[GeoNode-users] UnicodeDecodeError - In Upload a Layer
Daniel Victoria daniel.victoria at gmail.com
Mon Apr 24 11:23:59 PDT 2017
Hi Cesar,
You probably have some accented character in your attribute table and the
file encoding is not UTF-8. So, when you try to upload the layer, you get
this error. Since it looks like you are running on windows, try to set your
encoding to latin1 (or ISO-1250) and see it it works.
If you use QGis, you can change the layer encoding in the layer properties
to try and figure out what is the correct encoding
Cheers
Daniel
On Mon, Apr 24, 2017 at 2:53 PM César de Oliveira Ferreira Silva <
cesar at agroicone.com.br> wrote:
> Hello list. I found a problem when trying to upload a layer in GeoNode 2.4
> Can anyone suggest a solution?
> Attached, sending the shapefile file for testing.
> Below the complete log.
> UnicodeDecodeError at /layers/upload 'utf8' codec can't decode byte 0xe3
> in position 149: invalid continuation byte Request Method: POST Request
> URL: http://localhost/layers/upload Django Version: 1.6.11 Python
> Executable: C:\GeoNode-2.4.x\Apache2\bin\Apache.exe Python Version: 2.7.10
> Python Path:
> ['C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\Lib\\site-packages',
> 'C:\\WINDOWS\\SYSTEM32\\python27.zip',
> 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\DLLs',
> 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib',
> 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\plat-win',
> 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\lib-tk',
> 'C:\\GeoNode-2.4.x\\Apache2\\bin', 'C:\\GeoNode-2.4.x\\Python27\\Lib',
> 'C:\\GeoNode-2.4.x\\Python27\\DLLs',
> 'C:\\GeoNode-2.4.x\\Python27\\Lib\\lib-tk',
> 'C:\\GeoNode-2.4.x\\geonode-2.4.x',
> 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages',
> 'C:\\GeoNode-2.4.x\\Apache2'] Server time: Seg, 24 Abr 2017 14:48:47 -0300
> Installed Applications: ('django.contrib.auth',
> 'django.contrib.contenttypes', 'django.contrib.sessions',
> 'django.contrib.sites', 'django.contrib.admin', 'django.contrib.sitemaps',
> 'django.contrib.staticfiles', 'django.contrib.messages',
> 'django.contrib.humanize', 'django.contrib.gis', 'pagination', 'taggit',
> 'friendlytagloader', 'geoexplorer', 'leaflet', 'django_extensions',
> 'autocomplete_light', 'mptt', 'modeltranslation', 'djcelery',
> 'pinax_theme_bootstrap_account', 'pinax_theme_bootstrap',
> 'django_forms_bootstrap', 'account', 'avatar', 'dialogos', 'agon_ratings',
> 'announcements', 'actstream', 'user_messages', 'tastypie', 'polymorphic',
> 'guardian', 'geonode.people', 'geonode.base', 'geonode.layers',
> 'geonode.maps', 'geonode.proxy', 'geonode.security', 'geonode.social',
> 'geonode.catalogue', 'geonode.documents', 'geonode.api', 'geonode.groups',
> 'geonode.services', 'geonode.geoserver', 'geonode.upload', 'geonode.tasks')
> Installed Middleware: ('django.middleware.common.CommonMiddleware',
> 'django.contrib.sessions.middleware.SessionMiddleware',
> 'django.contrib.messages.middleware.MessageMiddleware',
> 'django.middleware.locale.LocaleMiddleware',
> 'pagination.middleware.PaginationMiddleware',
> 'django.middleware.csrf.CsrfViewMiddleware',
> 'django.contrib.auth.middleware.AuthenticationMiddleware',
> 'django.middleware.clickjacking.XFrameOptionsMiddleware') Traceback: File
> "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\core\handlers\base.py"
> in get_response 112. response = wrapped_callback(request, *callback_args,
> **callback_kwargs) File
> "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\contrib\auth\decorators.py"
> in _wrapped_view 22. return view_func(request, *args, **kwargs) File
> "C:\GeoNode-2.4.x\geonode-2.4.x\geonode\layers\views.py" in layer_upload
> 174. upload_session.save() File
> "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\db\models\base.py"
> in save 545. force_update=force_update, update_fields=update_fields) File
> in save_base 573. updated = self._save_table(raw, cls, force_insert,
> force_update, using, update_fields) File
> in _save_table 635. forced_update) File
> in _do_update 679. return filtered._update(values) > 0 File
> "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\db\models\query.py"
> in _update 510. return query.get_compiler(self.db).execute_sql(None) File
> "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\db\models\sql\compiler.py"
> in execute_sql 980. cursor = super(SQLUpdateCompiler,
> self).execute_sql(result_type) File
> in execute_sql 786. cursor.execute(sql, params) File
> "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\db\backends\util.py"
> in execute 73. sql = self.db.ops.last_executed_query(self.cursor, sql,
> params) File
> "C:\GeoNode-2.4.x\geonode-2.4.x\lib\site-packages\django\db\backends\postgresql_psycopg2\operations.py"
> in last_executed_query 214. return cursor.query.decode('utf-8') File
> "C:\GeoNode-2.4.x\geonode-2.4.x\lib\encodings\utf_8.py" in decode 16.
> return codecs.utf_8_decode(input, errors, True) Exception Type:
> UnicodeDecodeError at /layers/upload Exception Value: 'utf8' codec can't
> decode byte 0xe3 in position 149: invalid continuation byte Request
> information: GET: No GET data POST: charset = u'ISO-8859-1' permissions =
> u'{"users":{"AnonymousUser":["view_resourcebase","download_resourcebase"]},"groups":{}}'
> FILES: base_file = shx_file = dbf_file = prj_file = COOKIES: csrftoken =
> 'hRU1p8MvCyDFtvEv3TcQRPqrfybGcfGj' favoritosInit = '' i3geolingua = 'pt'
> sessionid = 'svv145t4mp27ricjimemozxrdz57bza4' META: wsgi.multiprocess =
> False HTTP_REFERER = 'http://localhost/layers/upload'
> mod_wsgi.handler_script = '' CONTEXT_DOCUMENT_ROOT =
> 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode' SERVER_SOFTWARE = 'Apache/2.4.18
> (Win32) mod_wsgi/4.4.21 Python/2.7.10' SCRIPT_NAME = u''
> mod_wsgi.enable_sendfile = '0' HTTP_X_CSRFTOKEN =
> 'hRU1p8MvCyDFtvEv3TcQRPqrfybGcfGj' SERVER_SIGNATURE = '' REQUEST_METHOD =
> 'POST' PATH_INFO = u'/layers/upload' HTTP_ORIGIN = 'http://localhost'
> SERVER_PROTOCOL = 'HTTP/1.1' QUERY_STRING = '' wsgi.errors = CONTENT_LENGTH
> = '320086' HTTP_USER_AGENT = 'Mozilla/5.0 (Windows NT 10.0; Win64; x64)
> AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36'
> HTTP_CONNECTION = 'keep-alive' HTTP_COOKIE = 'favoritosInit=;
> i3geolingua=pt; sessionid=svv145t4mp27ricjimemozxrdz57bza4;
