[GeoNode-users] Multi-Tenancy: how to start
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Jan 2 23:35:23 PST 2017
Eugenio is all more or less right.
The error you have is because, since you copied the site_template folder
manually, you also have to correctly adjust the variables in the files that
start with "$". In this case you have to put the correct project name in
the wsgi.py-
For the static files, they can stay anywhere, but is suggested to have them
in the web server folders /var/www etc,as said. To copy them there, once
you have set the STATIC_ROOT folder in the geosite settings yu can use the
normal geonode manage.py file by passing it the geosites settings instead:
python manage.py collectstatic
--settings=geonode.contrib.geosites.gemex.settings
2016-12-29 12:21 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone and all,
> unfortunately I hadn't solved my problem multi-tenancy configuration.
> My new questions are:
> - can I set-up multi-geosites from my running normal installation? (I
> installed geonode following this guide [1]) or should I install a geonode
> from scratch?
> - to run multi-geosites do you suggest me to setup multi-geosite from
> special version of geonode as for instance [2], if yes How to start?
> - in my geonode normal installation manage.py and manage_all.py are
> missing in the /geonode/geonode/contrib/geosites/
> - the master site has to be within contrib/geosites/master-site, which
> relationship is there between the normal geonode site and the master-site?
> in case master-site has to inherit from normal one-site config, how?
> - just to be sure is this the right order of the setting files read by
> geonode:
> - /geonode/geonode/local_setting.py and /geonode/geonode/setting.py
> (overridden by the first)
> - /geonode/geonode/contrib/geosites/pre_setting.py
> - /geonode/geonode/contrib/geosites/local_setting.py
> and /geonode/geonode/contrib/geositessetting.py (overridden by the
> first)
> - /geonode/geonode/contrib/geosites/post_setting.py
> - in my test performed in the last days I set the: SERVE_PATH=
> "/dati/geonode/geonode/contrib/geosites/ in /geonode/geonode/local_setting.py
> is that right? in apache error log I have:
> [Thu Dec 29 11:46:21.129691 2016] [:error] [pid 14216] [remote
> 93.32.72.156:62917] self.load_middleware()
> [Thu Dec 29 11:46:21.129706 2016] [:error] [pid 14216] [remote
> 93.32.72.156:62917] File "/usr/local/lib/python2.7/
> dist-packages/django/core/handlers/base.py", line 44, in load_middleware
> [Thu Dec 29 11:46:21.129728 2016] [:error] [pid 14216] [remote
> 93.32.72.156:62917] for middleware_path in
> settings.MIDDLEWARE_CLASSES:
> [Thu Dec 29 11:46:21.129742 2016] [:error] [pid 14216] [remote
> dist-packages/django/conf/__init__.py", line 54, in __getattr__
> [Thu Dec 29 11:46:21.129763 2016] [:error] [pid 14216] [remote
> 93.32.72.156:62917] self._setup(name)
> [Thu Dec 29 11:46:21.129776 2016] [:error] [pid 14216] [remote
> dist-packages/django/conf/__init__.py", line 49, in _setup
> [Thu Dec 29 11:46:21.129797 2016] [:error] [pid 14216] [remote
> 93.32.72.156:62917] self._wrapped = Settings(settings_module)
> [Thu Dec 29 11:46:21.129810 2016] [:error] [pid 14216] [remote
> dist-packages/django/conf/__init__.py", line 132, in __init__
> [Thu Dec 29 11:46:21.129831 2016] [:error] [pid 14216] [remote
> 93.32.72.156:62917] % (self.SETTINGS_MODULE, e)
> [Thu Dec 29 11:46:21.129851 2016] [:error] [pid 14216] [remote
> 93.32.72.156:62917] ImportError: Could not import settings
> '$PROJECT_NAME.gemex.settings' (Is it on sys.path? Is there an import error
> in the settings file?): No module named $PROJECT_NAME.gemex.settings
> the error at last line it is seems to be related to something missing....
> - last but not least I still have doubt on the positioning of
> static_root folder for each geosites, I would maintain them within each
> geosite folder but I don't know how to run collectstatic to populate that
> folder.
