[GeoNode-users] Custom Installation
Simone Dalmasso simone.dalmasso at gmail.com
Fri Feb 17 07:09:29 PST 2017
Hi, seems that you may have a wrong version of gsconfig. pls check that.
2017-02-17 16:05 GMT+01:00 Giovani Fronza <giovanifronza at gmail.com>:
> I think so. Don“t tried to start paver before, but now, it retuns this
> messanges:
> ---> pavement.start_django
> python manage.py runserver  &
> GeoNode is now available.
> root at vmgeo:/home/geonode# Performing system checks...
> System check identified some issues:
> WARNINGS:
> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
> ManyToManyField.
> System check identified 1 issue (0 silenced).
> February 17, 2017 - 08:54:03
> Django version 1.8.17, using settings 'geonode.settings'
> Starting development server at http://127.0.0.1:8000/
> Quit the server with CONTROL-C.
> 2017-02-17 12:17 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> Before starting using httpd and mod_wsgi: does your GeoNode instance
>> work correctly with the development server? You can start it with
>> paver start, as suggested in the documentation page you have linked
>> p
>> On Fri, Feb 17, 2017 at 8:31 AM, Giovani Fronza <giovanifronza at gmail.com>
>> wrote:
>> > Thankyou very much Paolo!
>> > After installation I faced problem with wsgi. Something related to
>> > geoserver.catalog.
>> > I found this on apache error.log
>> >  mod_wsgi (pid=22240): Target WSGI script '/home/geonode/geonode/wsgi.py
>> > cannot be loaded as Python module.
>> >  mod_wsgi (pid=22240): Exception occurred processing WSGI script
>> > '/home/geonode/geonode/wsgi.py'.
>> >  Traceback (most recent call last):
>> >    File "/home/geonode/geonode/wsgi.py", line 30, in <module>
>> >      application = get_wsgi_application()
>> >    File "/usr/local/lib/python2.7/dist-packages/django/core/wsgi.py",
>> line
>> > 14, in get_wsgi_application
>> >      django.setup()
>> >    File "/usr/local/lib/python2.7/dist-packages/django/__init__.py",
>> line
>> > 18, in setup
>> >      apps.populate(settings.INSTALLED_APPS)
>> >    File "/usr/local/lib/python2.7/dist-packages/django/apps/registry
>> .py",
>> > line 108, in populate
>> >      app_config.import_models(all_models)
>> >    File "/usr/local/lib/python2.7/dist-packages/django/apps/config.py",
>> line
>> > 198, in import_models
>> >      self.models_module = import_module(models_module_name)
>> >    File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>> > import_module
>> >      __import__(name)
>> >    File "/home/geonode/geonode/services/models.py", line 24, in
>> <module>
>> >      from geoserver.catalog import FailedRequestError, Catalog
>> >  ImportError: No module named catalog
>> > How to resolv that?
>> > 2017-02-16 18:24 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> >> Hi Giovani
>> >> you should be able to get the 2.6 (note that it is still not released)
>> by
>> >> checking out the 2.6 tag from git:
>> >> https://github.com/GeoNode/geonode/tree/debian/2.6.0+alpha1
>> >> hope it helps
>> >> p
>> >> On Thu, Feb 16, 2017 at 3:09 PM, Giovani Fronza <
>> >> wrote:
>> >> > I've just installed the current geonode.git, according to the
>> >> > instructions
>> >> > presented on
>> >> > http://docs.geonode.org/en/master/tutorials/admin/install/
>> custom_install.html,
>> >> > and for my surprise that was installed the 2.7.dev version.
>> >> > I'm curious about 2.6 stable release. We have just started a big
>> project
>> >> > to
>> >> > manage geospatial data and we would like to lead with a solution
>> newest
>> >> > as
>> >> > possible.
>> >> > Is there a realistic date for 2.6 version launch?
>> >> > What are your recomendations for custom installation (for debian),
>> >> > considering this situation?
>> >> > Giovani
>> >> > _______________________________________________
>> >> > geonode-users mailing list
>> >> > geonode-users at lists.osgeo.org
>> >> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>> >> Paolo Corti
>> >> Geospatial software developer
>> >> web: http://www.paolocorti.net
>> >> twitter: @capooti
>> >> skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170217/7820e94d/attachment-0001.html>
More information about the geonode-users mailing list