> csrftoken=hRU1p8MvCyDFtvEv3TcQRPqrfybGcfGj' SERVER_NAME = 'localhost'
> REMOTE_ADDR = '::1' mod_wsgi.request_handler = 'wsgi-script' PATHEXT =
> '.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC' wsgi.url_scheme =
> 'http' PATH_TRANSLATED =
> 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\wsgi.py\\layers\\upload'
> SERVER_PORT = '80' mod_wsgi.version = SERVER_ADDR = '::1' DOCUMENT_ROOT =
> 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode' apache.version =
> mod_wsgi.process_group = '' COMSPEC = 'C:\\WINDOWS\\system32\\cmd.exe'
> HTTP_X_REQUESTED_WITH = 'XMLHttpRequest' mod_wsgi.path_info =
> '/layers/upload' SCRIPT_FILENAME =
> 'C:/GeoNode-2.4.x/geonode-2.4.x/geonode/wsgi.py' SERVER_ADMIN = '
> webmaster at example.org' wsgi.input = HTTP_HOST = 'localhost'
> CONTEXT_PREFIX = '' mod_wsgi.callable_object = 'application'
> wsgi.multithread = True SystemRoot = 'C:\\WINDOWS' REQUEST_URI =
> '/layers/upload' HTTP_ACCEPT = '*/*' WINDIR = 'C:\\WINDOWS'
> wsgi.file_wrapper = '' wsgi.version = GATEWAY_INTERFACE = 'CGI/1.1'
> wsgi.run_once = False mod_wsgi.script_name = '' REMOTE_PORT = '59536'
> HTTP_ACCEPT_LANGUAGE = 'pt-BR,pt;q=0.8,en-US;q=0.6,en;q=0.4' REQUEST_SCHEME
> = 'http' mod_wsgi.script_start = '1493056125689752' CONTENT_TYPE =
> 'multipart/form-data; boundary=----WebKitFormBoundaryumMrOVduJikKa4BX'
> mod_wsgi.application_group = 'localhost|' mod_wsgi.script_reloading = '1'
> mod_wsgi.request_start = '1493056125688751' CSRF_COOKIE =
> u'hRU1p8MvCyDFtvEv3TcQRPqrfybGcfGj' HTTP_ACCEPT_ENCODING = 'gzip, deflate,
> br' Settings: Using settings module geonode.settings CASCADE_WORKSPACE =
> 'geonode' ACCOUNT_USER_DISPLAY = '' DATABASES = {'default': {'ENGINE':
> 'django.db.backends.postgresql_psycopg2', 'AUTOCOMMIT': True,
> 'ATOMIC_REQUESTS': False, 'NAME': 'geonode', 'TEST_MIRROR': None,
> 'CONN_MAX_AGE': 0, 'TIME_ZONE': 'America/Chicago', 'TEST_COLLATION': None,
> 'TEST_CHARSET': None, 'PORT': '5454', 'HOST': 'localhost', 'USER':
> 'geonode', 'TEST_NAME': None, 'PASSWORD': u'********************',
> 'OPTIONS': {}}, 'datastore': {'ENGINE':
> 'django.contrib.gis.db.backends.postgis', 'AUTOCOMMIT': True,
> 'ATOMIC_REQUESTS': False, 'NAME': 'geonode_imports', 'TEST_MIRROR': None,
> 'OPTIONS': {}}} CELERY_CREATE_MISSING_QUEUES = True GEONODE_CONTRIB_APPS =
> CSRF_COOKIE_SECURE = False CELERY_DEFAULT_QUEUE = 'default' UPLOADER =
> {'OPTIONS': {'TIME_ENABLED': False, 'GEOGIG_ENABLED': False}, 'BACKEND':
> 'geonode.rest'} LANGUAGE_CODE = 'en' LICENSES = {'ENABLED': True, 'DETAIL':
> 'above', 'METADATA': 'verbose'} MANAGERS = DOWNLOAD_FORMATS_METADATA =
> ['Atom', 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO'] BROKER_URL =
> 'django://' DEFAULT_CHARSET = 'utf-8' IGNORABLE_404_URLS =
> CELERY_DEFAULT_EXCHANGE_TYPE = 'direct' GDAL_LIBRARY_PATH =
> 'C:\\GeoNode-2.4.x\\GDAL\\gdal111.dll' DEFAULT_MAP_CENTER =
> ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS = 3 USE_THOUSAND_SEPARATOR = False
> ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL = None
> ACCOUNT_INVITE_USER_URL = u'account_invite_user' REGISTRATION_OPEN = False
> ALLOWED_HOSTS = [] EMAIL_HOST = 'localhost' DOWNLOAD_FORMATS_RASTER =
> ['JPEG', 'PDF', 'PNG', 'ArcGrid', 'GeoTIFF', 'Gtopo30', 'ImageMosaic',
> 'KML', 'View in Google Earth', 'Tiles'] AUTH_EXEMPT_URLS = WSGI_APPLICATION
> = None EMAIL_SUBJECT_PREFIX = '[Django] ' SEND_BROKEN_LINK_EMAILS = False
> STATICFILES_FINDERS = NOTIFICATION_QUEUE_ALL = False SESSION_CACHE_ALIAS =
> 'default' CELERY_IMPORTS = SESSION_COOKIE_DOMAIN = None SESSION_COOKIE_NAME
> = 'sessionid' VERSION = '2.4' ADMIN_FOR = TIME_INPUT_FORMATS =
> ACCOUNT_USE_AUTH_AUTHENTICATE = False X_FRAME_OPTIONS = 'SAMEORIGIN'
> FILE_UPLOAD_PERMISSIONS = None ACCOUNT_TIMEZONES = [('Africa/Abidjan',
> 'Africa/Abidjan'), ('Africa/Accra', 'Africa/Accra'), ('Africa/Addis_Ababa',
> 'Africa/Addis_Ababa'), ('Africa/Algiers', 'Africa/Algiers'),
> ('Africa/Asmara', 'Africa/Asmara'), ('Africa/Asmera', 'Africa/Asmera'),
> ('Africa/Bamako', 'Africa/Bamako'), ('Africa/Bangui', 'Africa/Bangui'),
> ('Africa/Banjul', 'Africa/Banjul'), ('Africa/Bissau', 'Africa/Bissau'),
> ('Africa/Blantyre', 'Africa/Blantyre'), ('Africa/Brazzaville',
> 'Africa/Brazzaville'), ('Africa/Bujumbura', 'Africa/Bujumbura'),
> ('Africa/Cairo', 'Africa/Cairo'), ('Africa/Casablanca',
> 'Africa/Casablanca'), ('Africa/Ceuta', 'Africa/Ceuta'), ('Africa/Conakry',
> 'Africa/Conakry'), ('Africa/Dakar', 'Africa/Dakar'),
> ('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'), ('Africa/Djibouti',
> 'Africa/Djibouti'), ('Africa/Douala', 'Africa/Douala'), ('Africa/El_Aaiun',
> 'Africa/El_Aaiun'), ('Africa/Freetown', 'Africa/Freetown'),
> ('Africa/Gaborone', 'Africa/Gaborone'), ('Africa/Harare', 'Africa/Harare'),
> ('Africa/Johannesburg', 'Africa/Johannesburg'), ('Africa/Juba',
> 'Africa/Juba'), ('Africa/Kampala', 'Africa/Kampala'), ('Africa/Khartoum',
> 'Africa/Khartoum'), ('Africa/Kigali', 'Africa/Kigali'), ('Africa/Kinshasa',
> 'Africa/Kinshasa'), ('Africa/Lagos', 'Africa/Lagos'), ('Africa/Libreville',
> 'Africa/Libreville'), ('Africa/Lome', 'Africa/Lome'), ('Africa/Luanda',
> 'Africa/Luanda'), ('Africa/Lubumbashi', 'Africa/Lubumbashi'),
> ('Africa/Lusaka', 'Africa/Lusaka'), ('Africa/Malabo', 'Africa/Malabo'),
> ('Africa/Maputo', 'Africa/Maputo'), ('Africa/Maseru', 'Africa/Maseru'),
> ('Africa/Mbabane', 'Africa/Mbabane'), ('Africa/Mogadishu',
> 'Africa/Mogadishu'), ('Africa/Monrovia', 'Africa/Monrovia'),
> ('Africa/Nairobi', 'Africa/Nairobi'), ('Africa/Ndjamena',
> 'Africa/Ndjamena'), ('Africa/Niamey', 'Africa/Niamey'),
> ('Africa/Nouakchott', 'Africa/Nouakchott'), ('Africa/Ouagadougou',
> 'Africa/Ouagadougou'), ('Africa/Porto-Novo', 'Africa/Porto-Novo'),
> ('Africa/Sao_Tome', 'Africa/Sao_Tome'), ('Africa/Timbuktu',
> 'Africa/Timbuktu'), ('Africa/Tripoli', 'Africa/Tripoli'), ('Africa/Tunis',
> 'Africa/Tunis'), ('Africa/Windhoek', 'Africa/Windhoek'), ('America/Adak',
> 'America/Adak'), ('America/Anchorage', 'America/Anchorage'),
> ('America/Anguilla', 'America/Anguilla'), ('America/Antigua',
> 'America/Antigua'), ('America/Araguaina', 'America/Araguaina'),
> ('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
> ('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
> ('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
