[GeoNode-users] Geonode security vulnerability
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Feb 13 04:29:15 PST 2017
Daniel, this good, we did this on master and 2.4.x as well see
https://github.com/GeoNode/geonode/commit/5023b5df25da4acd7854e70f59e3cecb32d3f2f2
Ciao
2017-02-13 12:04 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
> The geonode.conf file in my Geonode instalation (2.4) did not have those
> lines. However, the upload/layers directory was still open to all. Looking
> at the geonode.conf file I noticed that the uploaded/documents directory
> was closed with the options:
> <Directory "/var/www/geonode/uploaded/documents/">
> Order allow,deny
> Deny from all
> </Directory>
> So I repeated the same lines for the layers directory:
> <Directory "/var/www/geonode/uploaded/layers/">
> Order allow,deny
> Deny from all
> </Directory>
> Does that look ok? Or am I bound to break something? Until now, everything
> looks fine
> Thanks
> Daniel
> On Mon, Feb 13, 2017 at 4:15 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi Jonathan,
>> the change is not yet published in the packages but the 2.6 will
>> definitely contain it.
>> Best
>> 2017-02-13 0:28 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au>:
>>> I’ve tested upload at my end after the change: no impact. Also it was
>>> advised (and merged to the doco) by Geonode dev Simone Dalmasso.
>>> Regards
>>> Jonathan
>>> *From:* Daniel Victoria [mailto:daniel.victoria at gmail.com]
>>> *Sent:* Friday, 10 February 2017 11:22 PM
>>> *To:* Jonathan Doig
>>> *Cc:* geonode-users at lists.osgeo.org
>>> *Subject:* Re: [GeoNode-users] Geonode security vulnerability
>>> Hi Jonathan,
>>> Thanks for the heads up. Just to be sure, by changing the geonode.conf I
>>> wont break any other GeoNode funcionality?
>>> Cheers
>>> Daniel
>>> On Thu, Feb 9, 2017 at 10:10 PM, Jonathan Doig <j.doig at unsw.edu.au>
>>> wrote:
>>> Dear all
>>> I found this issue on my own site and am passing it on as it also
>>> affects a number of sites I’ve found online.
>>> The data on your Geonode site may be publicly downloadable, regardless
>>> of permissions, at:
>>> http://<your_geonode_host>/uploaded/layers/
>>> You need to edit /etc/apache2/sites-available/geonode.conf and remove
>>> the block which tells Apache to serve uploaded/layers/. It will look
>>> something like this:
>>> <Directory "/home/geonode/geonode/geonode/uploaded/layers/">
>>> Order allow,deny
>>> Options Indexes FollowSymLinks
>>> Allow from all
>>> Require all granted
>>> IndexOptions FancyIndexing
>>> </Directory>
>>> Then restart Apache:
>>> sudo service apache2 restart
>>> I’ve issued a pull request
>>> <https://github.com/GeoNode/geonode/pull/2899> to update the install
>>> doco
>>> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html#apache-configuration>.
>>> As a courtesy, I’ve also contacted the admins of sites I found through a
>>> “Powered by Geonode” Google search.
>>> Regards
>>> *Jonathan Doig*
>>> *Software Engineer – Spatial Systems*
>>> *City Futures Research Centre*
>>> *UNSW Built Environment *
>>> Level 3, Red Centre West Wing
>>> UNSW Sydney
>>> NSW 2052 AUSTRALIA
>>> T:+ 61 (2) 9385 5319 <+61%202%209385%205319> M: 0409 049185
>>> cityfutures.net.au <http://cityfutures.be.unsw.edu.au/>
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170213/36c7678a/attachment-0001.html>
More information about the geonode-users
