[GeoNode-users] Multi-Tenancy on apt-get installation
Davide Sandona'
sandona.davide at gmail.com
Thu Jan 26 06:51:08 PST 2017
Thanks Simone, I will give it a try and I did read the previous discussion
on this list about Multi-Tendancy. Thank you! :)
Davide.
2017-01-26 13:37 GMT+01:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi Davide,
> in order to customise geonode in production you should use the geonode
> project, see here https://github.com/GeoNode/geonode-project. It is
> always suggested to first try in dev mode and then switch to production.
> Just a note, the documentation on geosites is not 100% correct (for
> example the addsite command is not available and you have to manually copy
> and modify the template folder) and you will have to know some django
> basics in order to set it up correctly.
> hope this helps
> 2017-01-26 13:31 GMT+01:00 Davide Sandona' <sandona.davide at gmail.com>:
>> Hello,
>> I've setup a Virtual Machine running Ubuntu 14.04, and I've installed
>> GeoNode using atp-get. I was looking to test a Multi-Tenancy setup.
>> I'm not able to locate the settings.py file, in order to add
>> "geonode.contrib.geosites" to INSTALLED_APPS.
>> Reading the docs, it should be located into /etc/geonode folder, instead
>> in that folder there is the local_settings.py file (there is no
>> INSTALLED_APPS variable in this file).
>> How these two files (settings.py and local_settings.py) are related? What
>> should I do?
>> Davide.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170126/0460879e/attachment.html>
More information about the geonode-users