> Thanks for any hint...
> Eugenio
> [1] http://docs.geonode.org/en/latest/tutorials/install_and_
> admin/geonode_install/index.html
> [2]
> <http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/index.html>
> https://github.com/terranodo/geosites-project
> terranodo/geosites-project <https://github.com/terranodo/geosites-project>
> github.com
> geosites-project - A skeleton project for creating a multi-tenancy GeoNode
> using the GeoSites contrib app.
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* mercoledì 21 dicembre 2016 10.37
> *A:* Eugenio Trumpy
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: Multi-Tenancy: how to start
> ok:
> - I this that that Alias is a mistake, the way is configured is that any
> url /gemex will internally point to /dati but I don't think they are
> actually urls. You can remove it
> - you can assign a new name to WSGIProcessGroup
> - it ok to keep the dir in the root base of geonode since your site is
> inside
> - the geonode apt package creates the uploaded and static root under
> var/www as far as I know. It is ok to reuse the same settings. If not I
> suggest you to put them there as they are meant to be served by apache.
> - you can use the same config for the Daemon, just use the name you gave
> to the WSGIProcessGroup instead of geonode
> This is a brief explanation but you can find more on the static url and
> roots on the django docs and more on the wsgi config on the apache docs
> hope this helps.
> 2016-12-20 9:36 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi Simone and all,
>> thanks again for your inputs.
>> However, I think I'm at a crucial position to finalize the configuration
>> of the first new geosite (named gemex).
>> Just to clarify all the step performed and to focus the stage where I'm
>> now, I list here below what I did and what I miss:
>> 1. in setting.py I added under INSTALLED_APPS the line
>> 'geonode.contrib.geosites'
>> 2. I run python manage.py syncdb
>> 3. I copy site-template (i.e. the folder inside contrib/geosites/) in
>> the same position (i.e. contrib/geosites/) with a new name (e.g. gemex in
>> my case)
>> 4. I created a 4 level doman to be linked to the new site (i.e.
>> gemex.igg.cnr.it in my case)
>> 5. I added a new site from the admin panel available from a normal
>> running installation
>> 6. I create a new virtual host (for apache2) by copy the virtual host
>> I had for the normal running installation. Here what is clear to me are the
>> items:
>> - ServerName = where I put the created 4 level domain
>> - WSGIScriptAlias where I put the link to the wsgi.py available
>> within the created newsite (i.e. path to contrib/geosites/gemex/wsgi.py
>> - ProxyPass and ProxyPassReverse linked to the local geoserver
>> What is not yet clear:
>> from your last email I understand that the new site can be where I
>> prefer. I would say that for now I can leave it inside contrib/geosites, if
>> I can of course.
>> Then I have doubts to setup these lines:
>> - In the normal config I have Alias /geonode /dati/geonode/geonode
>> but I think I should change to link it to my new site, is it right?
>> - In WSGIProcessGroup the normal config has geonode, for my new site
>> do I need to change it?
>> - Regarding the directive Directory I had <Directory
>> "/dati/geonode/geonode/"> for the normal config, here should I insert the
>> path to my new site?
>> - Regarding /uploaded/ and /static/ Aliases, I understood from your
>> email I can put those directory where I prefer. Now another trivial
>> question: /uploaded/ and /static/ folder have to be different from those
>> created for the normal installation? if no, then it is easy both configure
>> the virtual host and run collectstatic. If yes, it is not clear how to run
>> collectstatic for the new site. That's why the command python manage.py
>> collectstatic works only within geonode folder and fill in the normal
>> static_root folder. Could you clarify this point?
>> - Last but not least the line WSGIDaemonProcess is not clear, because
>> running: service apache reload I had an error: Name duplicates
>> previous WSGI daemon definition (that's why apache find the virtualhost I
>> have for the normal installation. The normal installation has: WSGIDaemonProcess
>> geonode python-path=/dati/geonode/:/dati/.venvs/geonode/lib/python2.7/site-packages
>> user=eugenio threads=15 processes=2 How should sort out this line for the
>> new site?
>> I offer myself to prepare an how to for dummies to be included as
>> documentation in git, if I will be able to configure geosites.
