[GeoNode-users] Base layer is not visible on thumbnail of the uploaded content
Paolo Corti
pcorti at gmail.com
Thu Aug 31 11:57:43 PDT 2017
I have answered in the ticket, and I do not think this is a bug, so I
would close it.
The correct way to handle this is with the delete_orphaned_thumbs Celery task.
There is a command which should handle this and that you can schedule
in case you don't want the Celery/RabbitMQ overhead:
cheers
p
On Mon, Aug 28, 2017 at 11:09 PM, Naresh N <naresh919 at gmail.com> wrote:
> Dear Jonathan,
> Thanks for the reply. I have added this issue in Github.
> As you said there will not be no impact for user, I was thinking that ,it
> may be issue with my settings. However when we migrate from newer
> versions/replicate to more than one server , we need to copy all unnecessary
> images. And even it is difficult to delete the thumbnails manually which are
> no more use as there is no direct link with existing layers.
> Thanks&Regards,
> Naresh
> On Tue, Aug 29, 2017 at 5:50 AM, Jonathan Doig <j.doig at unsw.edu.au> wrote:
>> Hi Naresh
>> When we delete the layer/map the corresponding thumbnail is not deleting
>> from the server.
>> Hadn’t noticed that, but just confirmed it on our site. I suggest you add
>> this as an new issue. I can’t see how it would have any impact on users, but
>> it’s messy and should be cleaned up.
>> Regards
>> Jonathan
>> From: Naresh N [mailto:naresh919 at gmail.com]
>> Sent: Monday, 28 August 2017 6:50 PM
>> To: Jonathan Doig <j.doig at unsw.edu.au>
>> Cc: Simone Dalmasso <simone.dalmasso at gmail.com>; geonode-users
>> lists.osgeo.org <geonode-users at lists.osgeo.org>
>> Subject: Re: [GeoNode-users] Base layer is not visible on thumbnail of the
>> uploaded content
>> Dear Jonathan,
>> Thanks a lot for detailed explanation.
>> It may be good , this kind of functionality may be implemented in newer
>> version of GeoNode, since with out base layer the thumbnail does not looking
>> good, user has to manually set
>> from the server. How to delete thumbnails in case of deletion of layers/maps
>> Thanks&Regards,
>> Naresh
>> On Mon, Aug 28, 2017 at 11:04 AM, Jonathan Doig <j.doig at unsw.edu.au>
>> wrote:
>> Hi Naresh
>> This has been an open issue since 2015. Here is a bit more explanation:
>> https://github.com/GeoNode/geonode/issues/2025
>> Also some notes from our own user guide:
>> Your browser caches images, so the thumbnail may not appear to change.
>> Refresh the page with a ‘hard reload’ (Ctrl + Shift + R on Chrome, see
>> instructions for other browsers).
>> Please be patient, as larger datasets may take several minutes to display
>> the first time. The system builds a tiled image cache for new layers, so
>> subsequent rendering is virtually instantaneous.
>> Finally, if all else fails and you have access to the server you can
>> create a thumbnail ‘manually’ and FTP it to the uploaded/thumbs folder,
>> overwriting the automatically created thumbnail. To find the filename to
>> use, right-click the thumbnail and select ‘Copy image address’.
>> Regards
>> Jonathan
>> From: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] On
>> Behalf Of Naresh N
>> Sent: Monday, 28 August 2017 2:03 PM
>> To: Simone Dalmasso <simone.dalmasso at gmail.com>
>> Cc: geonode-users lists.osgeo.org <geonode-users at lists.osgeo.org>
>> uploaded content
>> Dear Simone,
>> Thanks a lot for answering my query.
>> 1. However in case of Map - Thumbail -- when we publish/save the
>> thumbnail is getting generated with the base layer. Please suggest can we do
>> modification in code,
>> so that when we upload the layer , the thumbnail should be
>> generated with the default selected base layer along with the uploaded
>> content.
>> 2. Even some times when we click on SetThumbnail, the thumbnail is not
>> refreshing and if we reload the page or click on the some other links the
>> thumbnail get refreshers.
>> I thinks there is some time delay or refresh problem. How do we over
>> come this issue?
>> Thanks&Regards,
>> Naresh. N
>> On Fri, Aug 25, 2017 at 5:29 PM, Simone Dalmasso
>> <simone.dalmasso at gmail.com> wrote:
>> Hi Naresh, that is not possible. The baselayer can only be visible if the
>> client is currently showing a map with it and can send it to the server
>> along with the thumbnail request. This is not available on layer upload.
>> 2017-08-24 14:03 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear All,
>> After uploading the layer, if we click on layers list, the corresponding
>> layer thumbnail base layers are not visible. If we click on the
>> corresponding Layers --> Edit Layer if we click on Set Thumbnail then base
>> layers along with uploaded content is visible in thumbnail
>> Please suggest how to include the base layers also in thumbnail on upload
>> of spatial data with out manually clicking Set Thumbnail option.
>> Thanks&Regards,
>> Naresh
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
