[GeoNode-users] Geosites installation error
Fosco Ventura foscone at gmail.com
Wed Apr 26 05:04:21 PDT 2017
Hi Eugenio, thanks.
Did you use geonode 2.6 and geonode project template? Because I haven't the
same file of your readme and neither the same of this
https://github.com/GeoNode/geonode/tree/2.6.x/geonode/contrib/geosites#geosites-project
Is it possible to use geosites in subfolders like http://IP/sito1 and
http://IP/sito2 instead of various domains?
I have installed geonode via apt-get, then I did *django-admin startproject
my_geonode* whit geonode-project template raccomanded from Simone and at
the and I copied site-template in the project folder.
Fosco
2017-04-26 9:26 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Fosco,
> I proposed some changes in the Geosites README file. Those are not yet
> validated,
> however you can take a look to the file, probably it can help,
> see: https://github.com/GeoNode/geonode/pull/3009/files/
> c8a8af3cdc23f06c9ccff666da6c461e4132349f#diff-
> bad3866b9b5ac9dba9a71d8a4f09428b
> cheers
> Eugenio
> *Da:* geonode-users <geonode-users-bounces at lists.osgeo.org> per conto di
> Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* lunedì 24 aprile 2017 19.29
> *A:* Fosco Ventura
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: [GeoNode-users] Geosites installation error
> in your project's dir is fine. It works like any django project, if you
> take a look at the django tutorial you can find very similar setups.
> 2017-04-24 19:28 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>> And I have to copy site-template in dir/dir/contrib/geosites or only in
>> dir/dir like in this guide https://github.com/terranodo/landscapeportal ?
>> 2017-04-24 18:07 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Hi,
>>> geonode-project is just a template, all you may need you can copy into
>>> it. In this case just copy the site-template either from githiub or your
>>> geonode installation (you can search for it and copy) and rename
>>> accordingly.
>>> 2017-04-24 16:52 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>>> Hi Simone,
>>>> I am trying to use geonode-project as base template. For single site it
>>>> works fine but I do not understand how to set it as a multisite. In
>>>> geonode-project template there are not all files mentioned in the geosites
>>>> guides.
>>>> For example in this Eugenio's comment https://github.com/Geo
>>>> Node/geonode/commit/740af85ab5654cee3d27b6611b74c39687a4187c
>>>> #commitcomment-21731291 I need site_template in contrib directory but
>>>> in geonode-project template there isn't.
>>>> How can I do?
>>>> Thanks.
>>>> Fosco
>>>> 2017-04-21 12:41 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> No don't need to checkout another geonode or delete the settings in
>>>>> etc. I suggest you to start from here https://github.com/GeoNod
>>>>> e/geonode-project and once you have it set up then you can create
>>>>> your own settings with geosites enabled and make your own geosites in it.
>>>>> 2017-04-21 12:31 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>>>>> Ok, I have installed geonode 2.6 like quick installation tells, then
>>>>>> I deleted /etc/geonode to replace it with *git
>>>>>> clone https://github.com/GeoNode/geonode
>>>>>> <https://github.com/GeoNode/geonode>*, is it right?
>>>>>> I have duplicated /geonode/geonode/contrib/geosites/site_template
>>>>>> whit a new name.
>>>>>> Now I would like to have:
>>>>>> - www.example.com/site1
>>>>>> - www.example.com/site2
>>>>>> so I go to www.example.com/admin/sites/site/ and add site1 and site2
>>>>>> Now have I to edit /etc/apache2/sites-enabled/geonode.conf? In which
>>>>>> way?
>>>>>> I did:
>>>>>> WSGIDaemonProcess new_name_site_template user=www-data threads=15
>>>>>> processes=2
>>>>>> <VirtualHost *:80>
>>>>>>    DocumentRoot /etc/geonode/geonode/contrib/geosites/
>>>>>>    WSGIProcessGroup fosco_geosites
>>>>>>    WSGIScriptAlias / /etc/geonode/geonode/contrib/g
>>>>>> eosites/new_name_site_template/wsgi.py
>>>>>> but doesn't work.
>>>>>> Where am I wrong?
>>>>>> Thanks.
>>>>>> Fosco
>>>>>> 2017-04-19 17:43 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com
>>>>>>> Hi,
>>>>>>> no you don't need a development installation, you can achieve the
>>>>>>> same using a standard apt geonode installation or a geonode-project.
>>>>>>> Unfortunately the documentation for geosites is a bit outdated but
>>>>>>> you can make it work even without any automatic script. I suggest you to
>>>>>>> take a look at the geonode repo as geosites is now part of it as a contrib
>>>>>>> app (optional and less maintained) https://github.com
>>>>>>> /GeoNode/geonode/tree/2.6.x/geonode/contrib/geosites and the
>>>>>>> geonode homepage and docs for the installation
>>>>>>> http://www.geonode.org.
>>>>>>> In order to use geosites you will have to understand the basics of
>>>>>>> django projects, nothing too tricky though.
>>>>>>> Recently Eugenio made some interesting comments on the geosites doc
>>>>>>> that could help you, see here https://github.com/GeoNod
>>>>>>> e/geonode/commit/740af85ab5654cee3d27b6611b74c39687a4187c#co
>>>>>>> mmitcomment-21731038
>>>>>>> hope this helps
>>>>>>> 2017-04-19 17:23 GMT+02:00 Fosco Ventura <foscone at gmail.com>:
>>>>>>>> Hi, I'm trying to install geosites.
>>>>>>>> I followed this guide for ubuntu development installation:
>>>>>>>> https://github.com/simod/geonode#ubuntu
>>>>>>>> and then this guide for geosites: https://github.com/t
>>>>>>>> erranodo/geosites-project/blob/master/GEOSITES-README.md
>>>>>>>> I realized that to have geosites I have to do development
>>>>>>>> installation, is it true?
>>>>>>>> When I give *bash ./setup.sh example.org <http://example.org>* I
>>>>>>>> have this error:
>>>>>>>> *Command "python setup.py egg_info" failed with error code 1 in
>>>>>>>> /tmp/pip-build-8XOXyi/Paver**/*
>>>>>>>> I looked for directory pip-build-8XOXyi but doesn't exist.
>>>>>>>> Is this command the same of geonode-updateip for standard
>>>>>>>> installation? Can I give *bash ./setup.sh IP* instead of
>>>>>>>> example.org?
>>>>>>>> Thanks
>>>>>>>> Fosco
>>>>>>>> Fosco
>>>>>>>> http://studiotypo.it/
>>>>>>>> http://www.studiotypo.it/fosco/
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> Simone
>>>>>> Fosco
>>>>> Simone
>>>> Fosco
>>> Simone
>> Fosco
> Simone
Fosco
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170426/7456aac9/attachment.html>
More information about the geonode-users mailing list