> ('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
> ('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
> ('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
> ('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
> ('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
> ('America/Argentina/Salta', 'America/Argentina/Salta'),
> ('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
> ('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
> ('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
> ('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
> ('America/Aruba', 'America/Aruba'), ('America/Asuncion',
> 'America/Asuncion'), ('America/Atikokan', 'America/Atikokan'),
> ('America/Atka', 'America/Atka'), ('America/Bahia', 'America/Bahia'),
> ('America/Bahia_Banderas', 'America/Bahia_Banderas'), ('America/Barbados',
> 'America/Barbados'), ('America/Belem', 'America/Belem'), ('America/Belize',
> 'America/Belize'), ('America/Blanc-Sablon', 'America/Blanc-Sablon'),
> ('America/Boa_Vista', 'America/Boa_Vista'), ('America/Bogota',
> 'America/Bogota'), ('America/Boise', 'America/Boise'),
> ('America/Buenos_Aires', 'America/Buenos_Aires'), ('America/Cambridge_Bay',
> 'America/Cambridge_Bay'), ('America/Campo_Grande', 'America/Campo_Grande'),
> ('America/Cancun', 'America/Cancun'), ('America/Caracas',
> 'America/Caracas'), ('America/Catamarca', 'America/Catamarca'),
> ('America/Cayenne', 'America/Cayenne'), ('America/Cayman',
> 'America/Cayman'), ('America/Chicago', 'America/Chicago'),
> ('America/Chihuahua', 'America/Chihuahua'), ('America/Coral_Harbour',
> 'America/Coral_Harbour'), ('America/Cordoba', 'America/Cordoba'),
> ('America/Costa_Rica', 'America/Costa_Rica'), ('America/Creston',
> 'America/Creston'), ('America/Cuiaba', 'America/Cuiaba'),
> ('America/Curacao', 'America/Curacao'), ('America/Danmarkshavn',
> 'America/Danmarkshavn'), ('America/Dawson', 'America/Dawson'),
> ('America/Dawson_Creek', 'America/Dawson_Creek'), ('America/Denver',
> 'America/Denver'), ('America/Detroit', 'America/Detroit'),
> ('America/Dominica', 'America/Dominica'), ('America/Edmonton',
> 'America/Edmonton'), ('America/Eirunepe', 'America/Eirunepe'),
> ('America/El_Salvador', 'America/El_Salvador'), ('America/Ensenada',
> 'America/Ensenada'), ('America/Fort_Nelson', 'America/Fort_Nelson'),
> ('America/Fort_Wayne', 'America/Fort_Wayne'), ('America/Fortaleza',
> 'America/Fortaleza'), ('America/Glace_Bay', 'America/Glace_Bay'),
> ('America/Godthab', 'America/Godthab'), ('America/Goose_Bay',
> 'America/Goose_Bay'), ('America/Grand_Turk', 'America/Grand_Turk'),
> ('America/Grenada', 'America/Grenada'), ('America/Guadeloupe',
> 'America/Guadeloupe'), ('America/Guatemala', 'America/Guatemala'),
> ('America/Guayaquil', 'America/Guayaquil'), ('America/Guyana',
> 'America/Guyana'), ('America/Halifax', 'America/Halifax'),
> ('America/Havana', 'America/Havana'), ('America/Hermosillo',
> 'America/Hermosillo'), ('America/Indiana/Indianapolis',
> 'America/Indiana/Indianapolis'), ('America/Indiana/Knox',
> 'America/Indiana/Knox'), ('America/Indiana/Marengo',
> 'America/Indiana/Marengo'), ('America/Indiana/Petersburg',
> 'America/Indiana/Petersburg'), ('America/Indiana/Tell_City',
> 'America/Indiana/Tell_City'), ('America/Indiana/Vevay',
> 'America/Indiana/Vevay'), ('America/Indiana/Vincennes',
> 'America/Indiana/Vincennes'), ('America/Indiana/Winamac',
> 'America/Indiana/Winamac'), ('America/Indianapolis',
> 'America/Indianapolis'), ('America/Inuvik', 'America/Inuvik'),
> ('America/Iqaluit', 'America/Iqaluit'), ('America/Jamaica',
> 'America/Jamaica'), ('America/Jujuy', 'America/Jujuy'), ('America/Juneau',
> 'America/Juneau'), ('America/Kentucky/Louisville',
> 'America/Kentucky/Louisville'), ('America/Kentucky/Monticello',
> 'America/Kentucky/Monticello'), ('America/Knox_IN', 'America/Knox_IN'),
> ('America/Kralendijk', 'America/Kralendijk'), ('America/La_Paz',
> 'America/La_Paz'), ('America/Lima', 'America/Lima'),
> ('America/Los_Angeles', 'America/Los_Angeles'), ('America/Louisville',
> 'America/Louisville'), ('America/Lower_Princes', 'America/Lower_Princes'),
> ('America/Maceio', 'America/Maceio'), ('America/Managua',
> 'America/Managua'), ('America/Manaus', 'America/Manaus'),
> ('America/Marigot', 'America/Marigot'), ('America/Martinique',
> 'America/Martinique'), ('America/Matamoros', 'America/Matamoros'),
> ('America/Mazatlan', 'America/Mazatlan'), ('America/Mendoza',
> 'America/Mendoza'), ('America/Menominee', 'America/Menominee'),
> ('America/Merida', 'America/Merida'), ('America/Metlakatla',
> 'America/Metlakatla'), ('America/Mexico_City', 'America/Mexico_City'),
> ('America/Miquelon', 'America/Miquelon'), ('America/Moncton',
> 'America/Moncton'), ('America/Monterrey', 'America/Monterrey'),
> ('America/Montevideo', 'America/Montevideo'), ('America/Montreal',
> 'America/Montreal'), ('America/Montserrat', 'America/Montserrat'),
> ('America/Nassau', 'America/Nassau'), ('America/New_York',
> 'America/New_York'), ('America/Nipigon', 'America/Nipigon'),
> ('America/Nome', 'America/Nome'), ('America/Noronha', 'America/Noronha'),
> ('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
> ('America/North_Dakota/Center', 'America/North_Dakota/Center'),
> ('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
> ('America/Ojinaga', 'America/Ojinaga'), ('America/Panama',
> 'America/Panama'), ('America/Pangnirtung', 'America/Pangnirtung'),
> ('America/Paramaribo', 'America/Paramaribo'), ('America/Phoenix',
> 'America/Phoenix'), ('America/Port-au-Prince', 'America/Port-au-Prince'),
> ('America/Port_of_Spain', 'America/Port_of_Spain'), ('America/Porto_Acre',
> 'America/Porto_Acre'), ('America/Porto_Velho', 'America/Porto_Velho'),
> ('America/Puerto_Rico', 'America/Puerto_Rico'), ('America/Rainy_River',
> 'America/Rainy_River'), ('America/Rankin_Inlet', 'America/Rankin_Inlet'),
> ('America/Recife', 'America/Recife'), ('America/Regina', 'America/Regina'),
> ('America/Resolute', 'America/Resolute'), ('America/Rio_Branco',
> 'America/Rio_Branco'), ('America/Rosario', 'America/Rosario'),
> ('America/Santa_Isabel', 'America/Santa_Isabel'), ('America/Santarem',
> 'America/Santarem'), ('America/Santiago', 'America/Santiago'),
> ('America/Santo_Domingo', 'America/Santo_Domingo'), ('America/Sao_Paulo',
