[GeoNode-users] Create issue with the shapefiel
Simone Dalmasso simone.dalmasso at gmail.com
Tue Aug 29 06:47:00 PDT 2017
Unfortunately we cannot change geoexplorer. We have another new client but
still lacks styling tools.
You could untick the "use tiled version" in the layer display tab in
geoexplorer.
Il giorno mar 29 ago 2017 alle 15:34 Naresh N <naresh919 at gmail.com> ha
scritto:
> Dear Simone,
>  Thanks for the response.
>  Since many of the users uses EDIT/Modify to create/edit new features in
> uploaded layer. But after editing/creating the features are loading
> partially only initially and users getting confuse. However if we add same
> layer as WMS in other portals it is loading fine. Even in layer preview of
> Geoserver also all the features loading properly.
>  I think it is issue with Geoexplorer settings .
>  Kindly look into this issue and please suggest.
> Thanks&Regards,
> Naresh
> On Tue, Aug 29, 2017 at 6:43 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Naresh, not sure what to tell. I the past I also experienced issues with
>> styles caching in geoserver, without specific errors.
>> Do not rely on demo as someone changed the default workspace and things
>> are screwed up.
>> 2017-08-29 13:17 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone/Paolo,
>>> This is issue is observed in demo geonode site also . Please login with
>>> admin account and visit this link
>>> http://demo.geonode.org/maps/new?layer=hr1:shape_first_1
>>> Please let me know any other information required to give solution.
>>> Kindly help me to fix, as it is very important functionality of GeoNode
>>> Thanks&Regards,
>>> Naresh
>>> On Tue, Aug 29, 2017 at 11:25 AM, Naresh N <naresh919 at gmail.com> wrote:
>>>> Dear Paolo/Simone
>>>> Thanks for reply. I have been trying from last couple of days to
>>>> resolve I am not able to do. Kindly help me. Few more details about my
>>>> settings.
>>>> I have disable the caching in my geoserver, even though I am facing
>>>> same issue.
>>>> As I am doing any one of the following  all the features are loading
>>>> properly
>>>> *(i) Increase and decrease the zoom level (ii) Clicking on Layer
>>>> Properties Symbol and Clicked on DISPLAY tab  (iii) Close the layer panel
>>>> and again open the layer panel*
>>>> *How  and where to write the  code in GeoNode, so that with out manual
>>>> intervention an one of the above task should execute.*
>>>> Thanks&Regards,
>>>> Naresh. N
>>>> On Sun, Aug 13, 2017 at 1:51 AM, Paolo Corti <pcorti at gmail.com> wrote:
>>>>> Hi
>>>>> We should determine if it is a GeoServer or GeoNode problem.
>>>>> GeoServer should automatically update the GeoWebCache tile cache when
>>>>> editing features using a WFS transaction - at least this was working
>>>>> properly at GeoNode 2.4. Can you check if the GeoWebCache cache is
>>>>> correctly updated for that layer?
>>>>> If not, this could be a client cache issue?
>>>>> p
>>>>> On Fri, Aug 11, 2017 at 8:37 AM, Naresh N <naresh919 at gmail.com> wrote:
>>>>> >  Dear All,
>>>>> > Please suggest for the following queries
>>>>> > 1. Uploaded spatial data(Shapefile). Viewed the uploaded data on Map
>>>>> > composer,selected create          option from Edit drop down menu and
>>>>> > created new features.
>>>>> >   a. Clicked on Layers list and selected same layer/uploaded data
>>>>> and used
>>>>> > Create Map option,in              map composer few of the newly
>>>>> created
>>>>> > features are not loaded. However If I do any one of the
>>>>> following
>>>>> > actions on map composer all the features are visible
>>>>> >        (ii) Clicking on Layer Properties Symbol and Clicked on
>>>>> DISPLAY tab
>>>>> >        (iii) Close the layer panel and again open the layer panel
>>>>> >       Please suggest what is the issue? how to resolve above
>>>>> >    b.Clicked on  Layers list and selected same layer/uploaded data
>>>>> and Layer
>>>>> > preview all the features are not visible in all the zoom levels.
>>>>> > Thanks&Regards,
>>>>> > Naresh.N
>>>>> > _______________________________________________
>>>>> > geonode-users mailing list
>>>>> > geonode-users at lists.osgeo.org
>>>>> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Paolo Corti
>>>>> Geospatial software developer
>>>>> web: http://www.paolocorti.net
>>>>> twitter: @capooti
>>>>> skype: capooti
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170829/b38ec24a/attachment.html>
More information about the geonode-users mailing list
