[GeoNode-users] Custom Installation
Paolo Corti pcorti at gmail.com
Fri Feb 17 06:17:53 PST 2017
Before starting using httpd and mod_wsgi: does your GeoNode instance
work correctly with the development server? You can start it with
paver start, as suggested in the documentation page you have linked
p
On Fri, Feb 17, 2017 at 8:31 AM, Giovani Fronza <giovanifronza at gmail.com> wrote:
> Thankyou very much Paolo!
> After installation I faced problem with wsgi. Something related to
> geoserver.catalog.
> I found this on apache error.log
>  mod_wsgi (pid=22240): Target WSGI script '/home/geonode/geonode/wsgi.py'
> cannot be loaded as Python module.
>  mod_wsgi (pid=22240): Exception occurred processing WSGI script
> '/home/geonode/geonode/wsgi.py'.
>  Traceback (most recent call last):
>    File "/home/geonode/geonode/wsgi.py", line 30, in <module>
>      application = get_wsgi_application()
>    File "/usr/local/lib/python2.7/dist-packages/django/core/wsgi.py", line
> 14, in get_wsgi_application
>      django.setup()
>    File "/usr/local/lib/python2.7/dist-packages/django/__init__.py", line
> 18, in setup
>      apps.populate(settings.INSTALLED_APPS)
>    File "/usr/local/lib/python2.7/dist-packages/django/apps/registry.py",
> line 108, in populate
>      app_config.import_models(all_models)
>    File "/usr/local/lib/python2.7/dist-packages/django/apps/config.py", line
> 198, in import_models
>      self.models_module = import_module(models_module_name)
>    File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
> import_module
>      __import__(name)
>    File "/home/geonode/geonode/services/models.py", line 24, in <module>
>      from geoserver.catalog import FailedRequestError, Catalog
>  ImportError: No module named catalog
> How to resolv that?
> 2017-02-16 18:24 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> Hi Giovani
>> you should be able to get the 2.6 (note that it is still not released) by
>> checking out the 2.6 tag from git:
>> https://github.com/GeoNode/geonode/tree/debian/2.6.0+alpha1
>> hope it helps
>> p
>> On Thu, Feb 16, 2017 at 3:09 PM, Giovani Fronza <giovanifronza at gmail.com>
>> wrote:
>> > I've just installed the current geonode.git, according to the
>> > instructions
>> > presented on
>> > http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html,
>> > and for my surprise that was installed the 2.7.dev version.
>> > I'm curious about 2.6 stable release. We have just started a big project
>> > to
>> > manage geospatial data and we would like to lead with a solution newest
>> > as
>> > possible.
>> > Is there a realistic date for 2.6 version launch?
>> > What are your recomendations for custom installation (for debian),
>> > considering this situation?
>> > Giovani
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