> 'America/Sao_Paulo'), ('America/Scoresbysund', 'America/Scoresbysund'),
> ('America/Shiprock', 'America/Shiprock'), ('America/Sitka',
> 'America/Sitka'), ('America/St_Barthelemy', 'America/St_Barthelemy'),
> ('America/St_Johns', 'America/St_Johns'), ('America/St_Kitts',
> 'America/St_Kitts'), ('America/St_Lucia', 'America/St_Lucia'),
> ('America/St_Thomas', 'America/St_Thomas'), ('America/St_Vincent',
> 'America/St_Vincent'), ('America/Swift_Current', 'America/Swift_Current'),
> ('America/Tegucigalpa', 'America/Tegucigalpa'), ('America/Thule',
> 'America/Thule'), ('America/Thunder_Bay', 'America/Thunder_Bay'),
> ('America/Tijuana', 'America/Tijuana'), ('America/Toronto',
> 'America/Toronto'), ('America/Tortola', 'America/Tortola'),
> ('America/Vancouver', 'America/Vancouver'), ('America/Virgin',
> 'America/Virgin'), ('America/Whitehorse', 'America/Whitehorse'),
> ('America/Winnipeg', 'America/Winnipeg'), ('America/Yakutat',
> 'America/Yakutat'), ('America/Yellowknife', 'America/Yellowknife'),
> ('Antarctica/Casey', 'Antarctica/Casey'), ('Antarctica/Davis',
> 'Antarctica/Davis'), ('Antarctica/DumontDUrville',
> 'Antarctica/DumontDUrville'), ('Antarctica/Macquarie',
> 'Antarctica/Macquarie'), ('Antarctica/Mawson', 'Antarctica/Mawson'),
> ('Antarctica/McMurdo', 'Antarctica/McMurdo'), ('Antarctica/Palmer',
> 'Antarctica/Palmer'), ('Antarctica/Rothera', 'Antarctica/Rothera'),
> ('Antarctica/South_Pole', 'Antarctica/South_Pole'), ('Antarctica/Syowa',
> 'Antarctica/Syowa'), ('Antarctica/Troll', 'Antarctica/Troll'),
> ('Antarctica/Vostok', 'Antarctica/Vostok'), ('Arctic/Longyearbyen',
> 'Arctic/Longyearbyen'), ('Asia/Aden', 'Asia/Aden'), ('Asia/Almaty',
> 'Asia/Almaty'), ('Asia/Amman', 'Asia/Amman'), ('Asia/Anadyr',
> 'Asia/Anadyr'), ('Asia/Aqtau', 'Asia/Aqtau'), ('Asia/Aqtobe',
> 'Asia/Aqtobe'), ('Asia/Ashgabat', 'Asia/Ashgabat'), ('Asia/Ashkhabad',
> 'Asia/Ashkhabad'), ('Asia/Baghdad', 'Asia/Baghdad'), ('Asia/Bahrain',
> 'Asia/Bahrain'), ('Asia/Baku', 'Asia/Baku'), ('Asia/Bangkok',
> 'Asia/Bangkok'), ('Asia/Beirut', 'Asia/Beirut'), ('Asia/Bishkek',
> 'Asia/Bishkek'), ('Asia/Brunei', 'Asia/Brunei'), ('Asia/Calcutta',
> 'Asia/Calcutta'), ('Asia/Chita', 'Asia/Chita'), ('Asia/Choibalsan',
> 'Asia/Choibalsan'), ('Asia/Chongqing', 'Asia/Chongqing'),
> ('Asia/Chungking', 'Asia/Chungking'), ('Asia/Colombo', 'Asia/Colombo'),
> ('Asia/Dacca', 'Asia/Dacca'), ('Asia/Damascus', 'Asia/Damascus'),
> ('Asia/Dhaka', 'Asia/Dhaka'), ('Asia/Dili', 'Asia/Dili'), ('Asia/Dubai',
> 'Asia/Dubai'), ('Asia/Dushanbe', 'Asia/Dushanbe'), ('Asia/Gaza',
> 'Asia/Gaza'), ('Asia/Harbin', 'Asia/Harbin'), ('Asia/Hebron',
> 'Asia/Hebron'), ('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
> ('Asia/Hong_Kong', 'Asia/Hong_Kong'), ('Asia/Hovd', 'Asia/Hovd'),
> ('Asia/Irkutsk', 'Asia/Irkutsk'), ('Asia/Istanbul', 'Asia/Istanbul'),
> ('Asia/Jakarta', 'Asia/Jakarta'), ('Asia/Jayapura', 'Asia/Jayapura'),
> ('Asia/Jerusalem', 'Asia/Jerusalem'), ('Asia/Kabul', 'Asia/Kabul'),
> ('Asia/Kamchatka', 'Asia/Kamchatka'), ('Asia/Karachi', 'Asia/Karachi'),
> ('Asia/Kashgar', 'Asia/Kashgar'), ('Asia/Kathmandu', 'Asia/Kathmandu'),
> ('Asia/Katmandu', 'Asia/Katmandu'), ('Asia/Khandyga', 'Asia/Khandyga'),
> ('Asia/Kolkata', 'Asia/Kolkata'), ('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
> ('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'), ('Asia/Kuching',
> 'Asia/Kuching'), ('Asia/Kuwait', 'Asia/Kuwait'), ('Asia/Macao',
> 'Asia/Macao'), ('Asia/Macau', 'Asia/Macau'), ('Asia/Magadan',
> 'Asia/Magadan'), ('Asia/Makassar', 'Asia/Makassar'), ('Asia/Manila',
> 'Asia/Manila'), ('Asia/Muscat', 'Asia/Muscat'), ('Asia/Nicosia',
> 'Asia/Nicosia'), ('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
> ('Asia/Novosibirsk', 'Asia/Novosibirsk'), ('Asia/Omsk', 'Asia/Omsk'),
> ('Asia/Oral', 'Asia/Oral'), ('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
> ('Asia/Pontianak', 'Asia/Pontianak'), ('Asia/Pyongyang', 'Asia/Pyongyang'),
> ('Asia/Qatar', 'Asia/Qatar'), ('Asia/Qyzylorda', 'Asia/Qyzylorda'),
> ('Asia/Rangoon', 'Asia/Rangoon'), ('Asia/Riyadh', 'Asia/Riyadh'),
> ('Asia/Saigon', 'Asia/Saigon'), ('Asia/Sakhalin', 'Asia/Sakhalin'),
> ('Asia/Samarkand', 'Asia/Samarkand'), ('Asia/Seoul', 'Asia/Seoul'),
> ('Asia/Shanghai', 'Asia/Shanghai'), ('Asia/Singapore', 'Asia/Singapore'),
> ('Asia/Srednekolymsk', 'Asia/Srednekolymsk'), ('Asia/Taipei',
> 'Asia/Taipei'), ('Asia/Tashkent', 'Asia/Tashkent'), ('Asia/Tbilisi',
> 'Asia/Tbilisi'), ('Asia/Tehran', 'Asia/Tehran'), ('Asia/Tel_Aviv',
> 'Asia/Tel_Aviv'), ('Asia/Thimbu', 'Asia/Thimbu'), ('Asia/Thimphu',
> 'Asia/Thimphu'), ('Asia/Tokyo', 'Asia/Tokyo'), ('Asia/Ujung_Pandang',
> 'Asia/Ujung_Pandang'), ('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
> ('Asia/Ulan_Bator', 'Asia/Ulan_Bator'), ('Asia/Urumqi', 'Asia/Urumqi'),
> ('Asia/Ust-Nera', 'Asia/Ust-Nera'), ('Asia/Vientiane', 'Asia/Vientiane'),
> ('Asia/Vladivostok', 'Asia/Vladivostok'), ('Asia/Yakutsk', 'Asia/Yakutsk'),
> ('Asia/Yekaterinburg', 'Asia/Yekaterinburg'), ('Asia/Yerevan',
> 'Asia/Yerevan'), ('Atlantic/Azores', 'Atlantic/Azores'),
> ('Atlantic/Bermuda', 'Atlantic/Bermuda'), ('Atlantic/Canary',
> 'Atlantic/Canary'), ('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
> ('Atlantic/Faeroe', 'Atlantic/Faeroe'), ('Atlantic/Faroe',
> 'Atlantic/Faroe'), ('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
> ('Atlantic/Madeira', 'Atlantic/Madeira'), ('Atlantic/Reykjavik',
> 'Atlantic/Reykjavik'), ('Atlantic/South_Georgia',
> 'Atlantic/South_Georgia'), ('Atlantic/St_Helena', 'Atlantic/St_Helena'),
> ('Atlantic/Stanley', 'Atlantic/Stanley'), ('Australia/ACT',
> 'Australia/ACT'), ('Australia/Adelaide', 'Australia/Adelaide'),
> ('Australia/Brisbane', 'Australia/Brisbane'), ('Australia/Broken_Hill',
> 'Australia/Broken_Hill'), ('Australia/Canberra', 'Australia/Canberra'),
> ('Australia/Currie', 'Australia/Currie'), ('Australia/Darwin',
> 'Australia/Darwin'), ('Australia/Eucla', 'Australia/Eucla'),
> ('Australia/Hobart', 'Australia/Hobart'), ('Australia/LHI',
> 'Australia/LHI'), ('Australia/Lindeman', 'Australia/Lindeman'),
> ('Australia/Lord_Howe', 'Australia/Lord_Howe'), ('Australia/Melbourne',
> 'Australia/Melbourne'), ('Australia/NSW', 'Australia/NSW'),
> ('Australia/North', 'Australia/North'), ('Australia/Perth',
> 'Australia/Perth'), ('Australia/Queensland', 'Australia/Queensland'),
