[GeoNode-users] installing geonode 2.5.6
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri Jan 6 11:33:39 PST 2017
Hi all,
Ansible 2.x related issues are now fixed.
Cheers,
Angelos
On 01/05/2017 01:16 PM, Dave Kennewell wrote:
> Hi Angelos,
> Thanks for this - I've tried the geonode-ansible installer. It seems to be
> working well, until I get to the "makemigrations" command, when I get this
> permissions error:
> [image: Inline images 1]
> If I ssh into the server, activate the venv and execute the makemigrations
> command manually, it works fine... but the rest of the playbook won't run.
> My playbook looks like this
> - hosts: webserver
>    remote_user: ubuntu
>    vars:
>      app_name: my_test_app
>      github_user: GeoNode
>    roles:
>      - geonode
> Both my ansible controlling machine & the geonode server are running
> Xenial.
> It's my first time using ansible, so I might be doing something not quite
> right, or it might the the scripts?
> Thanks
> Dave Kennewell
> On 3 January 2017 at 18:29, Angelos Tzotsos [via OSGeo.org] <
> ml-node+s1560n5301842h17 at n6.nabble.com> wrote:
>> Hi all,
>> I just completed updating the ansible installer for Ubuntu Xenial:
>> https://github.com/GeoNode/ansible-geonode
>> Please test and let me know how this works out.
>> I am going to work on the ppa issues next.
>> Best,
>> Angelos
>> On 01/03/2017 10:01 AM, David Kennewell wrote:
>> Ah, thanks Simone... I had been trying on Ubuntu 14.04 and not getting
>> anywhere with the /testing repo.
>> On 16.04 I'm now getting the same packaging problems as Jeff mentioned in
>> his recent email (subject: "GeoNode 2.5.6 is out"). But at least I'm now on
>> the same page as everyone else :)
>> (and apologies for any cross-posting with this reply, I've been getting
>> confused with my email lists)
>> David Kennewell
>> Water Resources Engineer
>> Hydrata.com
>> +971 55 409 7378[hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=0>
>> On Tue, Jan 3, 2017 at 11:08 AM, Simone Dalmasso [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=1>
>> wrote:
>> Hi, the fastest is to install geonode on xenial using the normal geonode
>> installation guide but just use:
>> sudo add-apt-repository ppa:geonode/testing
>> instead of
>> sudo add-apt-repository ppa:geonode/stable.
>> hope this helps
>> 2017-01-03 7:38 GMT+01:00 David Kennewell [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=2>:
>> Hi list,
>> I'd like to try out the new react viewer, and use django 1.8, not 1.6.
>> As of today, what's the easiest way to get this up and running on a clean
>> server?
>> regards
>> Dave
>> geonode-users mailing list[hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=3>http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
>> geonode-users mailing list[hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=4>http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Angelos Tzotsos, PhD
>> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
>> geonode-devel mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=5>
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Re-GeoNode-users-install
>> ing-geonode-2-5-6-tp5301842.html
>> To unsubscribe from GeoNode devel, click here
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185388&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OHwtOTI1NjEyMTk0>
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> geonode-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170106/474c706b/attachment.html>
More information about the geonode-users mailing list
