[GeoNode-users] Problem with GeoServer
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Aug 18 04:44:22 PDT 2017
Hi Ana,
For your installation the command is simply "geonode updatelayers ".
Best
Il giorno ven 18 ago 2017 alle 02:53 Jonathan Doig <j.doig at unsw.edu.au> ha
scritto:
> Hi Ana
> That’s odd. You should have manage.py in your geonode top-level
> installation directory.
> Here’s what I have in that directory (for Geonode 2.4):
> jdoig at cftest:/mnt/data/geonode/geonode$ ls
> AUTHORS docs fig.yml geoserver manage.py package
> README scripts setup.py
> Dockerfile downloaded geonode license.txt MANIFEST.in pavement.py
> README.rst setup.cfg
> The current Geonode master also has it in the same place – it’s a standard
> file for Django apps (which Geonode is):
> https://github.com/geonode/geonode/
> I don’t know what else to suggest.
> Regards
> Jonathan
> *From:* Ana Boljevic [mailto:ana.boljevic at cedis.me]
> *Sent:* Friday, 18 August 2017 4:43 PM
> *To:* Jonathan Doig <j.doig at unsw.edu.au>; geonode-users at lists.osgeo.org
> *Subject:* RE: Problem with GeoServer
> Dear Jonathan,
> We have deleted two layers you have mentioned (OPSTINE & OPSTINE0 and
> layer cedis:opgw_gm). We are waiting for results. In meantime, we have
> some python issue.
> As far as I understand, when some changes happends on the GeoServer,
> Geonode is not aware of those changes automatically. I must update Geonode
> with command:
> python manage.py updatelayers. But, unfortunately I can't do it. You can
> find output in attachment . We have installed geonode doing:
> - install Ubuntu 16.04
> - making quick installation of geonode (version 2.6.1) by doing:
> 1) sudo apt-get update; sudo apt-get upgrade
> 2) sudo add-apt-repository ppa:geonode/stable
> 3) sudo apt-get update; sudo apt-get install geonode
> 4) geonode createsuperuser
> 5) sudo geonode-updateip 10.0.0.112
> If you can give as any hint, idea or help, for making management python
> command we would be thankful.
> Regards,
> Ana
> *From:* Jonathan Doig [j.doig at unsw.edu.au]
> *Sent:* Thursday, August 17, 2017 2:05 AM
> *To:* Ana Boljevic; geonode-users at lists.osgeo.org
> Hi Ana
> I see a lot of ERRORs in the log relating to styles OPSTINE & OPSTINE0,
> and layer cedis:opgw_gm.
> I would try deleting these if you can, from Geonode or failing that from
> the Geoserver console at <hostname>/geoserver.
> That may have nothing to do with the problem though. Not sure what else to
> suggest but others here know a lot more about it.
> You could also set up monitoring of your /geoserver URL e.g. at
> monitis.com. That would at least tell you when it dies, and help you
> pinpoint the cause via the logs.
> Regards
> Jonathan
> *From:* Ana Boljevic [mailto:ana.boljevic at cedis.me <ana.boljevic at cedis.me>]
> *Sent:* Wednesday, 16 August 2017 7:41 PM
> Dear Jonathan,
> Thank You for quick answer!
> We have already tried with ‘sudo service tomcat7 restart’, and when we do
> so, it takes time to start working or we have to do this several times.
> We have checked logs in /usr/share/geoserver/data/logs and here is what we
> have
> https://www.dropbox.com/s/pvs2yl8coxrlnux/geoserver.log%20-%20Copy.1?dl=0 (on
> path /var/lib/tomcat7/webapps/geoserver/data/logs we can't find anything).
> We don't know when it died but around 7:30 am this morning we know it was
> crashed. Around 9 am everything started working normally again without even
> a restart, just by itself, and we don't know when it will die again (we are
> trying to find out what is the cause - we are uploading kml files and attribute
> names have correct form). If you can check these logs and give as any
> hint, idea or help, we would be thankful.
> Our version of Geonode is 2.6.1
> Thanks in advance,
> *Ana Boljević *
> *Direkcija za razvoj, pristup mreži i TIS*
> *Služba za GIS i tehničku bazu podataka*
> *Sektor za TIS*
> *Sent:* Wednesday, August 16, 2017 9:26 AM
> Hi Ana
> This probably means Geoserver has died and you need to restart it with
> ‘sudo service tomcat7 restart’.
> As to the cause, you should check the geoserver logs for ERRORs that
> occured shortly before or at the time of death. On our system these logs
> are in /var/lib/tomcat7/webapps/geoserver/data/logs.
> I’ve found (on Geonode 2.4) that uploading a shapefile with errors can
> kill Geoserver. E.g. a shapefile with attribute names that do not start
> with a letter or contain characters other than letters, digits and
> underscore. Sad but true.
> Good luck!
> Jonathan
> *From:* geonode-users [mailto:geonode-users-bounces at lists.osgeo.org
> <geonode-users-bounces at lists.osgeo.org>] *On Behalf Of *Ana Boljevic
> *Sent:* Wednesday, 16 August 2017 4:53 PM
> *To:* geonode-users at lists.osgeo.org
> *Subject:* [GeoNode-users] Problem with GeoServer
> Dear Sir,
> We have recently installed GeoNode on Ubuntu 16.04 Server (installation
> was standard deployment, not development mode). Everything is working fine
> except one problem: from time to time we can't see layers (only pink tiles
> - image1 in attachment), and when that happends we can't access to
> GeoServer admin page through web browser (error 404 - image2 in attachment).
> We have no idea why is this happening. Any hint or help would be helpful.
> Thanks in advance,
> *Ana Boljević *
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170818/9e37d54b/attachment-0001.html>
More information about the geonode-users