> ('Australia/South', 'Australia/South'), ('Australia/Sydney',
> 'Australia/Sydney'), ('Australia/Tasmania', 'Australia/Tasmania'),
> ('Australia/Victoria', 'Australia/Victoria'), ('Australia/West',
> 'Australia/West'), ('Australia/Yancowinna', 'Australia/Yancowinna'),
> ('Brazil/Acre', 'Brazil/Acre'), ('Brazil/DeNoronha', 'Brazil/DeNoronha'),
> ('Brazil/East', 'Brazil/East'), ('Brazil/West', 'Brazil/West'), ('CET',
> 'CET'), ('CST6CDT', 'CST6CDT'), ('Canada/Atlantic', 'Canada/Atlantic'),
> ('Canada/Central', 'Canada/Central'), ('Canada/East-Saskatchewan',
> 'Canada/East-Saskatchewan'), ('Canada/Eastern', 'Canada/Eastern'),
> ('Canada/Mountain', 'Canada/Mountain'), ('Canada/Newfoundland',
> 'Canada/Newfoundland'), ('Canada/Pacific', 'Canada/Pacific'),
> ('Canada/Saskatchewan', 'Canada/Saskatchewan'), ('Canada/Yukon',
> 'Canada/Yukon'), ('Chile/Continental', 'Chile/Continental'),
> ('Chile/EasterIsland', 'Chile/EasterIsland'), ('Cuba', 'Cuba'), ('EET',
> 'EET'), ('EST', 'EST'), ('EST5EDT', 'EST5EDT'), ('Egypt', 'Egypt'),
> ('Eire', 'Eire'), ('Etc/GMT', 'Etc/GMT'), ('Etc/GMT+0', 'Etc/GMT+0'),
> ('Etc/GMT+1', 'Etc/GMT+1'), ('Etc/GMT+10', 'Etc/GMT+10'), ('Etc/GMT+11',
> 'Etc/GMT+11'), ('Etc/GMT+12', 'Etc/GMT+12'), ('Etc/GMT+2', 'Etc/GMT+2'),
> ('Etc/GMT+3', 'Etc/GMT+3'), ('Etc/GMT+4', 'Etc/GMT+4'), ('Etc/GMT+5',
> 'Etc/GMT+5'), ('Etc/GMT+6', 'Etc/GMT+6'), ('Etc/GMT+7', 'Etc/GMT+7'),
> ('Etc/GMT+8', 'Etc/GMT+8'), ('Etc/GMT+9', 'Etc/GMT+9'), ('Etc/GMT-0',
> 'Etc/GMT-0'), ('Etc/GMT-1', 'Etc/GMT-1'), ('Etc/GMT-10', 'Etc/GMT-10'),
> ('Etc/GMT-11', 'Etc/GMT-11'), ('Etc/GMT-12', 'Etc/GMT-12'), ('Etc/GMT-13',
> 'Etc/GMT-13'), ('Etc/GMT-14', 'Etc/GMT-14'), ('Etc/GMT-2', 'Etc/GMT-2'),
> ('Etc/GMT-3', 'Etc/GMT-3'), ('Etc/GMT-4', 'Etc/GMT-4'), ('Etc/GMT-5',
> 'Etc/GMT-5'), ('Etc/GMT-6', 'Etc/GMT-6'), ('Etc/GMT-7', 'Etc/GMT-7'),
> ('Etc/GMT-8', 'Etc/GMT-8'), ('Etc/GMT-9', 'Etc/GMT-9'), ('Etc/GMT0',
> 'Etc/GMT0'), ('Etc/Greenwich', 'Etc/Greenwich'), ('Etc/UCT', 'Etc/UCT'),
> ('Etc/UTC', 'Etc/UTC'), ('Etc/Universal', 'Etc/Universal'), ('Etc/Zulu',
> 'Etc/Zulu'), ('Europe/Amsterdam', 'Europe/Amsterdam'), ('Europe/Andorra',
> 'Europe/Andorra'), ('Europe/Athens', 'Europe/Athens'), ('Europe/Belfast',
> 'Europe/Belfast'), ('Europe/Belgrade', 'Europe/Belgrade'),
> ('Europe/Berlin', 'Europe/Berlin'), ('Europe/Bratislava',
> 'Europe/Bratislava'), ('Europe/Brussels', 'Europe/Brussels'),
> ('Europe/Bucharest', 'Europe/Bucharest'), ('Europe/Budapest',
> 'Europe/Budapest'), ('Europe/Busingen', 'Europe/Busingen'),
> ('Europe/Chisinau', 'Europe/Chisinau'), ('Europe/Copenhagen',
> 'Europe/Copenhagen'), ('Europe/Dublin', 'Europe/Dublin'),
> ('Europe/Gibraltar', 'Europe/Gibraltar'), ('Europe/Guernsey',
> 'Europe/Guernsey'), ('Europe/Helsinki', 'Europe/Helsinki'),
> ('Europe/Isle_of_Man', 'Europe/Isle_of_Man'), ('Europe/Istanbul',
> 'Europe/Istanbul'), ('Europe/Jersey', 'Europe/Jersey'),
> ('Europe/Kaliningrad', 'Europe/Kaliningrad'), ('Europe/Kiev',
> 'Europe/Kiev'), ('Europe/Lisbon', 'Europe/Lisbon'), ('Europe/Ljubljana',
> 'Europe/Ljubljana'), ('Europe/London', 'Europe/London'),
> ('Europe/Luxembourg', 'Europe/Luxembourg'), ('Europe/Madrid',
> 'Europe/Madrid'), ('Europe/Malta', 'Europe/Malta'), ('Europe/Mariehamn',
> 'Europe/Mariehamn'), ('Europe/Minsk', 'Europe/Minsk'), ('Europe/Monaco',
> 'Europe/Monaco'), ('Europe/Moscow', 'Europe/Moscow'), ('Europe/Nicosia',
> 'Europe/Nicosia'), ('Europe/Oslo', 'Europe/Oslo'), ('Europe/Paris',
> 'Europe/Paris'), ('Europe/Podgorica', 'Europe/Podgorica'),
> ('Europe/Prague', 'Europe/Prague'), ('Europe/Riga', 'Europe/Riga'),
> ('Europe/Rome', 'Europe/Rome'), ('Europe/Samara', 'Europe/Samara'),
> ('Europe/San_Marino', 'Europe/San_Marino'), ('Europe/Sarajevo',
> 'Europe/Sarajevo'), ('Europe/Simferopol', 'Europe/Simferopol'),
> ('Europe/Skopje', 'Europe/Skopje'), ('Europe/Sofia', 'Europe/Sofia'),
> ('Europe/Stockholm', 'Europe/Stockholm'), ('Europe/Tallinn',
> 'Europe/Tallinn'), ('Europe/Tirane', 'Europe/Tirane'), ('Europe/Tiraspol',
> 'Europe/Tiraspol'), ('Europe/Uzhgorod', 'Europe/Uzhgorod'),
> ('Europe/Vaduz', 'Europe/Vaduz'), ('Europe/Vatican', 'Europe/Vatican'),
> ('Europe/Vienna', 'Europe/Vienna'), ('Europe/Vilnius', 'Europe/Vilnius'),
> ('Europe/Volgograd', 'Europe/Volgograd'), ('Europe/Warsaw',
> 'Europe/Warsaw'), ('Europe/Zagreb', 'Europe/Zagreb'), ('Europe/Zaporozhye',
> 'Europe/Zaporozhye'), ('Europe/Zurich', 'Europe/Zurich'), ('GB', 'GB'),
> ('GB-Eire', 'GB-Eire'), ('GMT', 'GMT'), ('GMT+0', 'GMT+0'), ('GMT-0',
> 'GMT-0'), ('GMT0', 'GMT0'), ('Greenwich', 'Greenwich'), ('HST', 'HST'),
> ('Hongkong', 'Hongkong'), ('Iceland', 'Iceland'), ('Indian/Antananarivo',
> 'Indian/Antananarivo'), ('Indian/Chagos', 'Indian/Chagos'),
> ('Indian/Christmas', 'Indian/Christmas'), ('Indian/Cocos', 'Indian/Cocos'),
> ('Indian/Comoro', 'Indian/Comoro'), ('Indian/Kerguelen',
> 'Indian/Kerguelen'), ('Indian/Mahe', 'Indian/Mahe'), ('Indian/Maldives',
> 'Indian/Maldives'), ('Indian/Mauritius', 'Indian/Mauritius'),
> ('Indian/Mayotte', 'Indian/Mayotte'), ('Indian/Reunion', 'Indian/Reunion'),
> ('Iran', 'Iran'), ('Israel', 'Israel'), ('Jamaica', 'Jamaica'), ('Japan',
> 'Japan'), ('Kwajalein', 'Kwajalein'), ('Libya', 'Libya'), ('MET', 'MET'),
> ('MST', 'MST'), ('MST7MDT', 'MST7MDT'), ('Mexico/BajaNorte',
> 'Mexico/BajaNorte'), ('Mexico/BajaSur', 'Mexico/BajaSur'),
> ('Mexico/General', 'Mexico/General'), ('NZ', 'NZ'), ('NZ-CHAT', 'NZ-CHAT'),
> ('Navajo', 'Navajo'), ('PRC', 'PRC'), ('PST8PDT', 'PST8PDT'),
> ('Pacific/Apia', 'Pacific/Apia'), ('Pacific/Auckland', 'Pacific/Auckland'),
> ('Pacific/Bougainville', 'Pacific/Bougainville'), ('Pacific/Chatham',
> 'Pacific/Chatham'), ('Pacific/Chuuk', 'Pacific/Chuuk'), ('Pacific/Easter',
> 'Pacific/Easter'), ('Pacific/Efate', 'Pacific/Efate'),
> ('Pacific/Enderbury', 'Pacific/Enderbury'), ('Pacific/Fakaofo',
> 'Pacific/Fakaofo'), ('Pacific/Fiji', 'Pacific/Fiji'), ('Pacific/Funafuti',
> 'Pacific/Funafuti'), ('Pacific/Galapagos', 'Pacific/Galapagos'),
> ('Pacific/Gambier', 'Pacific/Gambier'), ('Pacific/Guadalcanal',
> 'Pacific/Guadalcanal'), ('Pacific/Guam', 'Pacific/Guam'),
> ('Pacific/Honolulu', 'Pacific/Honolulu'), ('Pacific/Johnston',
> 'Pacific/Johnston'), ('Pacific/Kiritimati', 'Pacific/Kiritimati'),
> ('Pacific/Kosrae', 'Pacific/Kosrae'), ('Pacific/Kwajalein',
