[GeoNode-users] I can't upload layers
Ariel Neri
ariel.neriw at gmail.com
Wed Dec 6 07:46:50 PST 2017
Hi, I found a work around on the problem, by changing the security
settings. I changed the Active role settings to "default" and now users can
upload layers normally. What i don´t know is what else does this change
imply. Will it cause any other problem?
Thanks.
Ariel
2017-11-30 6:21 GMT-03:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> In my new brand installation I've the same settings. But I haven't yet
> tried to use it nor to migrate my data.
> When I had the issue on July, I've tried all the combinations, without
> success.
> 2017-11-28 15:26 GMT+01:00 Ariel Neri <ariel.neriw at gmail.com>:
>> Hallo Toni, thanks for your response. I could not open the link you sent.
>> This is my actual geonode-auth2 configuration:
>> [image: Imagen integrada 1]
>> 192.168.0.56 is the local server IP. Is this right?
>> Should i change the remaining "localhost" for our server ip?
>> Thanks
>> Ariel
>> 2017-11-28 3:59 GMT-03:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>
>>> Dear Ariel,
>>> Some time ago I faced the same problem on a fresh 2.6 istallation.
>>> I could not upload layers. What worked for me is setting the
>>> endpoints in geoserver gui > security > authentification > geonode-oauth2
>>> again.
>>> The problem was that I´ve set public IP where geocode / geoserver
>>> expected localhost.
>>> In specific this is how it worked for me:
>>> https://www.dropbox.com/s/8obsa07625t96gk/oauth.png?dl=0
>>> replace MYPUBLIC IP with the one set in local_settings. and just to be
>>> save restart
>>> tomcat ...
>>> Cheers,
>>> Toni
>>> CSGIS
>>> Kolonnadenstraße 1
>>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+104109+Leipzig&entry=gmail&source=g>
>>> 04109 Leipzig
>>> Mobil +49/ (0) 176 6680 3198 <+49%20176%2066803198>
>>> Tel +49/ (0) 341 24 04 738 <+49%20341%202404738>
>>> Fax +49/ (0) 341 24 04 73 <+49%20341%20240473>
>>> Web http://csgis.de
>>> Hinweis gemäß § 33 BDSG
>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>> ausschließlich für den
>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>> diese E-Mail versehentlich
>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>> löschen Sie diese Nachricht
>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>> Vervielfältigung, Veränderung,
>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>> Am 27.11.2017 um 20:20 schrieb geonode-users-request at lists.osgeo.org:
>>> Message: 1
>>> Date: Mon, 27 Nov 2017 12:25:37 -0300
>>> From: Ariel Neri <ariel.neriw at gmail.com>
>>> To: Francesco Bartoli <xbartolone at gmail.com>
>>> Cc: Annalisa Schiavon <annalisa.schiavon at gmail.com>, geonode-users
>>> <geonode-users at lists.osgeo.org>
>>> Subject: Re: [GeoNode-users] I can't upload layers
>>> Message-ID:
>>> <CAKd8vt+6bCPhN2Ap+mrSmkCJB5r-8sXjh8QSPsZt8nnSOrPX=w at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> Hi Annalisa, could you fix this issue? I´m facing the same problem and i
>>> would like to how you did it. Thanks!
>>> Ariel
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171206/0da98cee/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171206/0da98cee/attachment-0001.png>
More information about the geonode-users
