[GeoNode-users] FW: Cannot upload layers
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Dec 19 08:56:18 PST 2017
So,
I did some tests with your datasets and GeoNode is able to import them
correctly
[image: Inline image 1]
I'm currently using the GeoNode master with GeoServer 2.12.x, but I don't
think that your issue is related to the versions actually.
I am pretty sure that something is wrong with your overall configuration,
but it's hard to say without looking into the server config.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Tue, Dec 19, 2017 at 4:46 PM, <Stefano.LUONI at ext.ec.europa.eu> wrote:
> The machine is not reachable from outside JRC network at this time,
> unfortunately.
> If it can be of help, I can send you the GeoServer data directory, Apache
> virtual host, Geonode settings file and the GeoTiff layer we were testing
> before.
> *From:* Alessio Fabiani [alessio.fabiani at geo-solutions.it]
> *Sent:* 19 December 2017 16:01
> *To:* LUONI Stefano (JRC-ISPRA-EXT)
> *Cc:* GeoSolutions - JAI; geonode-users
> *Subject:* Re: [GeoNode-users] FW: Cannot upload layers
> That is very strange. Do you have a sample that I can test locally?
> Regards,
> Alessio Fabiani
> http://goo.gl/it488V for more information.
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> phone: +39 0584 962313 <0584%20962313>
> fax: +39 0584 1660272 <0584%20166%200272>
> mob: +39 331 6233686 <331%20623%203686>
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Dec 19, 2017 at 3:41 PM, <Stefano.LUONI at ext.ec.europa.eu> wrote:
>> Yes, I already checked that this file could be processed by GeoServer. If
>> I try to load it directly from GeoServer, SRS are detected (EPSG:21892), as
>> well as bounds and the layer can be published.
>> I don't understand why GeoServer should not be able to read the file.
>> This file is just an example, but I get an upload error from Tomcat for
>> shape files too.
>> *Sent:* 19 December 2017 15:18
>> Ah but "bogota" is a GeoTIFF or something? Is it gridded data or
>> vectorial data?
>> From the logs it looks like GeoNode tries to create a Coverage Store and
>> GeoServer somehow is not able to read the file.
>> It could be worth trying to ingest the file directly on GeoServer in
>> order to understand if the server is able to recognize it or not. Maybe it
>> needs some GDAL pre-processing in order to be correctly managed by
>> GeoServer.
>> Regards,
>> Alessio Fabiani
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> On Tue, Dec 19, 2017 at 3:02 PM, <Stefano.LUONI at ext.ec.europa.eu> wrote:
>>> Please, find the log attached to this email.
>>> Thank you Alessio!
>>> *Sent:* 19 December 2017 14:51
>>> Yes it is really strange.
>>> Can you try to configure the GeoServer log level to verbose and send to
>>> me the "geoserver.log" file ?
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> On Tue, Dec 19, 2017 at 2:48 PM, <Stefano.LUONI at ext.ec.europa.eu> wrote:
>>>> Yes, all database configs are correct; I followed the guide in the link
>>>> you posted and I also have a PostGIS store correctly enabled in GeoServer,
>>>> using those credentials.
>>>> I have the same versions of Geonode and Geoserver (and Postgre sql as
>>>> well) on a local development machine and everything works fine there. I
>>>> have issues on this other machine, where I'm using Apache (on port 80) with
>>>> WSGI daemon and Tomcat, instead of server on port 8000 and Jetty that come
>>>> with the basic development installation.
>>>> I also moved the Geoserver data directory to a custom
>>>> /data/geoserver-data, after copying all contents of the original folder
>>>> into the new one.
>>>> I also set 777 permissions on both uploaded/layers of Geonode and
>>>> GeoServer data directory, just to be sure that the problem was not there.
>>>> So, I guess something is wrong with Tomcat configurations, but I don't
>>>> know what (I also followed all guides I found, by the way).
>>>> *Sent:* 19 December 2017 14:31
>>>> *Cc:* geonode-users
>>>> Did you correctly configured the database passwords and connection
>>>> params on settings.py or local_settings.py ?
>>>> Try to give a look here also
>>>> http://training.geonode.geo-solutions.it/002_install_and_adm
>>>> in/002_geonode_install/create_geonode_db.html
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>>> 55054
>>>> Massarosa
>>>> (LU)
>>>> Italy
>>>> On Tue, Dec 19, 2017 at 2:20 PM, <Stefano.LUONI at ext.ec.europa.eu>
>>>> wrote:
>>>>> My issue is still unresolved and I don't know how to deeply debug it.
>>>>> I get errors while trying to upload both shape files and raster files;
>>>>> the only difference is that the process blocks at different points, since I
>>>>> already have a PostGIS data store in GeoServer that would be used for shape
>>>>> files.
>>>>> Apparently, Geonode is unable to create a store into GeoServer. This
>>>>> is an extract of Apache error log.
