.
>>>>> Fosco
>>>>> 2017-04-19 17:43 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>> Hi,
>>>>>> no you don't need a development installation, you can achieve the
>>>>>> same using a standard apt geonode installation or a geonode-project.
>>>>>> Unfortunately the documentation for geosites is a bit outdated but
>>>>>> you can make it work even without any automatic script. I suggest you to
>>>>>> take a look at the geonode repo as geosites is now part of it as a contrib
>>>>>> app (optional and less maintained) https://github.com
>>>>>> /GeoNode/geonode/tree/2.6.x/geonode/contrib/geosites and the geonode
>>>>>> homepage and docs for the installation http://www.geonode.org.
>>>>>> In order to use geosites you will have to understand the basics of
>>>>>> django projects, nothing too tricky though.
>>>>>> Recently Eugenio made some interesting comments on the geosites doc
>>>>>> that could help you, see here https://github.com/GeoNod
>>>>>> e/geonode/commit/740af85ab5654cee3d27b6611b74c39687a4187c#co
>>>>>> mmitcomment-21731038
>>>>>> hope this helps
>>>>>> 2017-04-19 17:23 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>>>>>> Hi, I'm trying to install geosites.
>>>>>>> I followed this guide for ubuntu development installation:
>>>>>>> https://github.com/simod/geonode#ubuntu
>>>>>>> and then this guide for geosites: https://github.com/t
>>>>>>> erranodo/geosites-project/blob/master/GEOSITES-README.md
>>>>>>> I realized that to have geosites I have to do development
>>>>>>> installation, is it true?
>>>>>>> When I give *bash ./setup.sh example.org <http://example.org>* I
>>>>>>> have this error:
>>>>>>> *Command "python setup.py egg_info" failed with error code 1 in
>>>>>>> /tmp/pip-build-8XOXyi/Paver**/*
>>>>>>> I looked for directory pip-build-8XOXyi but doesn't exist.
>>>>>>> Is this command the same of geonode-updateip for standard
>>>>>>> installation? Can I give *bash ./setup.sh IP* instead of example.org
>>>>>>> Thanks
>>>>>>> Fosco
>>>>>>> Fosco
>>>>>>> http://studiotypo.it/
>>>>>>> http://www.studiotypo.it/fosco/
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> Simone
>>>>> Fosco
>>>> Simone
>>> Fosco
>> Simone
> Fosco
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170424/f7b12dd9/attachment-0001.html>
More information about the geonode-users