> 'Pacific/Kwajalein'), ('Pacific/Majuro', 'Pacific/Majuro'),
> ('Pacific/Marquesas', 'Pacific/Marquesas'), ('Pacific/Midway',
> 'Pacific/Midway'), ('Pacific/Nauru', 'Pacific/Nauru'), ('Pacific/Niue',
> 'Pacific/Niue'), ('Pacific/Norfolk', 'Pacific/Norfolk'), ('Pacific/Noumea',
> 'Pacific/Noumea'), ('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
> ('Pacific/Palau', 'Pacific/Palau'), ('Pacific/Pitcairn',
> 'Pacific/Pitcairn'), ('Pacific/Pohnpei', 'Pacific/Pohnpei'),
> ('Pacific/Ponape', 'Pacific/Ponape'), ('Pacific/Port_Moresby',
> 'Pacific/Port_Moresby'), ('Pacific/Rarotonga', 'Pacific/Rarotonga'),
> ('Pacific/Saipan', 'Pacific/Saipan'), ('Pacific/Samoa', 'Pacific/Samoa'),
> ('Pacific/Tahiti', 'Pacific/Tahiti'), ('Pacific/Tarawa', 'Pacific/Tarawa'),
> ('Pacific/Tongatapu', 'Pacific/Tongatapu'), ('Pacific/Truk',
> 'Pacific/Truk'), ('Pacific/Wake', 'Pacific/Wake'), ('Pacific/Wallis',
> 'Pacific/Wallis'), ('Pacific/Yap', 'Pacific/Yap'), ('Poland', 'Poland'),
> ('Portugal', 'Portugal'), ('ROC', 'ROC'), ('ROK', 'ROK'), ('Singapore',
> 'Singapore'), ('Turkey', 'Turkey'), ('UCT', 'UCT'), ('US/Alaska',
> 'US/Alaska'), ('US/Aleutian', 'US/Aleutian'), ('US/Arizona', 'US/Arizona'),
> ('US/Central', 'US/Central'), ('US/East-Indiana', 'US/East-Indiana'),
> ('US/Eastern', 'US/Eastern'), ('US/Hawaii', 'US/Hawaii'),
> ('US/Indiana-Starke', 'US/Indiana-Starke'), ('US/Michigan', 'US/Michigan'),
> ('US/Mountain', 'US/Mountain'), ('US/Pacific', 'US/Pacific'),
> ('US/Pacific-New', 'US/Pacific-New'), ('US/Samoa', 'US/Samoa'), ('UTC',
> 'UTC'), ('Universal', 'Universal'), ('W-SU', 'W-SU'), ('WET', 'WET'),
> ('Zulu', 'Zulu')] FILE_UPLOAD_HANDLERS = DEFAULT_CONTENT_TYPE = 'text/html'
> ACCOUNT_APPROVAL_REQUIRED = False DEBUG_STATIC = False APPEND_SLASH = True
> FIRST_DAY_OF_WEEK = 0 DATABASE_ROUTERS = [] DEFAULT_TABLESPACE = ''
> YEAR_MONTH_FORMAT = 'F Y' STATICFILES_STORAGE =
> 'django.contrib.staticfiles.storage.StaticFilesStorage' CACHES =
> {'default': {'BACKEND': 'django.core.cache.backends.dummy.DummyCache'}}
> DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION = True CKAN_ORIGINS = [{'url': '
> https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}¬es={abstract}&caveats={caveats}',
> 'css_class': 'hdx', 'label': 'Humanitarian Data Exchange (HDX)'}]
> SLACK_WEBHOOK_URLS = ['https://hooks.slack.com/services/T000/B000/XX']
> ACCOUNT_EMAIL_CONFIRMATION_EMAIL = False SERVER_EMAIL = 'root at localhost'
> SESSION_COOKIE_PATH = '/' EXIF_ENABLED = False USE_X_FORWARDED_HOST = False
> ACCOUNT_OPEN_SIGNUP = True ROOT_URLCONF = 'geonode.urls' CATALOGUE =
> {'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local', 'URL': '
> http://localhost:8000/catalogue/csw'}} MISSING_THUMBNAIL =
> 'geonode/img/missing_thumb.png' FILE_UPLOAD_TEMP_DIR = None
> MIDDLEWARE_CLASSES = USE_I18N = True THOUSAND_SEPARATOR = ',' SECRET_KEY =
> u'********************' MODELTRANSLATION_FALLBACK_LANGUAGES = 'en'
> LANGUAGE_COOKIE_NAME = 'django_language' OGC_SERVER = {'default':
> {'LOG_FILE':
> 'C:\\GeoNode-2.4.x\\geonode-2.4.x/geoserver/data/logs/geoserver.log',
> 'WPS_ENABLED': False, 'WMST_ENABLED': False, 'GEOGIG_DATASTORE_DIR': '',
> 'GEONODE_SECURITY_ENABLED': True, 'MAPFISH_PRINT_ENABLED': True,
> 'PUBLIC_LOCATION': 'http://localhost/geoserver/',
> 'BACKEND_WRITE_ENABLED': True, 'USER': 'admin', 'TIMEOUT': 10, 'BACKEND':
> 'geonode.geoserver', 'DATASTORE': 'datastore', 'PASSWORD':
> u'********************', 'PRINT_NG_ENABLED': True, 'GEOGIG_ENABLED': False,
> 'LOCATION': 'http://localhost:8080/geoserver/'}}
> ACCOUNT_REMEMBER_ME_EXPIRY = 315360000 ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
> = u'********************' DEFAULT_MAP_CRS = 'EPSG:900913'
> ACCOUNT_EMAIL_UNIQUE = True TRANSACTIONS_MANAGED = False LOGGING_CONFIG =
> 'django.utils.log.dictConfig' TEMPLATE_LOADERS = GEOS_LIBRARY_PATH =
> 'C:\\GeoNode-2.4.x\\GDAL\\geos_c.dll' TASTYPIE_DEFAULT_FORMATS = ['json']
> TEMPLATE_DEBUG = True AUTO_GENERATE_AVATAR_SIZES = CSRF_COOKIE_NAME =
> 'csrftoken' THEME_ACCOUNT_CONTACT_EMAIL = 'admin at example.com'
> CELERY_DEFAULT_EXCHANGE = 'default' CELERY_DEFAULT_ROUTING_KEY =
> u'********************' ACCOUNT_LOGIN_REDIRECT_URL = u'/' TWITTER_HASHTAGS
> = ['geonode'] CELERY_ALWAYS_EAGER = True MODIFY_TOPICCATEGORY = False
> SIGNING_BACKEND = 'django.core.signing.TimestampSigner'
> SESSION_COOKIE_SECURE = False NLP_ENABLED = False ACCOUNT_LOGIN_URL =
> u'account_login' CACHE_TIME = 0 PYCSW = {'CONFIGURATION': {'metadata:main':
> {'identification_fees': 'None', 'provider_url': 'http://localhost:8000/',
> 'identification_keywords': 'sdi,catalogue,discovery,metadata,GeoNode',
> 'contact_address': 'Mailing Address', 'identification_accessconstraints':
> 'None', 'contact_name': 'Lastname, Firstname', 'contact_stateorprovince':
> 'Administrative Area', 'contact_country': 'Country', 'contact_url':
> 'Contact URL', 'provider_name': 'Organization Name', 'contact_phone':
> '+xx-xxx-xxx-xxxx', 'contact_hours': 'Hours of Service', 'contact_role':
> 'pointOfContact', 'contact_email': 'Email Address', 'identification_title':
> 'GeoNode Catalogue', 'contact_postalcode': 'Zip or Postal Code',
> 'contact_city': 'City', 'identification_keywords_type': 'theme',
> 'identification_abstract': 'GeoNode is an open source platform that
> facilitates the creation, sharing, and collaborative use of geospatial
> data', 'contact_fax': '+xx-xxx-xxx-xxxx', 'contact_instructions': 'During
> hours of service. Off on weekends.', 'contact_position': 'Position Title'},
> 'metadata:inspire': {'languages_supported': 'eng,gre', 'default_language':
> 'eng', 'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD', 'conformity_service':
> 'notEvaluated', 'contact_email': 'Email Address', 'date': 'YYYY-MM-DD',
> 'contact_name': 'Organization Name', 'gemet_keywords': 'Utility and
> governmental services', 'enabled': 'true'}}} CSRF_COOKIE_DOMAIN = None
> FILE_CHARSET = 'utf-8' DEBUG = True SESSION_FILE_PATH = None
> DEFAULT_FILE_STORAGE = 'django.core.files.storage.FileSystemStorage'
> INSTALLED_APPS = LANGUAGES_BIDI = USE_L10N = False
> COMMENTS_ALLOW_PROFANITIES = False STATIC_ROOT =
> 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\static_root' GEONODE_APPS =
> LEAFLET_CONFIG = {'TILES': [('Watercolor', 'http://{s}.
