[GeoNode-users] Serving a GeoServer Layer group through GeoNode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Dec 20 08:00:19 PST 2017
This is exactly the purpose of that GNIP, it will allow to select only the
resources to import.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Dec 20, 2017 at 4:58 PM, Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> Hi Alessio,
> But if I import it as a remote service it brings all of the layers
> published by GeoServer thus duplicating all the layers in GeoNode (I'm
> importing a service from the same GeoServer used by GeoNode). Currently, is
> there a way to filter the layers harvested by the remote service?
> Thanks
> On Wed, Dec 20, 2017 at 6:51 AM Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> At the current status I guess the best option is to import them as part
>> of a "Remote Service" i.e. a WMS cascade.
>> This feature currently is not very stable and usable on GeoNode, but
>> improvements are almost ready to be merged by following this GNIP
>> https://github.com/GeoNode/geonode/issues/3517
>> Regards,
>> Alessio Fabiani
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>> (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Mon, Dec 18, 2017 at 5:39 PM, Daniel Victoria <
>> daniel.victoria at gmail.com> wrote:
>>> I'm serving several large rasters in GeoNode, which I loaded into
>>> GeoServer and registered using the command 'geonode updatelayers'.
>>> I now want to group those layers into a 'national' one and I did this
>>> using GeoServer Layer Group function. However, when I run 'geonode
>>> updatelayers', the Layer Group is not identified.
>>> Is it possible to serve Layer Groups through GeoNode? Or should I create
>>> a map? In the end, I'd like to have one WMS service providing 5 layers that
>>> make up a national mosaic.
>>> Cheers
>>> Daniel
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171220/8062f4e2/attachment.html>
More information about the geonode-users mailing list