>> Thanks for any clarification
>> Eugenio
>> *Inviato:* lunedì 19 dicembre 2016 18.33
>> *A:* Eugenio Trumpy
>> I mean the whole gemex folder can be outside. For the static roots they
>> can be anywhere and is not recommended to have them inside but rather in
>> /var/www as they need to be served by the web server at some point.
>> 2016-12-19 16:50 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Ok, once I run syncdb I 'm able to register new site! first step!!!!
>>> Coming back to the first issue, I'm not sure to have understood well, do
>>> you mean the dir thumb, layers, static_root can stay ouside my newsite
>>> directory?
>>> That means I cannot run collectstatic if those dirs are inside my site
>>> dir?
>>> Actually in the docs I read I saw that the static folder is inside the
>>> new sites.
>>> This part is not so clear to me....
>>> E.
>>> *Inviato:* lunedì 19 dicembre 2016 16.22
>>> *A:* Eugenio Trumpy
>>> It is a good practice to not install the new sites folders into the root
>>> of the code. They can live outside without problems.
>>> The second issue is that you did not run python manage.py syncdb or
>>> migrate to install the tables that come with geosites.
>>> 2016-12-19 15:50 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>> Sorry for these multiple emails,
>>>> I following your suggestion to create the site by hand I proceeded to
>>>> register the new site by using the admin console as you suggested.
>>>> On save action I had this error message:
>>>> http://pastebin.com/SskX1QNB
>>>> It seems geonode.contrib.geosites is not installed yet, right?
>>>> E.
>>>> *Da:* Eugenio Trumpy <frippe12573 at hotmail.com>
>>>> *Inviato:* lunedì 19 dicembre 2016 15.37
>>>> *A:* Simone Dalmasso
>>>> Ok,
>>>> this is my new virtualhost prepared for the new site named 'gemex':
>>>> <VirtualHost *:80>
>>>> ServerName http://gemex.igg.cnr.it
>>>> ServerAdmin webmaster at localhost
>>>> DocumentRoot /var/www/html
>>>> Options -Indexes +FollowSymLinks
>>>> Alias /gemex "/dati/geonode/geonode/contrib/geosites"
>>>> WSGIDaemonProcess gemex python-path=/dati/geonode/geon
>>>> ode/contrib/geosites:/dati/.venvs/geonode/lib/python2.7/site-packages
>>>> ErrorLog /var/log/apache2/error.log
>>>> LogLevel warn
>>>> CustomLog /var/log/apache2/access.log combined
>>>> WSGIProcessGroup gemex
>>>> WSGIPassAuthorization On
>>>> WSGIScriptAlias / /dati/geonode/geonode/contrib/
>>>> <Directory "/dati/geonode/geonode/contrib/geosites/gemex">
>>>> Options Indexes FollowSymLinks
>>>> Require all granted
>>>> IndexOptions FancyIndexing
>>>> </Directory>
>>>> Alias /uploaded/ /dati/geonode/geonode/contrib/
>>>> geosites/gemex/uploaded/
>>>> Alias /static/ /dati/geonode/geonode/contrib/
>>>> geosites/gemex/static_root/
>>>> ProxyPreserveHost On
>>>> ProxyPass /geoserver http://localhost:8080/geoserver
>>>> ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>>> ProxyPass /geoserver2 http://localhost:8080/geoserver2
>>>> ProxyPassReverse /geoserver2 http://localhost:8080/geoserver2
>>>> </VirtualHost>
>>>> My concerns are:
>>>> - WSGIDeamon line, is that correct?
>>>> - the first Alias, is that correct too?
>>>> - Eventually the Directory is right?
>>>> Moreover, I followed again this page for the http setup:
>>>> http://docs.geonode.org/en/master/tutorials/install_and_admi
>>>> n/geonode_install/setup_configure_httpd.html
>>>> I think now should be rready for the collecstatic command, but I don't
>>>> know how to run it in in the new static_root inside my site gemex.
>>>> Any hints?
>>>> E.