> tile.stamen.com/watercolor/{z}/{x}/{y}.png
> <http://tile.stamen.com/watercolor/%7Bz%7D/%7Bx%7D/%7By%7D.png>', 'Map
> tiles by Stamen Design <http://stamen.com/>, CC BY 3.0
> <http://creativecommons.org/licenses/by/3.0> — Map data ©OpenStreetMap
> <http://openstreetmap.org/> contributors, CC-BY-SA
> <http://creativecommons.org/licenses/by-sa/2.0/>'), ('Toner Lite',
> 'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png
> <http://tile.stamen.com/toner-lite/%7Bz%7D/%7Bx%7D/%7By%7D.png>', 'Map
> <http://creativecommons.org/licenses/by/3.0> — Map data © OpenStreetMap
> <http://creativecommons.org/licenses/by-sa/2.0/>')], 'PLUGINS':
> {u'__is_normalized__': True, u'ALL': {u'css':
> [u'/static/leaflet/draw/leaflet.draw.css',
> '/static/lib/css/leaflet.fullscreen.css?v=2.4'], u'js':
> [u'/static/leaflet/draw/leaflet.draw.js',
> u'/static/leaflet/leaflet.extras.js', u'/static/leaflet/leaflet.forms.js',
> u'/static/leaflet/proj4js.js', u'/static/leaflet/proj4leaflet.js',
> u"/static/proj4js/{'DETAIL': 'never'}.js",
> '/static/lib/js/Leaflet.fullscreen.min.js?v=2.4',
> '/static/lib/js/esri-leaflet.js?v=2.4']}, 'esri-leaflet': {'auto-include':
> True, u'css': [], 'js': ['/static/lib/js/esri-leaflet.js?v=2.4']},
> u'forms': {u'css': [u'/static/leaflet/draw/leaflet.draw.css'],
> u'auto-include': False, u'js': [u'/static/leaflet/draw/leaflet.draw.js',
> u"/static/proj4js/{'DETAIL': 'never'}.js"]}, 'leaflet-fullscreen': {'css':
> ['/static/lib/css/leaflet.fullscreen.css?v=2.4'], 'auto-include': True,
> 'js': ['/static/lib/js/Leaflet.fullscreen.min.js?v=2.4']}, u'__default__':
> {u'css': ['/static/lib/css/leaflet.fullscreen.css?v=2.4'], u'js':
> ['/static/lib/js/Leaflet.fullscreen.min.js?v=2.4',
> '/static/lib/js/esri-leaflet.js?v=2.4']}}} DOWNLOAD_FORMATS_VECTOR =
> ['JPEG', 'PDF', 'PNG', 'Zipped Shapefile', 'GML 2.0', 'GML 3.1.1', 'CSV',
> 'Excel', 'GeoJSON', 'KML', 'View in Google Earth', 'Tiles'] PREPEND_WWW =
> False SECURE_PROXY_SSL_HEADER = None TWITTER_CARD = True
> ACCOUNT_PASSWORD_RESET_REDIRECT_URL = u'********************'
> SESSION_COOKIE_HTTPONLY = True DEBUG_PROPAGATE_EXCEPTIONS = False
> DEFAULT_ANONYMOUS_VIEW_PERMISSION = True MONTH_DAY_FORMAT = 'F j'
> ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL = u'account_login'
> LOGIN_URL = '/account/login/' SESSION_EXPIRE_AT_BROWSER_CLOSE = False
> SEARCH_FILTERS = {'REGION_ENABLED': True, 'EXTENT_ENABLED': True,
> 'DATE_ENABLED': True, 'KEYWORDS_ENABLED': u'********************',
> 'CATEGORIES_ENABLED': True, 'TYPE_ENABLED': True, 'OWNERS_ENABLED': True,
> 'TEXT_ENABLED': True} OPENGRAPH_ENABLED = True OGP_URL = '
> http://geodata.tufts.edu/solr/select' CELERY_EAGER_PROPAGATES_EXCEPTIONS
> = True TIME_FORMAT = 'P' CELERY_IGNORE_RESULT = True
> SERVICE_UPDATE_INTERVAL = 0 AUTH_USER_MODEL = 'people.Profile'
> DATE_INPUT_FORMATS = ACCOUNT_LOGOUT_REDIRECT_URL = u'/' SESSION_SERIALIZER
> = 'django.contrib.sessions.serializers.PickleSerializer' HAYSTACK_SEARCH =
> False AUTHENTICATION_BACKENDS = EMAIL_HOST_PASSWORD =
> u'********************' CELERY_DISABLE_RATE_LIMITS = True
> PASSWORD_RESET_TIMEOUT_DAYS = u'********************'
> CACHE_MIDDLEWARE_ALIAS = 'default' SESSION_SAVE_EVERY_REQUEST = False
> NUMBER_GROUPING = 0 SHORT_DATETIME_FORMAT = 'm/d/Y P' SESSION_ENGINE =
> 'django.contrib.sessions.backends.db' CELERY_RESULT_BACKEND = None
> ACCOUNT_DELETION_MARK_CALLBACK = '' CSRF_COOKIE_PATH = '/'
> LOGIN_REDIRECT_URL = '/accounts/profile/' TEMPLATE_STRING_IF_INVALID = ''
> NLP_LIBRARY_PATH = '/opt/MITIE/mitielib' ACCOUNT_DELETION_EXPUNGE_HOURS =
> 48 PROJECT_ROOT = 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode'
> DECIMAL_SEPARATOR = '.' API_INCLUDE_REGIONS_COUNT = u'********************'
> CELERY_SEND_EVENTS = False NOSE_ARGS = ['--nocapture', '--detailed-errors']
> LOCALE_PATHS = 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\locale'
> NLP_MODEL_PATH = '/opt/MITIE/MITIE-models/english/ner_model.dat'
> PASSWORD_HASHERS = u'********************' PROXY_ALLOWED_HOSTS =
> MESSAGE_STORAGE =
> 'django.contrib.messages.storage.fallback.FallbackStorage' USE_QUEUE =
> False SITEURL = 'http://localhost/' SOCIAL_ORIGINS = [{'url': 'mailto:?subject={name}&body={url}',
> 'css_class': 'email', 'label': 'Email'}, {'url': '
> http://www.facebook.com/sharer.php?u={url}', 'css_class': 'fb', 'label':
> 'Facebook'}, {'url': '
> https://twitter.com/share?url={url}&hashtags={hashtags}', 'css_class':
> 'tw', 'label': 'Twitter'}, {'url': '
> https://plus.google.com/share?url={url}', 'css_class': 'gp', 'label':
> 'Google +'}] LOGOUT_URL = '/account/logout/' MAP_BASELAYERS = [{'source':
> {'url': 'http://localhost/geoserver/wms', 'restUrl': '/gs/rest', 'ptype':
> 'gxp_wmscsource'}}, {'group': 'background', 'args': ['No background'],
> 'visibility': False, 'source': {'ptype': 'gxp_olsource'}, 'fixed': True,
> 'type': 'OpenLayers.Layer'}, {'group': 'background', 'name': 'mapnik',
> 'visibility': True, 'source': {'ptype': 'gxp_osmsource'}, 'fixed': True,
> 'type': 'OpenLayers.Layer.OSM'}] EMAIL_USE_TLS = False ACCOUNT_LANGUAGES =
> [('en', u'English'), ('es', u'espa\xf1ol'), ('it', u'italiano'), ('fr',
> u'fran\xe7ais'), ('de', u'Deutsch'), ('el',
> u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'), ('id', u'Bahasa
> Indonesia'), ('zh-cn', u'\u7b80\u4f53\u4e2d\u6587'), ('ja',
> u'\u65e5\u672c\u8a9e'), ('fa', u'\u0641\u0627\u0631\u0633\u06cc'), ('ar',
> u'\u0627\u0644\u0639\u0631\u0628\u064a\u0651\u0629'), ('bn',
> u'\u09ac\u09be\u0982\u09b2\u09be'), ('ne',
