[GeoNode-users] Backup problem
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Aug 25 01:02:01 PDT 2017
Which version of GeoNode? Recently some fixes to the backup script have
been pushed on latest GeoNode versions.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Mon, Aug 21, 2017 at 8:42 AM, Ana Boljevic <ana.boljevic at cedis.me> wrote:
> Dear GeoNode community,
> We have user installation geonode on Ubuntu 16.04 server (standard
> deployment, not developement). For some reason, backup from command line is
> not working. I have to enter password for every layer with output "pg_dump:
> No matching tables were found". If you give as any hint, idea or help, we
> would be thankful.
> geonode at gis:~$ sudo geonode backup --backup-dir=/tmp
> Before proceeding with the Backup, please ensure that:
>  1. The backend (DB or whatever) is accessible and you have rights
>  2. The GeoServer is up and running and reachable from this machine
> You want to proceed? [n]|y: y
> Dumping 'GeoServer Catalog [http://10.0.0.112/geoserver/]' into
> '/tmp/2017-08-21_011848 <011%20848>/geoserver_catalog.zip'.
> STARTED - 1/9
> COMPLETED - 9/9
> Dumped GeoServer Uploaded Data from '/opt/gs_data_dir/data/geonode'.
> Dumping GeoServer Vectorial Data : novi_DV_35_kV_NiksicTrebjesa
> Password:
> pg_dump: No matching tables were found
> Dumping GeoServer Vectorial Data : novi_DV_35kV_Podgor_Utrg
> Password:
> Dumping GeoServer Vectorial Data : novi_novo_selo_10
> Password:
> Dumping GeoServer Vectorial Data : novi_DV_110_kV_Virpazar___Bar
> Password:
> Dumping GeoServer Vectorial Data : topology
> Password:
> Dumping GeoServer Vectorial Data : layer
> Password:
> [1]+  Stopped                 sudo geonode backup --backup-dir=/tmp
> Regards,
> Ana
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170825/ebaef777/attachment.html>
More information about the geonode-users mailing list
