[GeoNode-users] apt-get geonode 2.5.4
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Jan 16 05:25:47 PST 2017
Hi, we are doing some tests on the packages so it should be out in the
upcoming weeks
2017-01-16 13:24 GMT+01:00 Giovani Fronza <giovanifronza at gmail.com>:
> There is some prevision for the 2.6 version launch?
> 2017-01-05 22:05 GMT-02:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>> Hi,
>> The debian packaging is not completed yet.
>> Please use the stable ppa for GeoNode 2.4.x or use the ansible script to
>> install 2.5.x
>> https://github.com/GeoNode/ansible-geonode
>> Cheers,
>> Angelos
>> On 01/05/2017 04:07 PM, Finnegan Pope-Carter wrote:
>> Hi, I’m running into an error when trying to install geonode 2.5.4 on a fresh copy of Ubuntu 16.04. I’ve added the ppa:geonode/testing repository and run apt-get update but when I try to install geonode I get the following error:
>> @geonode2:~$ sudo apt-get install geonode
>> Reading package lists... Done
>> Building dependency tree
>> Reading state information... Done
>> Some packages could not be installed. This may mean that you have
>> requested an impossible situation or if you are using the unstable
>> distribution that some required packages have not yet been created
>> or been moved out of Incoming.
>> The following information may help to resolve the situation:
>> The following packages have unmet dependencies:
>> geonode : Depends: geoserver-geonode but it is not installable or
>> geoserver but it is not installable
>> Depends: postgresql-9.1-postgis but it is not installable or
>> postgresql-9.3-postgis-2.1 but it is not installable
>> Depends: python-geonode-agon-ratings but it is not installable
>> Depends: python-dialogos but it is not installable
>> Depends: python-django-geoexplorer but it is not installable
>> Depends: python-geonode-notification but it is not installable
>> Depends: python-django-taggit-templatetags but it is not installable
>> Depends: python-geonode-user-accounts but it is not installable
>> Depends: python-geonode-avatar but it is not installable
>> Depends: python-gsconfig but it is not installable
>> Depends: python-geonode-announcements but it is not installable
>> Depends: python-pinax-theme-bootstrap but it is not going to be installed
>> Depends: python-tastypie but it is not installable
>> Depends: python-django-modeltranslation but it is not installable
>> Depends: python-gsimporter but it is not installable
>> Depends: python-geonode-arcrest but it is not installable
>> Recommends: python-gisdata but it is not installable
>> Recommends: transifex-client but it is not going to be installed
>> E: Unable to correct problems, you have held broken packages.
>> Can anyone tell me what I’m doing wrong?
>> Kind regards
>> Finn
>> geonode-users mailing listgeonode-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geonode-users
>> Angelos Tzotsos, PhD
>> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170116/da33e694/attachment.html>
More information about the geonode-users
