[GeoNode-users] FW: Cannot upload layers
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Dec 19 05:31:06 PST 2017
Did you correctly configured the database passwords and connection params
on settings.py or local_settings.py ?
Try to give a look here also
http://training.geonode.geo-solutions.it/002_install_and_admin/002_geonode_install/create_geonode_db.html
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Tue, Dec 19, 2017 at 2:20 PM, <Stefano.LUONI at ext.ec.europa.eu> wrote:
> My issue is still unresolved and I don't know how to deeply debug it.
> I get errors while trying to upload both shape files and raster files; the
> only difference is that the process blocks at different points, since I
> already have a PostGIS data store in GeoServer that would be used for shape
> files.
> Apparently, Geonode is unable to create a store into GeoServer. This is an
> extract of Apache error log.
> [Tue Dec 19 07:04:02.118664 <02%20118664> 2017] [wsgi:error] [pid
> 4932:tid 140059365070592]   File "/home/luonist/risk_data_hub/
> my_venv/local/lib/python2.7/site-packages/geoserver/catalog.py", line
> 555, in _create_coveragestore
> [Tue Dec 19 07:04:02.118685 <02%20118685> 2017] [wsgi:error] [pid
> 4932:tid 140059365070592]     raise UploadError(response)
> [Tue Dec 19 07:04:02.118707 <02%20118707> 2017] [wsgi:error] [pid
> 4932:tid 140059365070592] UploadError: Could not save the layer bogota,
> there was an upload error: <!DOCTYPE html><html><head><title>Apache
> Tomcat/8.0.32 (Ubuntu) - Error report</title><style type="text/css">H1
> {font-family:Tahoma,Arial,sans-serif;color:white;
> background-color:#525D76;font-size:22px;} H2 {font-family:Tahoma,Arial,
> sans-serif;color:white;background-color:#525D76;font-size:16px;} H3
> background-color:#525D76;font-size:14px;} BODY {font-family:Tahoma,Arial,
> sans-serif;color:black;background-color:white;} B
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;}
> P {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A
> {color : black;}A.name {color : black;}.line {height: 1px;
> background-color: #525D76; border: none;}</style> </head><body><h1>HTTP
> Status 403 - Access is denied</h1><div class="line"></div><p><b>type</b>
> Status report</p><p><b>message</b> <u>Access is denied</u></p><p><b>description</b>
> <u>Access to the specified resource has been forbidden.</u></p><hr
> class="line"><h3>Apache Tomcat/8.0.32 (Ubuntu)</h3></body></html>
> From GeoServer logs, I only find an error that comes later, when it looks
> for a store that should have been created before (if I understand
> correctly):
> 2017-12-19 13:04:02,014 ERROR [geoserver.rest] - No such datastore:
> geonode,bogota
> 2017-12-19 13:04:02,016 ERROR [geoserver.rest] -
> org.geoserver.rest.RestletException
> 2017-12-19 13:04:02,050 ERROR [geoserver.rest] - No such coverage store:
> geonode,bogota
> 2017-12-19 13:04:02,051 ERROR [geoserver.rest] -
> 2017-12-19 13:04:02,080 ERROR [geoserver.rest] - No such wms store:
> geonode,bogota
> I'm using Geonode 2.7.4, GeoServer 2.10 (taken from
> http://build.geonode.org/geoserver/latest/), Apache 2.4, Tomcat 8,
> OpenJDK 1.8.0_151
> Thank you very much,
> Stefano
> *From:* geonode-users [geonode-users-bounces at lists.osgeo.org] on behalf
> of Stefano.LUONI at ext.ec.europa.eu [Stefano.LUONI at ext.ec.europa.eu]
> *Sent:* 18 December 2017 09:50
> *To:* alessio.fabiani at geo-solutions.it
> *Cc:* geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] Cannot upload layers
> Hi Alessio,
> yes, the GeoServer WAR file came with the development installation (paver
> setup); I then moved the WAR file into Tomcat directory, in order to
> replace Jetty with Tomcat as container for GeoServer. I'm already using the
> Geonode authentication on GeoServer, though.
> *From:* Alessio Fabiani [alessio.fabiani at geo-solutions.it]
> *Sent:* 13 December 2017 18:16
> *To:* LUONI Stefano (JRC-ISPRA-EXT)
> *Cc:* geonode-users
> Are you using one of the GeoServer WARs and DataDir prepared for GeoNode?
> Regards,
> Alessio Fabiani
> http://goo.gl/it488V for more information.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> phone: +39 0584 962313 <0584%20962313>
> fax:     +39 0584 1660272 <0584%20166%200272>
> mob:   +39 331 6233686 <331%20623%203686>
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Wed, Dec 13, 2017 at 6:04 PM, <Stefano.LUONI at ext.ec.europa.eu> wrote:
>> Hi,
>> I'm facing this issue: whenever I try to upload a layer (both shape file
>> or raster), I receive a 403 error (Access is denied) from Tomcat.
>> Error code (403) from GeoServer:
>> HTTP Status 403 - Access is denied
>> *type* Status report
>> *message* *Access is denied*
>> *description* *Access to the specified resource has been forbidden.*
>> I'm working on a custom installation of Geonode v.2.7.4 on Ubuntu 16.04.
>> I replaced Jetty with Tomcat8 as container for Geoserver, which is
>> 2.10-SNAPSHOT.
>> In Geoserver logs, I can find these errors:
>> ERROR [org.geoserver.rest] - No such coverage store: geonode,geonode_data
>> ERROR [org.geoserver.rest] - No such wms store: geonode,geonode_data
>> From Apache logs, I see that there is an exception thrown by
>> 249, in save
>> (headers['status'], body))
>> FailedRequestError: Error code (403) from GeoServer
>> Postgre sql is working correctly and I already configured and enabled a
>> "datastore" PostGIS store in Geoserver.
>> I followed all instructions about custom installation of Geonode (
>> http://docs.geonode.org/en/master/tutorials/admin/install/
>> custom_install.html) and advanced security (http://docs.geonode.org/en/ma
>> ster/tutorials/admin/geoserver_geonode_security/).
>> I checked that files exist in the "uploaded" directory under Geonode
>> folder.
>> I don't know what to do further to debug this issue.
>> Can you help me?
>> Stefano
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171219/bbd27ee8/attachment-0001.html>
More information about the geonode-users mailing list