> u'\u0928\u0947\u092a\u093e\u0932\u0940'), ('sq', u'shqip'), ('af',
> u'Afrikaans'), ('sw', u'Kiswahili'), ('pt', u'Portugu\xeas'), ('ru',
> u'\u0420\u0443\u0441\u0441\u043a\u0438\u0439'), ('vi', u'Ti\xea\u0301ng
> Vi\xea\u0323t'), ('ko', u'\ud55c\uad6d\uc5b4'), ('am', 'Amharic'), ('km',
> u'Khmer'), ('pl', u'polski'), ('sv', u'svenska'), ('th',
> u'\u0e20\u0e32\u0e29\u0e32\u0e44\u0e17\u0e22'), ('uk',
> u'\u0423\u043a\u0440\u0430\u0457\u043d\u0441\u044c\u043a\u0430'), ('si',
> 'sinhala'), ('ta', u'tamil'), ('tl', 'tagalog')] FIXTURE_DIRS =
> ABSOLUTE_URL_OVERRIDES = {} DATE_FORMAT = 'N j, Y' NLP_LOCATION_THRESHOLD =
> 1.0 CSRF_FAILURE_VIEW = 'django.views.csrf.csrf_failure' SKIP_PERMS_FILTER
> = False ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE = u'********************'
> MEDIA_ROOT = 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\uploaded'
> AGON_RATINGS_CATEGORY_CHOICES = {'maps.Map': {'map': 'How good is this
> map?'}, 'layers.Layer': {'layer': 'How good is this layer?'},
> 'documents.Document': {'document': 'How good is this document?'}}
> DEFAULT_EXCEPTION_REPORTER_FILTER =
> 'django.views.debug.SafeExceptionReporterFilter' ADMINS =
> FORMAT_MODULE_PATH = None DEFAULT_FROM_EMAIL = 'webmaster at localhost'
> STATICFILES_DIRS = ['C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\static']
> MEDIA_URL = '/uploaded/' DATETIME_FORMAT = 'N j, Y, P' TEMPLATE_DIRS =
> 'C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\templates'
> ALLOWED_DOCUMENT_TYPES = ['doc', 'docx', 'gif', 'jpg', 'jpeg', 'ods',
> 'odt', 'odp', 'pdf', 'png', 'ppt', 'pptx', 'rar', 'sld', 'tif', 'tiff',
> 'txt', 'xls', 'xlsx', 'xml', 'zip', 'gz'] NOTIFICATION_LANGUAGE_MODULE =
> 'account.Account' ACCOUNT_DELETION_EXPUNGE_CALLBACK = ''
> RESOURCE_PUBLISHING = False ACCOUNT_HOOKSET = PROXY_URL = '/proxy/?url='
> SITE_ID = 1 DISALLOWED_USER_AGENTS = ALLOWED_INCLUDE_ROOTS =
> API_LIMIT_PER_PAGE = u'********************' ACCOUNT_SETTINGS_REDIRECT_URL
> = u'account_settings' EXTRA_LANG_INFO = {'tl': {'code': 'tl', 'name':
> 'Tagalog', 'bidi': False, 'name_local': 'tagalog'}, 'am': {'code': 'am',
> 'name': 'Amharic', 'bidi': False, 'name_local': 'Amharic'}, 'si': {'code':
> 'si', 'name': 'Sinhala', 'bidi': False, 'name_local': 'sinhala'}, 'ta':
> {'code': 'ta', 'name': 'Tamil', 'bidi': False, 'name_local': u'tamil'}}
> SRID = {'DETAIL': 'never'} LOGGING = {'loggers': {'geonode': {'handlers':
> ['console'], 'level': 'ERROR'}, 'django': {'handlers': ['console'],
> 'level': 'ERROR'}, 'pycsw': {'handlers': ['console'], 'level': 'ERROR'},
> 'owslib': {'handlers': ['console'], 'level': 'ERROR'}, 'gsconfig.catalog':
> {'handlers': ['console'], 'level': 'ERROR'}}, 'disable_existing_loggers':
> True, 'handlers': {'null': {'class': 'django.utils.log.NullHandler',
> 'level': 'ERROR'}, 'console': {'formatter': 'simple', 'class':
> 'logging.StreamHandler', 'level': 'ERROR'}, 'mail_admins': {'class':
> 'django.utils.log.AdminEmailHandler', 'filters': ['require_debug_false'],
> 'level': 'ERROR'}}, 'formatters': {'simple': {'format': '%(message)s'},
> 'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d
> %(thread)d %(message)s'}}, 'version': 1, 'filters': {'require_debug_false':
> {'()': 'django.utils.log.RequireDebugFalse'}}} SHORT_DATE_FORMAT = 'm/d/Y'
> TWITTER_SITE = '@GeoNode' SLACK_ENABLED = False TEST_RUNNER =
> 'django_nose.NoseTestSuiteRunner' ACTSTREAM_SETTINGS = {'MODELS':
> ('people.Profile', 'layers.layer', 'maps.map', 'dialogos.comment',
> 'documents.document', 'services.service'), 'GFK_FETCH_DEPTH': 1,
> 'USE_JSONFIELD': True, 'FETCH_RELATIONS': True, 'USE_PREFETCH': False}
> MODELTRANSLATION_LANGUAGES = ['en'] HAYSTACK_FACET_COUNTS = False
> CACHE_MIDDLEWARE_KEY_PREFIX = u'********************' DEFAULT_WORKSPACE =
> 'geonode' TIME_ZONE = 'America/Chicago' FILE_UPLOAD_MAX_MEMORY_SIZE =
> 2621440 LOCAL_GEOSERVER = {'source': {'url': '
> 'gxp_wmscsource'}} EMAIL_BACKEND =
> 'django.core.mail.backends.smtp.EmailBackend' ANONYMOUS_USER_ID = -1
> DEFAULT_MAP_ZOOM = 0 TEMPLATE_CONTEXT_PROCESSORS = CELERY_QUEUES = [ ->
> default>, -> cleanup>, -> update>, -> email>] LOCKDOWN_GEONODE = False
> SESSION_COOKIE_AGE = 1209600 SETTINGS_MODULE = 'geonode.settings'
> GUARDIAN_GET_INIT_ANONYMOUS_USER =
> 'geonode.people.models.get_anonymous_user_instance' USE_ETAGS = False
> SOCIAL_BUTTONS = True LANGUAGES = CELERY_TASK_RESULT_EXPIRES = 1
> DEFAULT_INDEX_TABLESPACE = '' INTERNAL_IPS = STATIC_URL = '/static/'
> EMAIL_PORT = 25 LAYER_PREVIEW_LIBRARY = 'geoext' USE_TZ = False
> DEFAULT_SEARCH_SIZE = 10 CLIENT_RESULTS_LIMIT = 100
> MODELTRANSLATION_DEFAULT_LANGUAGE = 'en' ACCOUNT_SIGNUP_REDIRECT_URL = u'/'
> CACHE_MIDDLEWARE_SECONDS = 600 ACCOUNT_CREATE_ON_SAVE = True
> CSRF_COOKIE_HTTPONLY = False DATETIME_INPUT_FORMATS =
> ACCOUNT_EMAIL_CONFIRMATION_REQUIRED = False FORCE_SCRIPT_NAME = None
> PROFANITIES_LIST = u'********************' EMAIL_HOST_USER = ''
> MAX_DOCUMENT_SIZE = 2 You're seeing this error because you have DEBUG =
> True in your Django settings file. Change that to False, and Django will
> display a standard 500 page.
> *CÉSAR DE OLIVEIRA FERREIRA SILVA*
> *Estagiário de Geoprocessamento*
> +55 11 3025.0500 <(11)%203025-0500> | cesar at agroicone.com.br
> [image: cid:image001.png at 01D23130.D9EF5E20]
> <http://../../../../Desktop/Agroicone.html>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170424/aca8e1bd/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170424/aca8e1bd/attachment-0001.png>
More information about the geonode-users mailing list