>>>>> [Tue Dec 19 07:04:02.118664 <02%20118664> 2017] [wsgi:error] [pid
>>>>> 4932:tid 140059365070592] File "/home/luonist/risk_data_hub/m
>>>>> y_venv/local/lib/python2.7/site-packages/geoserver/catalog.py", line
>>>>> 555, in _create_coveragestore
>>>>> [Tue Dec 19 07:04:02.118685 <02%20118685> 2017] [wsgi:error] [pid
>>>>> 4932:tid 140059365070592] raise UploadError(response)
>>>>> [Tue Dec 19 07:04:02.118707 <02%20118707> 2017] [wsgi:error] [pid
>>>>> 4932:tid 140059365070592] UploadError: Could not save the layer bogota,
>>>>> there was an upload error: <!DOCTYPE html><html><head><title>Apache
>>>>> Tomcat/8.0.32 (Ubuntu) - Error report</title><style type="text/css">H1
>>>>> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;}
>>>>> H2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;}
>>>>> H3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;}
>>>>> BODY {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;}
>>>>> B {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;}
>>>>> P {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A
>>>>> {color : black;}A.name {color : black;}.line {height: 1px;
>>>>> background-color: #525D76; border: none;}</style> </head><body><h1>HTTP
>>>>> Status 403 - Access is denied</h1><div class="line"></div><p><b>type</b>
>>>>> Status report</p><p><b>message</b> <u>Access is
>>>>> denied</u></p><p><b>description</b> <u>Access to the specified
>>>>> resource has been forbidden.</u></p><hr class="line"><h3>Apache
>>>>> Tomcat/8.0.32 (Ubuntu)</h3></body></html>
>>>>> From GeoServer logs, I only find an error that comes later, when it
>>>>> looks for a store that should have been created before (if I understand
>>>>> correctly):
>>>>> 2017-12-19 13:04:02,014 ERROR [geoserver.rest] - No such datastore:
>>>>> geonode,bogota
>>>>> 2017-12-19 13:04:02,016 ERROR [geoserver.rest] -
>>>>> org.geoserver.rest.RestletException
>>>>> 2017-12-19 13:04:02,050 ERROR [geoserver.rest] - No such coverage
>>>>> store: geonode,bogota
>>>>> 2017-12-19 13:04:02,051 ERROR [geoserver.rest] -
>>>>> 2017-12-19 13:04:02,080 ERROR [geoserver.rest] - No such wms store:
>>>>> geonode,bogota
>>>>> I'm using Geonode 2.7.4, GeoServer 2.10 (taken from
>>>>> http://build.geonode.org/geoserver/latest/), Apache 2.4, Tomcat 8,
>>>>> OpenJDK 1.8.0_151
>>>>> Thank you very much,
>>>>> Stefano
>>>>> *From:* geonode-users [geonode-users-bounces at lists.osgeo.org] on
>>>>> behalf of Stefano.LUONI at ext.ec.europa.eu [
>>>>> Stefano.LUONI at ext.ec.europa.eu]
>>>>> *Sent:* 18 December 2017 09:50
>>>>> *To:* alessio.fabiani at geo-solutions.it
>>>>> *Cc:* geonode-users at lists.osgeo.org
>>>>> *Subject:* Re: [GeoNode-users] Cannot upload layers
>>>>> Hi Alessio,
>>>>> yes, the GeoServer WAR file came with the development installation
>>>>> (paver setup); I then moved the WAR file into Tomcat directory, in order to
>>>>> replace Jetty with Tomcat as container for GeoServer. I'm already using the
>>>>> Geonode authentication on GeoServer, though.
>>>>> *Sent:* 13 December 2017 18:16
>>>>> *Cc:* geonode-users
>>>>> Are you using one of the GeoServer WARs and DataDir prepared for
>>>>> GeoNode?
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> 55054
>>>>> Massarosa
>>>>> (LU)
>>>>> Italy
>>>>> On Wed, Dec 13, 2017 at 6:04 PM, <Stefano.LUONI at ext.ec.europa.eu>
>>>>> wrote:
>>>>>> Hi,
>>>>>> I'm facing this issue: whenever I try to upload a layer (both shape
>>>>>> file or raster), I receive a 403 error (Access is denied) from Tomcat.
>>>>>> Error code (403) from GeoServer:
>>>>>> HTTP Status 403 - Access is denied
>>>>>> *type* Status report
>>>>>> *message* *Access is denied*
>>>>>> *description* *Access to the specified resource has been forbidden.*
>>>>>> Apache Tomcat/8.0.32 (Ubuntu)
>>>>>> I'm working on a custom installation of Geonode v.2.7.4 on Ubuntu
>>>>>> 16.04. I replaced Jetty with Tomcat8 as container for Geoserver, which is
>>>>>> 2.10-SNAPSHOT.
>>>>>> In Geoserver logs, I can find these errors:
>>>>>> ERROR [org.geoserver.rest] - No such coverage store:
>>>>>> geonode,geonode_data
>>>>>> ERROR [org.geoserver.rest] - No such wms store: geonode,geonode_data
>>>>>> From Apache logs, I see that there is an exception thrown by
>>>>>> my_venv/local/lib/python2.7/site-packages/geoserver/catalog.py",
>>>>>> line 249, in save
>>>>>> (headers['status'], body))
>>>>>> FailedRequestError: Error code (403) from GeoServer
>>>>>> Postgre sql is working correctly and I already configured and enabled
>>>>>> a "datastore" PostGIS store in Geoserver.
>>>>>> I followed all instructions about custom installation of Geonode (
>>>>>> http://docs.geonode.org/en/master/tutorials/admin/install/c
>>>>>> ustom_install.html) and advanced security (
>>>>>> http://docs.geonode.org/en/master/tutorials/admin/geoserver
>>>>>> _geonode_security/).
>>>>>> I checked that files exist in the "uploaded" directory under Geonode
>>>>>> folder.
>>>>>> I don't know what to do further to debug this issue.
>>>>>> Can you help me?
>>>>>> Stefano
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171219/1084ed31/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171219/1084ed31/attachment-0001.png>
More information about the geonode-users