>>>> Setup & Configure HTTPD — GeoNode 2.4 documentation
>>>> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html>
>>>> docs.geonode.org
>>>> Setup & Configure HTTPD¶ In this section we are going to setup Apache
>>>> HTTP to serve GeoNode.
>>>> *Inviato:* lunedì 19 dicembre 2016 15.03
>>>> *A:* Eugenio Trumpy
>>>> Exactly, one virtualhost for each site.
>>>> 2016-12-19 14:53 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>> Ok,
>>>>> I will proceed this way.
>>>>> Then I have to create a new virtualhost pointing to the wsgi.py within
>>>>> the new site dir, right?
>>>>> In the same virtual host have I to set new aliases for uploaded dir
>>>>> and static_root as I did for the normal installation?
>>>>> E.
>>>>> *Inviato:* lunedì 19 dicembre 2016 14.21
>>>>> *A:* Eugenio Trumpy
>>>>> I suggest you to go manually and create a site folder copying the
>>>>> site_template, rename and add the Site object into the database.
>>>>> geosites has not been revised for a while and geonode improved. It
>>>>> works but the shortcut command addsite may be broken.
>>>>> 2016-12-19 11:32 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>> Hi Simone,
>>>>>> I did what you suggested, actually now I have the addsite command,
>>>>>> but as you announced I have also this error:
>>>>>> AttributeError: 'Settings' object has no attribute 'SITE_ROOT'
>>>>>> then I added SITE_ROOT in local_setting.py inserting the path
>>>>>> "geonode/contrib/geosites"
>>>>>> afterwords I had this error:
>>>>>> AttributeError: 'Settings' object has no attribute 'SERVE_PATH'
>>>>>> so that I added SERVE_PATH in local_setting.py inserting the path "
>>>>>> geonode/contrib/geosites/static"
>>>>>> but I'm not sure I did the right thing, since now I have this error:
>>>>>> OSError: [Errno 17] File exists: '/dati/geonode/geonode/contrib
>>>>>> /site2'
>>>>>> Where I'm wrong?
>>>>>> Thanks
>>>>>> Eugenio
>>>>>> *Inviato:* lunedì 19 dicembre 2016 11.04
>>>>>> *A:* Eugenio Trumpy
>>>>>> you have to add it in INSTALLED_APPS, currently it is only listed in
>>>>>> the contrib apps.
>>>>>> 2016-12-19 9:20 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>>> Hi Simone,
>>>>>>> and thank you for your answer.
>>>>>>> Sorry for my trivial question:
>>>>>>> in my setting.py I have already geonode.contrib.geosites
>>>>>>> in GEONODE_CONTRIB_APPS, see below:
>>>>>>> GEONODE_CONTRIB_APPS = (
>>>>>>> # GeoNode Contrib Apps
>>>>>>> 'geonode.contrib.dynamic',
>>>>>>> 'geonode.contrib.exif',
>>>>>>> 'geonode.contrib.favorite',
>>>>>>> 'geonode.contrib.geogig',
>>>>>>> 'geonode.contrib.geosites',
>>>>>>> 'geonode.contrib.nlp',
>>>>>>> 'geonode.contrib.slack'
>>>>>>> in INSTALLED_APPS I have:
>>>>>>> INSTALLED_APPS = (
>>>>>>> # Boostrap admin theme
>>>>>>> # 'django_admin_bootstrapped.bootstrap3',
>>>>>>> # 'django_admin_bootstrapped',
>>>>>>> # Apps bundled with Django
>>>>>>> 'django.contrib.auth',
>>>>>>> 'django.contrib.contenttypes',
>>>>>>> 'django.contrib.sessions',
>>>>>>> 'django.contrib.sites',
>>>>>>> 'django.contrib.admin',
>>>>>>> 'django.contrib.sitemaps',
>>>>>>> 'django.contrib.staticfiles',
>>>>>>> 'django.contrib.messages',
>>>>>>> 'django.contrib.humanize',
>>>>>>> 'django.contrib.gis',
>>>>>>> # Third party apps
>>>>>>> # Utility
>>>>>>> 'pagination',
>>>>>>> 'taggit',
>>>>>>> 'friendlytagloader',
>>>>>>> 'geoexplorer',
>>>>>>> 'leaflet',
>>>>>>> 'django_extensions',
>>>>>>> # 'haystack',
>>>>>>> ....and others...
>>>>>>> Should I insert geonode.contrib.geosites somewhere in local_setting?
>>>>>>> or it's already ok as it? or copy geonode.contrib.geosites in
>>>>>>> settings.py under INSTALLED_APPS?
>>>>>>> Sorry again for this banal question...
>>>>>>> E.
>>>>>>> *Inviato:* lunedì 19 dicembre 2016 09.04
>>>>>>> *A:* Eugenio Trumpy
>>>>>>> Ciao Eugenio,
>>>>>>> sorry for being so late in the response.
>>>>>>> You have to add 'geonode.contrib.geosites' to your INSTALLED_APPS in
>>>>>>> order to get the command.
>>>>>>> In case you get errors in running that command, you can always
>>>>>>> 'make' a geosite by yourself by copying the folder 'site_template' and
>>>>>>> changing it's name and internal parameters and then register the new Site
>>>>>>> in the admin panel. You can follow the utils.py add_site function and
>>>>>>> replicate the needed steps (some of them are only for production).
>>>>>>> Take also some time to see how the pre and post settings work.
>>>>>>> Hope this helps
>>>>>>> 2016-12-19 8:55 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>>>> Hi everyone,
>>>>>>>> regarding the multi-tenancy setting up and in particular the
>>>>>>>> installation of new site since the command:
>>>>>>>> python manage.py addsite sitename sitedomain
>>>>>>>> return me:
>>>>>>>> Unknown command: 'addsite'
>>>>>>>> Type 'manage.py help' for usage.
>>>>>>>> Do you know way? Have I 'activate' in some way the multi-tenancy
>>>>>>>> before? or it is ready to use?
>>>>>>>> If it is ready to use, why 'addsite' is an unknown command?
>>>>>>>> I launched the command from the main geonode directory, am I right?
>>>>>>>> As I wrote in the previous email in my installation I have only
>>>>>>>> manage.py file in
>>>>>>>> /geonode directory.
>>>>>>>> I'm testing on on ubuntu 14.04 and geonode is at version
>>>>>>>> 2.4.dev20151029170512.
>>>>>>>> I installed geonode as custom installation (not by apt-get).
>>>>>>>> Thanks
>>>>>>>> Eugenio
>>>>>>>> *Inviato:* venerdì 16 dicembre 2016 15.04
>>>>>>>> *A:* geonode-users at lists.osgeo.org
>>>>>>>> *Oggetto:* Multi-Tenancy: how to start
>>>>>>>> Hi all,
>>>>>>>> as pointed in the email object I want to try the
>>>>>>>> geonode multi-tenancy capabilities.
>>>>>>>> I started of course from the documentation [1] and [2], but a need
>>>>>>>> some hints to start.
>>>>>>>> I have already a running geonode instance. Do you think I should
>>>>>>>> start from
>>>>>>>> a clean geonode installation or I can arrange the running one?
>>>>>>>> Is there somewhere a set of commands to setup the geosite 1,
>>>>>>>> geosite 2, ...
>>>>>>>> I was looking into geosites folder, as suggested in [2], but I
>>>>>>>> don't see neither manage.py nor manage_all.py files.
>>>>>>>> I tried python manage.py addsite geosite1 geosite1domain
>>>>>>>> but I got Unknown command: 'addsite'
>>>>>>>> Am I missing something?
>>>>>>>> After that: How can I sort out the already stored layers?
>>>>>>>> Thank you very much for hints and for the patience of this
>>>>>>>> stupid questions,
>>>>>>>> Eugenio
>>>>>>>> [1] https://geonode.readthedocs.io/en/2.0/tutorials/admin/mu
>>>>>>>> lti-tenancy.html
>>>>>>>> [2] https://github.com/GeoNode/geonode/tree/master/geonode/c
>>>>>>>> ontrib/geosites
>>>>>>> Simone
>>>>>> Simone
>>>>> Simone
>>>> Simone
>>> Simone
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170103/83d9a999/attachment-0001.html>
More information about the geonode-users
